Author Topic: ThermoPex Help!?!?  (Read 3057 times)
Offline stumper
ThermoPex Help!?!?
« on: October 25, 2008, 08:44:20 AM »
How do you clean off the insulation from the pex pipe in the thermopex outdoor wood boiler piping?
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
Re: ThermoPex Help!?!?
« Reply #1 on: October 25, 2008, 09:42:07 AM »
Cut the outer layer with a good sharp knife back the distance you need from the end. You could even work around it with a backsaw as that outer layer is quite tough. Peel that off then simply break the insulation away from the exposed PEX tubing.  We used a utility knife.
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #2 on: November 08, 2008, 09:57:50 PM »
Like Jeff said, use a hand saw to cut the outer jacket and peal it off.   I then used a large machete like knife to cut the insulation away and then used it to scrape off the inner pipes.
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Offline okmulch
« Reply #3 on: November 09, 2008, 05:13:36 PM »
hey I am glad stumper asked that question. I am going to be getting my thermopex in a couple of weeks and now I know how to clean the insulation off.
Rotochopper b66 track, woodmizer lt40, CAT 277b, CAT 268b, CAT 287c, CAT 277c, CAT299d2
Can I run Thermopex like this?
Started by LegendsCreekFarm on Firewood and Wood Heating
Last post February 23, 2016, 06:27:07 AM
by DR_Buck
thermopex
Started by jerry sundberg on Firewood and Wood Heating
Last post April 18, 2019, 02:54:24 PM
by thecfarm
Classic edge 750 thermopex exit plaement
Started by Logging logginglogging on Firewood and Wood Heating
Last post June 02, 2017, 03:36:03 PM
Just bought Central Boiler 6048 - Thermopex Alternative?
Last post January 09, 2016, 06:30:07 AM
by coxy
