Author Topic: Using dowels  (Read 620 times)
Offline cliffreaves
  • Finally figuring things out.
Using dowels
« on: April 04, 2019, 10:09:10 PM »
Does anyone use dowels as stickers? I realize you would need to have squared off stickers at each end, but overall there would be less contact with the lumber. I recently found some 3/4" &1" x 3ft dowels for cheap and it got me to thinking. Less sticker stain perhaps?  Or what do you all use for stickers?
Offline kelLOGg
Re: Using dowels
« Reply #1 on: April 05, 2019, 06:39:35 AM »
They would have less contact with the wood which may allow for faster drying but I think they would roll out of place too easily before the next board goes on top. You may have a good deal on them but I can't imagine they are cheaper than those you can cut yourself.
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline ljohnsaw
Re: Using dowels
« Reply #2 on: April 05, 2019, 09:43:57 AM »
With less contact area come greater PSI.  You would likely dent the wood on the lower layers as all the weight is concentrated along that narrow contact point of each sticker/dowel.
John Sawicky
Offline cliffreaves
Re: Using dowels
« Reply #3 on: April 05, 2019, 01:29:39 PM »
Great points. I need dry stickers and I don't have anything dry to make into stickers. I hadn't thought about potential denting. Just looking for a cheap option. Perhaps I'll just rip some 2x4s down.
Offline GeneWengert-WoodDoc
Re: Using dowels
« Reply #4 on: April 05, 2019, 09:41:16 PM »
1x2, actual 3/4 x 1-1/2", are ready to go and not too expensive.
The concentrated load on a small area will crush the wood and can affect subsequent processing.
Offline cliffreaves
Re: Using dowels
« Reply #5 on: April 05, 2019, 10:46:46 PM »
1x2's sound even better!  I most definitely do that.
Online Ianab
Re: Using dowels
« Reply #6 on: April 06, 2019, 12:25:03 AM »
Yeah, generally stickers should be more than 3/4", but less than 1.5".  I use 1 x 1 rough sawn because I can make them easily as I'm sawing. But the "finished" 1 x 2 fit's the guideline as well,  so If you have to buy something, it may as well be that.
It also depends what you are sawing. I can dry cedar and cypress on green stickers cut as I'm milling (edgings) and they are fine. Other species you need to be more careful and use dry sticks. I have a good stash now, and make sure to use dry when it matters. And I still make a few new ones when I'm milling.
Producing dowels
Started by jim king on Drying and Processing
Last post August 31, 2008, 05:17:11 PM
by SwampDonkey
Dowels in Canada
Started by Muskydawg on Timber Framing/Log construction
Last post June 06, 2019, 09:13:53 PM
by BarnMB
Making Dowels
Started by Saki on General Woodworking
Last post January 19, 2014, 09:07:51 AM
by barbender
How to Cut Wood Pegs / Dowels
Started by asca65290 on General Woodworking
Last post June 22, 2011, 06:18:17 AM
by terrifictimbersllc
