Author Topic: Central Boiler 'Auto' Night Lite  (Read 1805 times)
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« on: November 15, 2008, 09:51:41 AM »
Anyone have an explanation on how the 'auto' light function on the Central Boiler units is supposed to work.   Information in the manual is kind of sparse.
On my unit, the 'ON'  position turns on both the front and side lights.   I understand this is correct.    The 'AUTO' position only effects the front light and not the side.  This is also correct.  The issue on my unit is in 'AUTO' the light comes on and stays on after dark.  I was led to believe that it was supposed to be activated with a motion sensor after dark and would go off after some time of no motion.  Is this correct and mine is not working correct, or is it just a day - night sensor?    If so, this is kind of counter to the saving energy idea.
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40 Super- Wide HDG38
Lucas Dedicated 60" Slabber
Offline beenthere
Re: Central Boiler 'Auto' Night Lite
« Reply #1 on: November 15, 2008, 10:51:31 AM »
Might be it functions like a regular motion detector light.
Offline Jim H
« Reply #2 on: November 15, 2008, 03:15:14 PM »
The light is a dusk to dawn light controlled by  a sensor near the temperature display
2008 LT40HDG28, autoclutch, debarker, stihl 026, 046, ms460 bow, 066, JD 2350 4wd w/245 loader, sawing since '94 fulltime since '98
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #3 on: November 15, 2008, 04:27:53 PM »
That's kind of what I thought it was.  :(       Looks like I'm going to have to change out the sensor, or add a motion detector to the circuit.    I'd like the light to come on if I approach the unit when it is dark.  smiley_lit_bulb  Then have it go off by it's self after I am done loading wood and walk away.    I have a light on the front of my shed that works that way.
Hidden Acres Farm
Offline stumper
« Reply #4 on: November 15, 2008, 04:54:54 PM »
I was actually considering removing the lens and bulb from the front one and installing a twins spot light set up.  Hopefully being able to aim one spot down and into the box and the other out toward my wood pile.  Has anybody tried that?
Anyone with a new Central boiler Classic Edge Titanium series boiler yet?
Started by Logging logginglogging on Firewood and Wood Heating
Last post June 02, 2019, 04:32:03 PM
by WI Fire
Done with Central Boiler ...Boiler recomendations please
Last post January 29, 2019, 07:52:18 PM
by 1countryboy
Central boiler fan
Started by talldog on Firewood and Wood Heating
Last post March 03, 2013, 05:15:44 PM
by hockeyguy
central boiler
Started by coxy on Firewood and Wood Heating
Last post February 05, 2013, 05:09:32 AM
by albirk
