Author Topic: E-Classic Re-lighting issue solved  (Read 1773 times)
Offline antos_ketcham
« on: August 22, 2008, 04:11:19 PM »
Hey all -
I solved the issue of my E-Classic 2300 wood only model having the fire die out while I am trying to just heat my DHW. I talked to CB and the solution is to put a paperclip in the upper solenoid (primary air) so it can't close completely. This allows enough air in to keep the fire going.
Pete
Offline ADAMINMO
  • Today is gonna be another one of those days!!
Re: E-Classic Re-lighting issue solved
« Reply #1 on: August 22, 2008, 04:26:52 PM »
Sounds like a redneck fix to me and there is still a problem. You shouldn't have to do that. They should supply a better fix than " stick a paper clip in it" . If you are happy with it that is all that counts. I for one would not be happy with that answer. They would be out there to fix it the right way on their dime.Just my $ .02 .ADAMINMO
« Reply #2 on: August 22, 2008, 04:30:38 PM »
I don't disagree. My sense is that they have heard this from a few folks and a better more permanent solution is on the way. I intend to keep after them on that.
Pete
E-Classic Issue
Started by Cass007 on Firewood and Wood Heating
Last post March 02, 2015, 05:51:43 PM
by garret
Classic issue
Started by petefrom bearswamp on Firewood and Wood Heating
Last post December 18, 2017, 11:06:10 AM
E Classic 2400 air flow issue?
Started by VTwoodburning on Firewood and Wood Heating
Last post November 17, 2014, 01:50:45 PM
by VTwoodburning
E-Classic 2400 Issue Revisitied
Last post March 16, 2015, 08:26:14 PM
by garret
