Author Topic: Spout your opinions one and all Off grid, no access property. Which mill?  (Read 1701 times)
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
A 6" swing mill will do that without much difficulty.  Once you get a cant cut 9" wide and however tall, you can double cut (cut from both sides) to get up to 12" boards.  Not as efficient as smaller dimensions, but can at least get multiples from a log that way.
On large logs, wanting the sizes you've mentioned, with minimal equipment, this is the way to go IMHO.
In the long run, you make your own luck good, bad, or indifferent. Loretta Lynn
Offline cwk266
Not a professional sawyer opinion a mobile dimensions sawmill is pretty handy.Breaks down really easy for boat transport,can be setup for mobile,stationary and or directly on the log if you have some monsters to play with.It can also be setup in different blade configurations to suite the desired product.Blade teeth can be sharpened easily and replaced quickly if needed which might be a big advantage over band saw blades especially is the logs are dirty.My use of the mill has been for my own needs around the farm cutting logs salvaged on site or locally also on the west coast.It is a handy universal tool I couldn't do without.Your needs for lumber will be more than just building the cabin.Good luck with project sounds fun
Offline Don P
    • Calculator Index
Quote
The beams I have planned are 3.5" x 9" x24'. That probably makes way more sense. If I mill fairly green wood for the rafters and try to keep it quartersawn material, will they still warp like heck? It would be topped off with 2" material as well on top, then roofed with Metal. No insulation and only wood heat when we are there for a couple weeks at a time, then they would be at outside temp. I was thinking that if it didn't dry out too quick and its all tied together it may remain stable. It is quite humid right out on the west coast. They would probably take years to dry without a kiln I'm guessing. Thanks for the insights! Keep em coming, I'm as green as a bamboo shoot.
Quartersawn has the most crook, flatsawn the most bow. You can correct bow in the 1.5" direction, not so with crook in the wide dimension. A 24' rafter 9" deep, I've got doubts, check the awc.org span calc., the WSDD manual there or the beam calcs in the toolbox here.
Bar oil jug spout
Started by husky2100 on Chainsaws
Last post March 13, 2014, 08:43:09 AM
by husky2100
Fuel Spout
Started by Bill Gaiche on General Board
Last post January 29, 2014, 10:39:54 PM
by mudhog
Purchased property, cut down trees, starting a mill lol
Started by cedartimbers on Forestry and Logging
Last post May 20, 2015, 09:13:12 PM
by KiwiBro
Looking for Opinions on Hud-Son Oscar 18 saw mill
Started by tomb on Sawmills and Milling
Last post September 09, 2010, 07:48:21 AM
by badpenny
