Author Topic: Drag back  (Read 1242 times)
Offline Bruno of NH
Drag back
« on: April 20, 2019, 09:47:45 AM »
Is there a drag back option for my new lt40 wide I have on order?
If so does anyone have one?
Your input please
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,Mahindra 3540 cab tractor loader F350 4x4 dump and lot of contracting tools
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Drag back
« Reply #1 on: April 20, 2019, 01:25:41 PM »
I don't see a board dragback option listed for the standard LT40HD:  LINK
Probably has to do with the size of the power feed motor.  ???
Offline Bandmill Bandit
Re: Drag back
« Reply #2 on: April 20, 2019, 02:38:54 PM »
I put a manual board return on my LT40 and then changed to the LT40 Super feed drive about 2  weeks later. The small motor on the standard Hydraulic will die very quickly using the board return. It just DOESNT have the torgue to do the job.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2001 Dodge 1500 4x4. 2018 F150
2007 Woodmizer LT40HDG28 almost Super
2 Logrite 36 inch cant hooks and a bunch of stuff I built myself
Offline 123maxbars
    • www.outofthewoodsforestry.com
Re: Drag back
« Reply #3 on: April 20, 2019, 03:11:15 PM »
My 40 Wide I recently ordered should be ready first of May, the drag back was an option that I included around $550
Sawyer/Woodworker/Timber Harvester
W/M LT40HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Offline Bruno of NH
Re: Drag back
« Reply #4 on: April 20, 2019, 03:43:46 PM »
Nathan,
Did you get a super?
Mine on order is the Lt40 wide,38hp gas,debarker, and command controls .
I would like a drag back if it an option.
Bruno
Offline Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
Re: Drag back
« Reply #5 on: April 20, 2019, 04:01:46 PM »
I added the manual board return to mine, but was on a job with big logs cutting 1x12ís. Thatís when I discovered that I couldnít make a 12Ē deep cut with it on, so I removed it. Iíll be cutting a bunch of 1x8 siding in the near future and will probably put it back on. Sounds like I may need to upgrade my feed motor first though.
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Drag back
« Reply #6 on: April 20, 2019, 05:05:06 PM »
My LT40 non super dragback lasted  several years and was working when I sold it. Woodmizer told me they had changed or upgraded or something most of the motors on the mill throughout the years to increase life and I assumed that was one of them but donít know.  I have a bad hip and figured Iíd rather have the motor die than me, but it kept on running.  I certainly didnít drag back cross ties or stuff like that, only lumber.
I did pop my breaker occasionally but when it did I would reset it, clear that board by hand and get back to it. Never burned out the breaker or the motor.  The breaker protected the motor seemingly quite well.
The video of me dragging red oak boards I made a few years ago was made with the same motor I sold the mill with.  I used my dragback shoe and it will also drag back and carry the board across the roller table.
HobbyHardwoodAlabama.com
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Drag back
« Reply #7 on: April 20, 2019, 05:46:46 PM »
I removed the board dragback soon after I bought my sawmill.  It didn't work well with portable sawing plus dealing with that extra table.  My main issue was the encroachment of the throat height above the sawmill blade.  For my operation I have never seen the need for it nor regretted removing it.
Offline Bruno of NH
Re: Drag back
« Reply #8 on: April 20, 2019, 06:46:36 PM »
I was thinking just for boards not like 6x6 or anything like that.
Offline Bruno of NH
Re: Drag back
« Reply #9 on: April 20, 2019, 06:51:50 PM »
Also I have been trying to walk without my walker.
Little steps each day.
The last 3 days over 15 to 20 ft each day.
It doesn't seem like much to most but to me it was a great feeling.
2 of those days I got in and out of the tractor.
Driving the tractor has been one of the most painful things for some reason.
Offline Chuck White
  • Sawing Mobile since 2005
Re: Drag back
« Reply #10 on: April 20, 2019, 07:15:18 PM »
Once in a while I will drag a few boards back with the blade itself!
If you elect to do that, just make sure that you disengage the blade first or it will come off of the blade wheels!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Hilltop366
Re: Drag back
« Reply #11 on: April 20, 2019, 07:24:42 PM »
I find tractor cabs are awkward to get in and out of at the best of times, with a small entrance at your feet you kind of got to side shuffle and back in there and then the steering wheel is in the way. All from a tiny step(s) that are too high off the ground.
