Author Topic: Pine tree milling  (Read 412 times)
Offline asm9296
Pine tree milling
« on: May 19, 2019, 03:59:21 PM »
How long can a pine tree sit after cutting before milling?  Loblolly pine.   Bark left on.
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Pine tree milling
« Reply #1 on: May 19, 2019, 04:24:01 PM »
   I am sure it varies but around here we mostly have white pine and in the warmer months after a few months you are getting seriously at risk for pine borer beetles that will cut about 3/8" holes in the wood. As I understand if you can debark them that greatly reduces the risk. I bought spud with about a 4" wide head and a sturdy 5' handle at HF I plan to use for stripping bark off my logs. I have not used it enough to verify how well it will work yet.
Offline Lawg Dawg
  • True South Sawmill Lumber
« Reply #2 on: May 19, 2019, 04:41:46 PM »
Better hurry up and saw it, trust me
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
 John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: May 19, 2019, 04:56:12 PM »
Note:  Adding your location to your profile greatly helps with answering questions.  :P
In my location, during the Winter, 2-3 months is generally OK.  Summer, within a month is best.  As LD eluded to above, the log starts degrading the instant that it hits the ground.
Offline richhiway
  • Rich
« Reply #4 on: May 19, 2019, 07:48:53 PM »
It depends. I have cut pine that was two years old that was good without pine borers. Other times they start chewing up the wood right away,you can hear them.They only start when it is above freezing so you will be safe in cold weather. If you want some pine with "character" you let it sit for a few years,it will get blue stain and the borers will chew all those pretty holes!
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: May 19, 2019, 08:06:12 PM »
@asm9296 said "Loblolly" which puts him somewhere in the South.  Not much cold to prevent borers.
Online Southside
« Reply #6 on: May 19, 2019, 09:00:52 PM »
Yup, and with the furnace just turning on they will begin to stain quicker and spoil faster. Ironically white pine lasts longer on the ground than loblolly.
Can you save a pine tree once pine beetles get into it?
Started by scsmith42 on Ask The Forester
Last post September 02, 2015, 10:17:55 AM
by mesquite buckeye
milling pine
Started by mcarso1 on Sawmills and Milling
Last post March 11, 2009, 01:18:21 AM
by backwoods sawyer
Milling a Big Pine
Started by kgbond on Sawmills and Milling
Last post June 11, 2014, 08:59:30 AM
by kgbond
Milling Pine
Started by JD350Cmark on Sawmills and Milling
Last post March 25, 2004, 08:18:29 PM
by Kirk_Allen
