Author Topic: remington manual and automatic oilers  (Read 1225 times)
Offline old 030
« on: July 04, 2010, 11:51:52 AM »
wanted to see if anyone knows on the manual only remys, is the only check valve used in the line, from the pump to the outlet?. i have a pl55/wards, looks like it was never used, manual only, but still seams to burn alot of oil, any way bar oil can get into the crankcase on these?. any info would be great. also wanted to pass along, on my sl11a, with the same problem, a homelite rubber duckbill valve worked great, and was easy to install. found out my wards did also have auto oiling, it just did'nt say it anywhere on the saw, it was also an easy fix with a homelite duckbill valve
Manual vs automatic WM board return
Started by pnyberg on Sawmills and Milling
Last post September 26, 2009, 09:36:22 AM
by Warren
old remington saw
Started by beeto24 on Chainsaws
Last post November 18, 2003, 07:32:06 AM
by SasquatchMan
35 Remington
Started by Raider Bill on The Outdoor Board
Last post November 22, 2011, 08:56:45 PM
by teamgreen
remington sl-9
Started by clyde on Chainsaws
Last post August 18, 2005, 08:59:02 AM
by sawguy21
