Author Topic: 1990 LT40 HD  (Read 675 times)
Offline Hondaxr
  • Ride Red
1990 LT40 HD
« on: April 08, 2019, 09:39:52 PM »
Hello.  My brother in law and I just purchased our first sawmill.  We bought it from the wife of the original owner.  It's a 1990 LT40 HD that only has 258 original hours on it.  It came with an engine cover, about 20 used blades,  the operators manual and, the shiplap/shake cutting attachment.  We are looking forward to this new adventure.  It needs a new battery, a water tank and, tank bracket.  The water line is intact.  Im wondering where the to begin the search.  So far I have not been successful in finding what I need.  It would also be nice if there was a picture book of sorts showing how everything should look.  If anyone had any suggestions by all means reply!  Thanks
Offline Southside
Re: 1990 LT40 HD
« Reply #1 on: April 08, 2019, 09:49:42 PM »
Welcome to the Forum.  Call Woodmizer in Indiana tomorrow and give them your info along with the serial number of the mill.  They will register you as the owner in their system which will give you an online parts ordering account complete with parts diagrams, numbers, etc.  In addition, they can help to determine and locate any parts you may need.
I would suggest a full service, alignment, new wheel and drive belts, filters, and grease before you do any sawing as it sounds like it has been sitting a while.  After that she will be good to go for sure as it is basically new.
Enjoy the journey!!
Offline Chuck White
  • Sawing Mobile since 2005
Re: 1990 LT40 HD
« Reply #2 on: April 09, 2019, 06:57:44 AM »
Welcome to the Forestry Forum, Hondaxr, and Congratulations on the "new to you" sawmill!
By all means, contact Wood-Mizer and they will get you started!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline naturaledge1
    • Repose Fire Logs LLC
Re: 1990 LT40 HD
« Reply #3 on: April 09, 2019, 10:35:26 AM »
You will love it , if it doesn't have a hydraulic strip so you don't have to bring it all the way back I would add one and also hydraulic tensioner if it doesn't have it. You will have to install a more robust set of bearings but it's worth it. And the little sight spring you mount on the mast. Not sure if it has an alternator or not , the hydraulics eat a lot of power. If I think of any other addons I will post.
Offline Hondaxr
  • Ride Red
Re: 1990 LT40 HD
« Reply #4 on: April 21, 2019, 12:11:12 AM »
Wood mizer got me on track.  Wondering now if I can cut with the 1 1/2 blade or if I need to stick with the 1 1/4.
1990 cat 518 log skidder
Started by MICKEY108 on Forestry and Logging
Last post February 06, 2015, 03:18:55 PM
by ga jones
1990 Timberjack 990
Started by timberjake on For Sale
Last post July 20, 2010, 10:13:04 PM
by timberjake
1990 170 franklin grappel
Started by coxy on Forestry and Logging
Last post January 17, 2015, 08:29:31 AM
by OntarioAl
1990 ford f350 ?
Started by bigred1951 on General Board
Last post November 17, 2013, 02:33:33 AM
by Gunny 1992
