Author Topic: D4 Caterpillar identification  (Read 680 times)
Offline Pete_Jul
  • Member*
« on: April 23, 2019, 11:51:14 PM »
Hi from Australia.
Ive just bought a 1956 d4 crawler.
I cant find the serial numbers anywhere.
Was told around engine bay or seat area.
Was told by seller that its a 56 d46u.
any help on location of vital numbers much appreciated.
tks peter
Offline Riwaka
Re: D4 Caterpillar identification
« Reply #1 on: April 24, 2019, 12:05:01 AM »
Some have serial numbers under the seat, rear left of the engine etc. Unless ground off
This has some D4 numbers
Caterillar D4-7U series bulldozer
Offline Al_Smith
« Reply #2 on: April 24, 2019, 04:38:19 AM »
4G-7J-2T-5T-6U-7U < oldest to newest .It's either on the engine or rear end of the machine .I've got a 2T and a 5T and a 7J .It should be a metal plate
Offline krusty
« Reply #3 on: April 25, 2019, 09:42:49 PM »
I have a recently acquired 7u, 56 I believe. Check out http://www.acmoc.org/bb/forumdisplay.php?4-DISCUSSION as there is invaluable info there.
My tag is on the left side of the engine, to the right of the injector pump. Was covered in dirl/oil when I got it.
Offline Al_Smith
« Reply #4 on: April 26, 2019, 09:48:22 AM »
It's interesting on some of these old machines knowing the year of manufacture .For example my 2T-31 is 1943 .It has cast iron or steel in place of brass because of WW2 .It 's got a galvanized steel radiator core instead of copper like the later 5T model which is 1946 .One thing about old Caterpillars ,you can keep them running forever if you are willing to turn a wrench and track down parts .The old D4's aren't the most powerful in terms of a modern 5 ton unit but they will still do a days  work if you know how to operate them.Anybody can operate say a JD 450 with a tilt angle blade ,try it some time with a straight blade and slow hydraulics .That separates the men from the boys . 8)
Caterpillar 518
Started by David-L on Forestry and Logging
Last post February 12, 2018, 06:19:50 AM
by coxy
Caterpillar
Started by Mooseherder on The Outdoor Board
Last post July 19, 2010, 06:43:45 PM
by Mooseherder
Caterpillar 225 and 528
Started by ephnyb on Forestry and Logging
Last post April 03, 2011, 01:06:02 PM
by lumberjack48
D4 caterpillar
Started by Thefarmer76 on Forestry and Logging
Last post January 19, 2017, 07:29:44 PM
by Thefarmer76
