Author Topic: water heating with woodstove  (Read 11469 times)
Offline John Mc
Re: water heating with woodstove
« Reply #20 on: September 28, 2010, 09:36:28 PM »
isn't extracting as much heat as possible before it escapes the chimney the name of the game in terms of efficiency?
The name of the game in terms of efficiency starts with burning the fire at the appropriate temperature. Some of the gasses given off when burning wood will not ignite if the temperature is not high enough (unfortunately, I don't remember the ideal temps). If that's the case, the gasses go up your chimney unburnt, or condense on the chimney walls. Failure to burn these gasses gives up a LOT of BTUs that you could otherwise burn.
For a good web site with information on the subject, check out www.woodheat.org Their site has a lot of good info, as well as links to other sites with good technical background.
John
heating hot water with a wood stove.
Started by muddstopper on Firewood and Wood Heating
Last post February 18, 2013, 09:46:31 AM
by r.man
side arm hot water heater not heating like it used to
Started by moselgreenwing on Firewood and Wood Heating
Last post February 14, 2017, 07:18:35 PM
by Kellyj
passive solar water heating idea
Started by nailbender on Firewood and Wood Heating
Last post October 11, 2010, 10:30:43 AM
by Bill
What is your OWF water jacket temperature at beginning of heating season?
Started by Dean186 on Firewood and Wood Heating
Last post November 23, 2010, 10:28:27 AM
by Dean186
