Author Topic: john deer 648d  (Read 473 times)
Offline redbone
john deer 648d
« on: April 08, 2019, 10:42:18 AM »
hi
new to the forum,inherited this grapple skidder and don't know to much about it,the grapple closes very slow but opens fine,read somewhere to try swapping hoses and now it closes fast and opens slow is there somewhere else i can check?  also where to check the differancial for fluid level and fill.
this skidder is mechanical.
Offline Firewoodjoe
  • Im getting old
Re: john deer 648d
« Reply #1 on: April 08, 2019, 07:57:35 PM »
Never been around a 648 that old but maybe check the linkage is fully pushing/pulling the spool for the grapple would be a start and the newer Deere’s had a plug in the back diff. Removed a guard below the arch and those model pumped it through the differential lock line I believe. Maybe someone else will chime in. Good luck.
Offline redbone
Re: john deer 648d
« Reply #2 on: April 10, 2019, 09:28:50 AM »
i will check that out this weekend,just trying to get this thing working right so it can be sold.
Offline redbone
Re: john deer 648d
« Reply #3 on: April 11, 2019, 03:57:10 PM »
checked out the linkage and was fine,but i noticed the middle plunger was not going down as far as the other two. disconnected the linkage and tried pushing it down with a pry bar and seems to be jamming up  or something is broke? does anybody know if these can be removed from the valve without removing the whole control valve.thanks mike
john deere 648d turbo skidder
Started by missouri_logger on Forestry and Logging
Last post March 08, 2009, 11:55:34 PM
by missouri_logger
skidder info 648d john deere vs timberjack 240a
Last post January 15, 2009, 07:43:57 PM
by thompsontimber
360 D Timberjack / John Deer
Started by Autocar on Forestry and Logging
Last post December 20, 2013, 10:19:11 AM
by Autocar
john deer 440b parts
Started by saltydog on For Sale
Last post April 03, 2010, 11:44:50 AM
by saltydog
