Author Topic: Clark 667 transmission problem  (Read 482 times)
Offline BAN
« on: April 07, 2019, 05:33:50 PM »
The drive line that runs the winch stopped. You can turn it by hand so nothing is seized up. Everything else functions normally.  Still moves the machine fine. Any ideas on what's up?
Offline Hans1
Re: Clark 667 transmission problem
« Reply #1 on: April 07, 2019, 10:15:24 PM »
What winch is on it, the timber jack I was running had a neutral on the transfer case. Years ago it looked like it was connected to a lever which was removed. This was a Eaton/Hercules winch
Offline BAN
« Reply #2 on: April 08, 2019, 10:20:32 AM »
Clark winch. Fairly certain problem is in tranny though
Offline kiko
« Reply #3 on: April 09, 2019, 08:15:27 PM »
The shaft inside the transmission has snaped or the spline coupler is stripped. I believe the shaft can be removed with the tractor articulated all the way.  I will check on that.
Offline BAN
« Reply #4 on: April 10, 2019, 09:27:15 AM »
Thanks for info. Haven't started tearing it apart yet. Was hoping not to have to tear transmission out to fix.
Clark skidder 666B transmission problem
Started by VelmerD on Forestry and Logging
Last post August 07, 2018, 08:04:09 AM
by VelmerD
Tj 350 Clark transmission
Started by kb88 on Forestry and Logging
Last post February 14, 2016, 06:54:20 PM
by kiko
clark transmission
Started by 350 cummins on Forestry and Logging
Last post February 15, 2016, 07:11:02 PM
by 350 cummins
Clark 664 transmission lever
Started by Plankton on Forestry and Logging
Last post November 10, 2015, 06:20:02 PM
by Plankton
