Author Topic: Full size Bronco  (Read 2022 times)
Offline sprucebunny
  • Gender: Female
Full size Bronco
« on: October 30, 2005, 08:34:55 AM »
With 351 auto.
Have one that burned. I want either a parts truck with good engine and dashboard or an inspectable runner.
The better shape it's in, the further I'll travel to get it.
Also interested in an F250 4x4 extra cab diesel.Don't want crew cab. 97 or older in good shape.
Offline DonE911
  • givme a minute, I'll think of something
Re: Full size Bronco
« Reply #1 on: October 31, 2005, 03:58:36 PM »
I have a 77 f150 4x4 hiboy sitting down in FL....  dash is okay,  no engine/ c6 trani. but could use a rebuild.   Hurricane took the top layer of the roof off.   Not worth traveling for.
What year is the bronco you have??  351m or 351w ?? diff blocks and trani's...  there is a mid 80's for sale locally that has been rolled.... didn't look to close at it, but I bet the inisde is okay... and prolly still runs.
Offline sprucebunny
  • Gender: Female
« Reply #2 on: October 31, 2005, 09:34:13 PM »
Thanks, Don. It's an 88 but I don't know which letter.
I've talked with someone in NH about the parts. I'd be more interested in a whole good one from Georgia as there is a good chance it would have less rust than one from here. But I would need to get the same year as the point of this is to use the plow and brand new front end parts that cost $1600 ::)
Offline DonE911
« Reply #3 on: November 01, 2005, 07:47:31 AM »
If its an 88 model you have a 351W (windsor) ...  you can rebuild that engine cheap... or just buy a rebuilt from AutoZone or something.   You could do away with all the computer stuff also, but I don't know if you have to pass a vehicle inspection up there or not..... DMV's tend to frown on getting rid of fuel injection and going back to a carb for smog reasons.
Offline sprucebunny
  • Gender: Female
« Reply #4 on: November 01, 2005, 08:09:05 AM »
The engine was still running when the fire went out because I smothered it with snow. The engine isn't the problem....it's all the other stuff that's melted like the heater and wires.
I'll look into putting a carb on it. Thanks
Offline rebocardo
  • Atlanta GA
« Reply #5 on: November 02, 2005, 11:38:59 PM »
You can buy decent rust free full sized 80s/90s 4x4 Broncos (though 2x4 are more common) for $1200-$2000. Look at www.ajc.com (friday,sat,sun) and the Atlanta Advertiser http://atlantaadvertiser.traderpub.com. Very rare to find them at www.pullapart.com.
Most come with the 351w/C-6 combo for the 80s style. Mostly Duraspark so you can easly rewire the whole thing or go carb/vac. dist. with points if you have to. Though when I lived in NH I had emissons testing.
Offline sprucebunny
  • Gender: Female
« Reply #6 on: November 03, 2005, 05:29:07 AM »
Thanks for the links, rebocardo.
I didn't find the right thing today but I'll check again this weekend.
They have started emmision testing again but only on '97 and newer that have the computer plug in port  :-\
Offline rebocardo
  • Atlanta GA
« Reply #7 on: November 04, 2005, 07:24:46 PM »
Many times you will find Broncos on the used car dealer lots and they are not advertised. I turned down one guy when I wanted one (he was $1800 and I was $1400) and it ended up selling for $1200.00 later in the AJC.
Offline Out On A Limb
« Reply #8 on: November 18, 2005, 07:12:54 AM »
SpruceBunny,
I've got a 1995 Bronco with about 220,000 miles....purrs like a kitten!  Everything (except for the rear-end) is original.  I parked it on some property I have in northern Michigan; it just sits there waiting for me to come visit.
34' Long Red Oak Log - Any value full size?
Started by eashworth64 on Forestry and Logging
Last post April 30, 2013, 09:48:30 PM
by mesquite buckeye
Used Full Size SUV Opinions
Started by barbender on General Board
Last post April 23, 2017, 11:56:55 PM
by barbender
moved
MOVED: First full size BSM: choosing between Logosol B751 and Woodmizer LT15
Started by Roxie on Sawmills and Milling
Last post September 12, 2018, 12:32:30 PM
by Roxie
Pats/Bronco's Game
Started by Roger2561 on General Board
Last post November 27, 2013, 04:01:06 PM
by jd2007
