Author Topic: Gumming Up Saw Milling Pine  (Read 1006 times)
Offline woodweasel
  • I'm No Longer New, But Green As A Gord
« on: April 10, 2019, 11:43:45 AM »
 So a lady called and said the recent storms we had in Central Texas blew a tall pine tree on her house. After someone cut it into it 8' sections, I went to take a lookey see.The logs were on a hill and I would not be able to roll them onto the mill, plus I could not get my mill in her driveway. So I threw her a price which I thought was on the pricey side to pick up logs. Didn't think she would go for it. I had a buddy down the road who had a tractor, which I thought would help me. She jumped on it. So,,,, my buddy was in the hospital and I had to go get my tractor, load logs,take home, unload, then come back to p/u tractor. When I got them home the FUN began.I used EXTRA DAWN,but blades,drive belts,guides kept gumming up. Didnt want to use diesel. What a Admin language edit SHOW! Added more Dawn, didnt help, increased flow, didnt help. Wavy cuts!Changed blades several times. Sticky Admin language edit all over the place.!Lost my ass on this one. Had to soak blades, replace belts, pressure wash entire LT40. What do u EAST TEXAS FELLOWS who cut pine on a regular basic do and use? So,,, she was very happy with the job and said she would have paid Double. :D :D ;D ;D  :) :o
Online doc henderson
Re: Gumming Up Saw Milling Pine
« Reply #1 on: April 10, 2019, 12:05:52 PM »
I have also added pine-sol to my lube tank along with the dawn.  more of a solvent.  wonder if time of year cut had anything to do with the generous amount of sticky stuff you had?  @GeneWengert-WoodDoc
Offline A-z farmer
« Reply #2 on: April 10, 2019, 12:36:45 PM »
Wood weasel
I am not from Texas but from eastern New York .
I have the same problem when milling eastern white pine with all the pitch going every where.
What I use now is cotton spindle lubricant and pinesol mixed with water.I also use a bottle with a hole drilled into it filled with kerosene to put on the blade after each cut .it does not take much to cut pitch off of the blade each time.
As far as your pine pitch on your mill and gloves it will give you a better grip .
The pine pitch lasts on the lumber until it gets to a high temperature to set it .
I know this does not help you now but this is what I have learned from the members on here.
Zeke
Offline E-Tex
  • Rather be Saw'n or Fish'n
    • www.L2Sawmill.com
« Reply #3 on: April 10, 2019, 12:43:06 PM »
Darrel  -  I mill a good deal of pine here in east texas.   it may be over kill but i put dawn, pinesol, and a heavy dose of Spindle lube in my tanks.  and I turn turn the flow up pretty heavy.  THEN, if needed, i squirt a little diesel on the blade when engaged.   Works for me but i do watch it close.
LT-50 Wide, Mahindra 6065
L2 Sawmill LLC
Offline GeneWengert-WoodDoc
« Reply #4 on: April 10, 2019, 12:52:41 PM »
Within the four species that make up what is commonly called southern pine, the amount of sap or resin or pitch can vary.  Loblolly has the least; longleaf has more.
Yard trees, because they are often injured by mowers, kids pounding nails, etc. will have more.
The amount does not vary by season, but it flows more in the spring.
The hotter the blade, the more is deposited on a blade.  Maybe try adding ice to the lube so that the lube cools.  It is the heat that expands the blade and makes wavy cuts.  So, I do wonder what adjustment needs more adjusting to avoid heating the blade.  The lack of clearance for the blade also promotes heating...we swage the teeth (sometimes called set) in order to cut a path wider than the blade itself.  We use different amount of swage in winter with "frozen" logs than the rest of the year.
Offline Woodpecker52
« Reply #5 on: April 10, 2019, 06:27:33 PM »
Diesel works, blue dawn and pinesol work.  Brushes mounted near wheel belts and you will never scrape another belt.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900
Offline Escavader
  • Sawmill/Planermill operator since1984
« Reply #6 on: April 10, 2019, 06:32:17 PM »
I use the windsheild washer the lt 15 calls for with good results .i moved my tank where i could reach it ,so i shut it off Fter each cut and give it a good trickle when its cutting.saw mostly green pine
Alan Bickford
Hammond lumber company/Yates American A20 planer with dbl profilers Newman feed table multiple saw trimmer destacker automatic stacking machine Baker resaw MS log corner machine  4 large capacity Nyles dehumidification kilns JCB 8000 lb forklifts woodmizer lt 15 and mp100 and blower
Offline woodweasel
« Reply #7 on: April 10, 2019, 09:14:17 PM »
woodpecker52,
   you have any pictures of the mounted brushes?
Offline John Bartley
  • Location: 13 Critchley Avenue, PO Box 36, Monteith Ont, P0K1P0
« Reply #8 on: April 10, 2019, 10:22:12 PM »
I have always used the same mixture :
5 gals of water / 1/3 cup any detergent / 1/3 cup any soluble machining oil, then mix well.  During freezing temps I dilute that mixture 50/50 with windshield washer fluid until that freezes, then I quit milling.
