Author Topic: Skidder cable ferrules.  (Read 1589 times)
Offline BargeMonkey
« on: April 12, 2019, 01:10:37 AM »
It's been talked about on here, I had to change a cable out the other day so I took a couple pictures, I'm a fan of using them and havent had a problem yet.
 I was using the grey ones with 3/4 swaged, went to 7/8 cable this time.
  Get it hand tight, hang it upside down and slap it with a decent sized hammer.
  Theres a whole lot of pain right there. 😂
Offline teakwood
  • Switzerland
Re: Skidder cable ferrules.
« Reply #1 on: April 12, 2019, 07:27:57 AM »
I use the pink ones for 1/2-5/8" cable.  i am also a fan of them, they are hands down the best solution for a cable end! and you can loose them with a small hammer in no time.
Offline ehp
  • logger/chainsaw hack
« Reply #2 on: April 12, 2019, 07:42:50 AM »
cable here already comes with the end on it , for my winch the end has to be the proper size to fit the place on the drum to hold itself . double swedge  cable here as well, you got to watch on how you hook your trees up and keep them set up in a straight line which is not to hard , very rare I get 3 trees on machine
Offline Ed_K
« Reply #3 on: April 12, 2019, 08:10:49 AM »
 I used the pink one but I used it on the drum side. I put the cable on in 08 and haven't had a problem yet.
Ed K
Offline logman81
« Reply #4 on: April 12, 2019, 08:26:29 AM »
Place I get mine from puts it on the end free of charge.
Precision Firewood & Logging
Offline sidehill6
« Reply #5 on: April 12, 2019, 11:36:07 AM »
*DanG, 7/8 cable and 9 sliders that will make a man out of somebody or killem in all that flat land east of Oneonta!!!
Online Old Greenhorn
« Reply #6 on: April 12, 2019, 12:20:20 PM »
I live east of Oneonta and ain't hardly nothin' flat here, but I suppose if you are 'just east' then there is some flatland.
Can You help out the Coleman Veterans Memorial by chipping in a few bucks? Go here for the full story: Can you help this year? in General Board
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
Online A-z farmer
« Reply #7 on: April 12, 2019, 01:14:04 PM »
Thank you for the information Bargemonkey
I just got a replacement cable for my wallenstein winch from the dealer for 550 with shipping .It is good to know there are options out there.
Zeke
Offline BargeMonkey
« Reply #8 on: April 12, 2019, 02:09:07 PM »
Zeke
 550 dollars US ? for small wire ? Did it come with dinner and a movie first? I want to say that cable was 350 ? 20 bucks for the ball.
Offline BargeMonkey
« Reply #9 on: April 12, 2019, 02:10:56 PM »
Lots of flat ground here. 9 sliders would destroy a weak man if your actually pulling cable 😂 unless it's big handcut stuff I'm getting bunched wood, 4-5 to a pile.
Offline sidehill6
« Reply #10 on: April 12, 2019, 03:17:49 PM »
Barge, when I was about your age I used to hand cut and help hook for the skidder operators, mostly 240 jacks and 518 cats. 3/4 swaged with six or seven sliders was more than enough working in the hills between Deposit and Worcester. end of day I wanted to roll over and play dead
Offline nativewolf
« Reply #11 on: April 12, 2019, 08:13:04 PM »
I thought you'd get  1/2 a tree  :D
Liking Walnut
Online A-z farmer
« Reply #12 on: April 12, 2019, 08:38:36 PM »
Barge
No dinner or movie just US dollars for half inch cable 165 feet long with one end already attached.
I am sure there is a lot of fingers in the pot from Canada to get to me on the farm.
Thank you
Zeke
Offline thecfarm
« Reply #13 on: April 12, 2019, 09:46:00 PM »
Labonville has inch cable much cheaper, @A-z farmer,  I only run 3/8 on my winch. 165 feet for about $160. I tried the inch on my Norse and it would not stay against the drum. Would make a mess. Went back to the smaller cable and much better.
Online A-z farmer
« Reply #14 on: April 13, 2019, 06:30:28 AM »
Thecfarm
I should have asked questions here first about a replacement cables.I think it was my operator error with the cable getting kinked up on the drum after only one season of use .Everyday is a learning experience and sometimes expensive.
Offline BurkettvilleBob
« Reply #15 on: April 18, 2019, 06:40:02 AM »
Thanks for posting this. I bought a nice pink one last time I was at Harolds, knowing that if I didnt my cable would break. Needless to say, I havent needed it yet.
Offline jdatwood
« Reply #16 on: April 21, 2019, 07:23:54 PM »
I use those as well. Ive tied a knot on the end in a pinch but really dont care for it unless absolutely needed to keep pulling wood. Used to keep a Morse Starett cable cutter in the box too but with cordless tools these days a 18volt Milwaukee 4-1/2 cut off saw seems to be the answer. I dont have even a quarter of the problems braking mainlines now with the ferrules on the end, knots really weaken the cable.
Cable skidder versus cable dozer
Started by killamplanes on Forestry and Logging
Last post November 15, 2016, 11:24:06 PM
by lynde37avery
moved
MOVED: Cable vs. Grapple/Cable Skidder
Last post November 30, 2005, 09:43:45 PM
by Jeff
question
Started by sticks on Forestry and Logging
Last post December 01, 2005, 05:31:49 PM
by timberjack240
Cat 508 Cable Skidder
Started by Mountain_d on Forestry and Logging
Last post October 17, 2016, 09:47:31 PM
by Mountain_d
