Author Topic: Outdoor Bridge and Camp Construction  (Read 2019 times)
Offline Stan P
  • A bad day in the woods is better than a good day at work.
« on: November 14, 2005, 06:46:49 AM »
Hello All,
  I recently bought a woodlot in CT, primarily to hunt and camp with the kids.  The previous owner had built 3 bridges over small creeks.  He used small steel ibeams with wood across the top.  It looks like he used the wrong wood, since after just 15 years it is so rotted out there is almost nothing left.
  I want to resurface the bridges and have heard that black locust would be best, but I have lots of white pine, hemlock and red oak.  Could any of those work?
  I want to build a small camp next summer.  A simple one room structure totally off the grid with plank exterior and was wondering if any of you would have ideas or know where I could find ideas for design.
thanks
Stan
Offline HARLEYRIDER
    • game cam
Re: Outdoor Bridge and Camp Construction
« Reply #1 on: November 14, 2005, 07:42:25 AM »
I'd say hemlock for your bridges, and white pine for your log cabin
Greenwoods Timberworks
Offline TN_man
  • Building my house and cutting part time
« Reply #2 on: November 14, 2005, 08:20:52 AM »
If you have any white oak, I would use that for the bridges, definitely not the red oak.
The white pine would be great for the cabin.
WM LT-20 solar-kiln Case 885 4x4 w/ front end loader  80 acre farm  little time or money
Offline ARKANSAWYER
  • Poor white Southern trash
« Reply #3 on: November 14, 2005, 01:11:02 PM »
   I would look for some black locust or walnut.  Do not know anything about hemlock but the others will not last long.
ARKANSAWYER
Offline mark davidson
  • from ontario, canada
    • whippletree post and beam
« Reply #4 on: November 14, 2005, 05:24:59 PM »
I use hemlock for exterior, almost as good as cedar. and strong. makes good deck framing instead of the pressure treated stuff.
Offline Stan P
« Reply #5 on: November 18, 2005, 02:46:31 PM »
Several of you have suggested black locust would be best for the bridge.  I think I finally found a guy who can cut me some in CT. Will that shrink much when it dries?  How long should I dry it before attaching to the beams.  Obviously if it shrinks a lot, can't put it up wet.
thanks
Offline raycon
« Reply #6 on: November 18, 2005, 03:02:32 PM »
I have 20 or 30 black locust logs if your other source is short logs/boards.
Black Locust has minimal shrinkage for a hardwood. Less than white oak. I don't have the #'s in front of me at the moment.
 If you think about using Hemlock and it may have to carry a load make sure its clear (minimal knots) and structurally sound( no shake).
Lot of stuff..
Bridge Construction
Started by KyLogger on Forestry and Logging
Last post September 15, 2012, 10:02:04 AM
by Sixacresand
covered bridge construction?
Started by hackberry jake on Timber Framing/Log construction
Last post November 05, 2011, 10:40:58 AM
by jdtuttle
moved
MOVED: covered bridge construction?
Started by Jeff on Sawmills and Milling
Last post November 04, 2011, 12:59:17 PM
by Jeff
Small temporary bridge - timber or log construction?
Started by ChugiakTinkerer on Timber Framing/Log construction
Last post May 14, 2018, 12:16:58 PM
by ChugiakTinkerer