So it got me to wondering if it would help if you made a dock with a ramp and hand rail that you could park the tractor next to to help getting in and out of the tractor.
Offline btulloh
Re: Drag back
« Reply #12 on: April 20, 2019, 07:45:31 PM »
Good report Bruno and good progress.  Keep after it and enjoy the small victories.  Over time they add up.
It seems like tractors require quite a bit of ballet training. I've noticed that it gets harder as the age increases.  That's my take on it.  Some of the new stuff has more room on the platform, and the transmission tunnel is lower.  None of my tractors have any of that though.  Mine get more cramped and all the non-skid surfaces seem like the zamboni came by a slicked 'em up real good.
Stay safe.
HM126
Re: Drag back
« Reply #13 on: April 20, 2019, 08:59:59 PM »
The above picture of the mod to the board return arm is a significant reduction in load to the motor because the the majority weight of the lumber is supported by the mill head which transfers that to the roller suspension system that the head rides on.
When doing larger dimensions I raise the roller toe boards and lift the far end with my modified drag back arm to pull back the lumber. I actually have to be careful NOT to send it hurdling off the end of the scramble table as it comes off the mill.
If you have a good roller s et up and the lip to lift the lumber you will probably be just fine with the standard drive motor.
Offline Southside
Re: Drag back
« Reply #14 on: April 20, 2019, 09:14:57 PM »
Bruno - that's great news!!  In order to see the actual progress you have to look back to when you could not take those steps and realize that you are getting better and stronger.  I have personally walked in those shoes twice and know how frustrating it is.  Had an older friend who would come by and give me a hard time because my walker didn't have the fancy hand brake and tennis balls on the bottom.  He was just trying to keep my spirits up.  Just keep pushing ahead, make it through the next one second and repeat, that's all you need to do and you will put time and distance behind you.
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
Re: Drag back
« Reply #15 on: April 20, 2019, 10:19:08 PM »
Seems like a lot of equipment (tractors, skid steers, forklifts) were designed for operators who are 5'10", 165 pounds, with size 8 feet.  At 6'3", 250 and size 13, a lot of things don't fit... and that was before I got old.  :)
07 Timberking B-20, Custom-made log arch, 20' trailer w/ log loading arch, F350 SD flatbed dump.  Princeton piggy-back forklift.  Bobcat S250, Stihl 025C 16" and a Husqvarna 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says "He's sawin logs", I ain't snorin'.
Offline RichTired
Re: Drag back
« Reply #16 on: April 21, 2019, 10:20:55 AM »
They may be using the same design handbook used for airplane seats. :D
Wood-Mizer LT15GO, Kubota L2800, Husqvarna 268 chainsaw, Logrite cant hook, Ford F-150 Fx4
Richard
Offline luap
  • Not as good as I once was
Re: Drag back
« Reply #17 on: April 21, 2019, 10:45:24 AM »
Keep looking forward. I want to encourage you by my experience. two months ago I lost my ability to balance, the use of my left side and needless to say could not walk due to swelling-water on the brain. After treatments  which are still ongoing and therapy I am now walking again. Balance not totally back but getting there. I thought I was headed to long term care and came back from the edge. I identify with you where you are at.
Offline 123maxbars
Re: Drag back
« Reply #18 on: April 21, 2019, 01:04:00 PM »
Nathan,
Bruno
I did not get the super,
mine is exactly like yours except I got the drag back and also the Diesel instead of gas,
outofthewoods
Youtube page
Out of the
Offline Bruno of NH
Re: Drag back
« Reply #19 on: April 21, 2019, 01:30:37 PM »
Nathan,
Bruno
Great can't wait for mine.
Looking forward for a movie of yours.
I'm also getting an edger
the back drag got me!
Started by Tom L on Sawmills and Milling
Last post October 05, 2011, 06:22:20 PM
by Chuck White
Drag-back mod for LT28
Started by WoodenHead on Sawmills and Milling
Last post November 30, 2012, 07:58:00 AM
by bandmiller2
Drag Back LTAGA to CBN
Started by quadracutter222 on Sawmills and Milling
Last post January 24, 2019, 11:55:32 PM
by donbj
Drag-back Flavors
Started by Rougespear on Sawmills and Milling
Last post November 27, 2016, 11:23:27 PM
by Brucer
