Author Topic: Drag back  (Read 1232 times)
Offline 123maxbars
    • www.outofthewoodsforestry.com
Re: Drag back
« Reply #20 on: April 21, 2019, 03:33:32 PM »
Mine is suppose to be ready on May 6, I also got the lube mizer, Fine adjustment outriggers and the high performance blade guides, WM told me I got every option for this mill but the laser.
An edger might be in my future but I need a planer now so I got that coming instead.
when is yours ready?
Sawyer/Woodworker/Timber Harvester
W/M LT40HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Offline 123maxbars
Re: Drag back
« Reply #21 on: April 21, 2019, 03:46:45 PM »
@Bruno of NH sounds like you have a great mill headed your way, I would reach out to WM on the drag back, they told me it was a standard option on the 40s now. I went with the gas initially but @YellowHammer suggested the diesel since the majority of what I cut is wide live edge slabs currently and I could use the extra torque on making the wide cuts.
outofthewoods
Youtube page
Out of the
Offline Bruno of NH
Re: Drag back
« Reply #22 on: April 21, 2019, 04:09:27 PM »
Some time in June 8)
The edger comes in May 8)
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,Mahindra 3540 cab tractor loader F350 4x4 dump and lot of contracting tools
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Drag back
« Reply #23 on: April 21, 2019, 08:29:53 PM »
I'm glad you guys are getting your mills, I think each will be really good for your operations.
The drag back modification I came up with many years ago is such an integral part of sawing efficiently, I am trying to figure out how I'm going to incorporate it on my 70.  It will lift and carry a board and virtually remove the load on your head motors and allow you to put the board anywhere you want it.
Here are a few links where I documented the design and improvements over the years.
Useful sawmill mods in Sawmills and Milling
HobbyHardwoodAlabama.com
Offline Southside
Re: Drag back
« Reply #24 on: April 21, 2019, 09:29:52 PM »
Hammer -
Have you seen how Jake worked the same idea into his 70?  He told me the bottom fingers were a bit too long, but otherwise it worked well.
the back drag got me!
Started by Tom L on Sawmills and Milling
Last post October 05, 2011, 06:22:20 PM
by Chuck White
Drag-back Flavors
Started by Rougespear on Sawmills and Milling
Last post November 27, 2016, 11:23:27 PM
by Brucer
question
Drag back questions
Started by Larry on Sawmills and Milling
Last post September 25, 2010, 10:51:19 AM
by Banjo picker
Drag back arm motor
Started by Waterford Woodworks on Sawmills and Milling
Last post January 06, 2015, 12:07:09 AM
by YellowHammer