I always found that Pine (I sawed Eastern White and Red) is bad for pitch and waves.  The pitch is an issue, but I was able to get rid of waves (and the gumming got way less) by increasing the set on my bands to about 0.030" from the standard 0.021" that they come with.
cheers
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
Offline Florida boy
  • Young sawyer with my first mill
« Reply #9 on: April 10, 2019, 11:14:07 PM »
I had problems for a while till I started using one bottle of pinesol per tank. Also let the blade run between cuts helps to keep em clean. Also I've run dry or little lube at times too much lube can make it worst at times
« Reply #10 on: April 10, 2019, 11:23:49 PM »
wood weasel they are just shoe fine horsehair bristle brushes cut and glued. But I swear before them I had to clean belts after 2 logs but since putting them on I have cut over 200 logs and not scraped a belt yet.
Offline kelLOGg
« Reply #11 on: April 11, 2019, 06:06:33 AM »
I like that brush idea. I have crowned steel wheels but occasionally I get bits of sawdust on them which I don't think cause a problem but I would like them gone. I think I'll try it.
I got gummed up, too milling old heart pine year ago so I did this:
Anatomy of my double 2-sided blade oiler in Sawmills and Milling
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #12 on: April 11, 2019, 08:57:08 AM »
I saw a lot of EWP and I find the new blades need no lube. Once I start using resharpened blades I need lube, pinesol and water add the Windshield washer fluid for the winter. Some logs are worse than others, probably what I Gene says about the damaged trees.I do saw a lot of yard trees as that is my Target market. Recaliming those trees , they are taking down to build a new home/cottage here in Muskoka
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #13 on: April 11, 2019, 01:15:16 PM »
A good dose of Cotton Spindle Cleaner (water/oil emulsion) will oil a blade and generally keep it slick and clean.  Pine Sol (Pine Solvent) works good on pine, and I add some to my Spindle cleaner.
Diesel will work, also, but I only use it in extreme situations, because of the smell.  However, I like to dial the Lubemizer way back, to only get a couple or so shots of diesel per cut, so its not too bad.
If you want to see what works, run an experiment.  Get some pine sap on your hand and try to remove it using a variety of products, and what works will be what you could run in your tank.
HobbyHardwoodAlabama.com
Offline woodweasel
« Reply #14 on: April 20, 2019, 09:31:37 AM »
Woodpecker52
                      Thats a great ideal. Gonna try that.   THANKS 8) 8)
Offline Mt406
« Reply #15 on: April 20, 2019, 11:27:24 AM »
I cut 99% pine and fir.
I use diesel drip one drop every 5 seconds sometimes a little less.
I mounted a small gas tank off a mower shut valve to a needle valve to control flow rate then to copper pipe 1/8 I used hose clamps to hold to blade idler arm and a piece felt as wiper.
This works for my operations the bug killed pine has a lot of sap the first inch or two.
Blades come off clean and ready to sharpen. I have not had any complaints about any smell.
If you wanted some pics of the system I could post.
This is my two cents worth I know diesel is controversial subject.
Scott
Online thecfarm
« Reply #16 on: April 20, 2019, 01:28:19 PM »
Just sawing framing lumber the diesel drip and I said drip,once every 2-3-4 seconds should be fine.
The conflict comes from what some feel they need a steady stream,like water,to do the same job. And some sawmills manuals says not to use it. I was told to use it. :P But at only a slow drip, And I do mean slow and drip. Yes,with my manual mill there is a big difference in the amount of lumber I have sawed. Some of you guys saw in a day,what I do in a week. But I do the saw a little and build a little.
Offline esteadle
    • Steadwood Forest Products
« Reply #17 on: April 21, 2019, 10:16:36 PM »
My formula for pitchy-pine is lots of water and letting the blade "run" for 20 seconds after each cut.
Occasionally, I'll mix in a 1/2 cup of PineSol to 1 gallon of water, but I don't like to do this these days as the areated / misted Pine Sol seems to affect my breathing.
Agree with the earlier comment that new blades are better. Once some pits and scale develop on a blade, those pores seem to make the pitch stick better to it.
Also, as was also mentioned, some extra set on the blades helps to keep the lumber straight and true. I set my blades at .21 - .25 normally, but will push out to .30 or even .35 if I'm going to be cutting white pine or spruce early in the season.
Timber Harvester 30HT26 (setworks, hydraulic) Stihl 880 (36" bar).
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
« Reply #18 on: April 22, 2019, 09:28:10 AM »
I have been sawing a bit of white pine lately.
What works for me (manual mill) is to get setup for the cut.
Spin up the blade and using a squirt bottle apply a shot or 2 of diesel directly to the blade just before I enter the cut. That's all it takes. The blade and rollers stay clean and the blade doesn't get hot.
Now for all the sticky sap that gets on the handles of everything I use WD-40. Takes it right off.
Also I stopped using a tape measure on these logs and am using the old folding type. Again, clean up with WD-40. I made a mess of one tape measure.
On my hands, arms, face, wherever I get sap, and it gets everywhere! I use baby oil, it leaves my skin so soft and smooth. ;D
Imagine, Me a Tree Farmer.
Jon, Appalachian American Wannabe. ... and it looks like my dream will come true!
Is your bandblade gumming up?
Started by Tom on Sawmills and Milling
Last post February 02, 2002, 08:37:38 PM
by Tom
Milling a Big Pine
Started by kgbond on Sawmills and Milling
Last post June 11, 2014, 08:59:30 AM
by kgbond
milling pine
Started by mcarso1 on Sawmills and Milling
Last post March 11, 2009, 01:18:21 AM
by backwoods sawyer
Milling Pine
Started by JD350Cmark on Sawmills and Milling
Last post March 25, 2004, 08:18:29 PM
by Kirk_Allen
