Author Topic: CHERRY FIGURED GUNSTOCK BLANK "WANTED"  (Read 5698 times)
Offline 333_okh
  • Got Wood
« on: December 31, 2005, 03:16:49 PM »
This little search I have been conducting on the Internet is killing me.
I want a dry black cherry blank from the eastern US to be made into a rifle stock.  The blanks needs to be 8 inches on the wide end, 3 inches on the small end, 34-37 inches long and 2 1/2 -3+ inches thick.  These are minimum specs. I want as much figure as I can find, especially in the BUTT AREA (WIDE END) OF THE BLANK.
Can anyone help point me towards a dealer.  The blank needs to be dry and aged would be preferred.  The below image gives you an idea of the shape of the blank needed in case my specs were confusing.
Offline Mtnjack
  • Bear Hunter
Re: CHERRY FIGURED GUNSTOCK BLANK "WANTED"
« Reply #1 on: December 31, 2005, 11:51:16 PM »
Try gunstockblank.com they go under the name Tiger Hunt and have figured cherry like you want.  Mtn Jack
Offline 333_okh
  • Got Wood
« Reply #2 on: January 01, 2006, 12:43:02 AM »
I have contact him and I am awaiting his information on my request.
Anymore people???? I have also contacted Dunlap Woodcraft, but they are out of figured peices this thick, as is Curly Woods.
Offline Ironwood
    • http://www.branchandburl.com
« Reply #3 on: January 01, 2006, 06:59:13 AM »
That'll be a tough one. I have figure cherry but only up to 2-2.25" It kills me to slice the good stuff that thick. Reid
Kirk_Allen
  • Guest
« Reply #4 on: January 01, 2006, 09:56:33 AM »
I will check my stash today and let you know.  I commonly cut cherry to 12/4 but I think Curlywoods bought all I had dried a few months ago.
Offline 333_okh
  • Got Wood
« Reply #5 on: January 01, 2006, 01:16:31 PM »
I think Tiger-Hunt is coming through with wood, but I needed to keep my options open.  I really am looking for high grade cherry such as this:
NOTE FROM ADMIN.
photos posted on the forestry forum must use the forum gallery.
I am not necessarily looking for crotch figure, but I will not turn down a solid piece.  The one thing about Dunlap and Tiger-Hunt that I am interested in, and hoping they can find my wood, is that they guarantee the wood against defect internally.  If an internal flaw or check exists they will replace the blank.
Offline 333_okh
  • Got Wood
« Reply #6 on: January 03, 2006, 12:34:33 AM »
Offline thedeeredude
  • RufusRuffcut and Sawtooth to da races!
Offline 333_okh
  • Got Wood
« Reply #8 on: January 03, 2006, 10:48:28 PM »
I will give them a try.  Most of thier wood appears to be muzzleloader size which will not work for my project.
Offline weimedog
  • Better to be a "Has Been" than a "Never Been"!
« Reply #9 on: January 07, 2006, 08:30:14 AM »
I have at least 3 miles of hedge rowes full of Cherry trees. Most over 15inches in Diameter, some
actually very large. They are not very tall. Might get one log before they branch out. My bet
is they are not the best quality for the loggers to bother with...what about things like gun stocks?
Bet there is plenty of "figure" Is it worth taking one down to see whats inside? Any local in the
CNY area who would understand to best approach to dealing with these old cherries?
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
Offline 333_okh
  • Got Wood
« Reply #10 on: January 07, 2006, 01:05:24 PM »
That actually sounds like the wood most of the guys do cut for stocks.  It isnt the true straight tree it is the wrinkled barked tree with swelling stumps.
Offline weimedog
« Reply #11 on: January 08, 2006, 03:01:15 PM »
If you want I can cut one down & slice it up (When the WEATHER permits!!). Email me.
Offline just_sawing
  • Making Split Rails Shingles and Sawing
« Reply #12 on: January 12, 2006, 08:02:59 PM »
I have some 150 year old Curry Cherry that I am Processing if you interested. It will be dry Kiln.
You can follow me at
www.http://haneyfamilysawmill.com
Offline 333_okh
  • Got Wood
« Reply #13 on: January 12, 2006, 09:20:13 PM »
I might be.  I really depends on the figure.  I need a blank that is layed out for the grain structure flow through the stock of the rifle and also having as much figure as I can possible find in cherry.  It is the Holy search.  If you can post pictures when you have some.  the problem is they tell me less than 1% of the logs have what I am looking for.
Offline just_sawing
« Reply #14 on: January 22, 2006, 08:50:58 AM »
I am stii trying to get my photo's at low enough resolution to post on the forum. but if you will send me a E-mail at my home e-mail Just_sawing@highstream.net I will send pic directly. I have photoshop aand have cropped and dropped my resolution but still have problems.
Roy
Online Furby
  • Blurb....
« Reply #15 on: January 22, 2006, 12:17:55 PM »
http://www.forestryforum.com/board/index.php?topic=12416.0
You really need some compression software as well.
The xat link is a FREE download! ;)
Offline maple flats
  • Life is what you make it!
« Reply #16 on: January 23, 2006, 08:21:11 PM »
I have some that I cut last summer and stickered. Cut at 2.75 thick x random widths, not yet cut into blanks. Will not be ready til at least Aug, was over 10 yrs in log before sawing into blank stock thickness. If you have not found any before then I will check figure as I unstack the pile.
Offline 333_okh
  • Got Wood
« Reply #17 on: January 29, 2006, 01:06:24 AM »
Maple flats....good to know....I am starting to lean towards maple instead of cherry for my gunstock.
Wanted: 3"x3"x0.25" square tubing 36" long
Started by Dan_Shade on Wanted
Last post November 02, 2006, 04:48:35 PM
by Gary_B
Maple - is this "figured" or something else
Started by landscraper on General Woodworking
Last post January 22, 2016, 08:00:23 AM
by sandsawmill14
Wanted 2"to3" (OD) Pipe or Drill Stem for use in building cattle corrals
Started by fishpharmer on Wanted
Last post May 09, 2009, 12:17:33 AM
by sjfarkas
question
Ginkgo wood wanted! Log of limb or ??? @ 3" dia x 6" long. For comparison
Started by krislynn on Tree, Plant and Wood I.D.
Last post March 15, 2010, 10:41:51 PM
by fishpharmer
