Author Topic: Unique TF Barn ???  (Read 7522 times)
Offline Rooster
  • Board Moderator
  • Tools are extensions of ourselves... share a tool.
    • Photobucket image storage account
Unique TF Barn ???
« on: March 19, 2011, 12:44:56 PM »
Howdy,
A salvage guy in Wisconsin found and purchased this barn near Manitowoc, WI which is north of Milwaukee near Lake Michigan. It is a 40 x 70 hand hewn pine frame. He has never seen one like this, and neither have I. To me, the most unique part of this frame is that the tails of the rafters are joined to either a full tie beam that rests on top of the sidewall top-plate, or for lack of a better description, "stub-tie-beams", which then seem to be attached to a beam that spans the bay and connects the full tie-beams about 24" from their ends. It seems like the framer is using this secondary beam to help control the roof from pushing the sidewalls out at the top. Do you also see this?...or is there a different purpose or idea behind this additional framing system?
So I offer this starter question...Does this design have it's origins in any known ethnic inventory?
Let me know what you all think.
Rooster
P.S I am hoping to do a Sketchup drawing of the frame so that I can post it in the  depository.
"We talk about creating millions of "shovel ready" jobs, for a society that doesn't really encourage anybody to pick up a shovel."
Mike Rowe
"Old barns are a reminder of when I was young,
       and new barns are a reminder that I am not so young."
                          Rooster
Offline shinnlinger
Re: Unique TF Barn ???
« Reply #1 on: March 19, 2011, 07:50:32 PM »
I have never saw a frame like that and I suspect the reason why is it uses more lumber and joinery than other simpler designs that will work just as well.  I am unsure why a farmer would make more work or expense for himself building a barn or anything else for that matter.
Maybe it is the pics, or perhaps they did a really good job, but other than the floor joists it doesn't look hand hewn to me.
Shinnlinger
Offline Rooster
  • Board Moderator
« Reply #2 on: March 19, 2011, 09:20:08 PM »
Maybe the farmer got talked into it because he didn't have enough experience, or he built it himself ("farmer built") and wanted to over-build it to make sure that it would last. We may never know.
Mike Rowe
                          Rooster
Offline Rooster
  • Board Moderator
« Reply #3 on: November 11, 2012, 08:54:45 PM »
Hey,
I finally got a chance to draw this frame with Sketchup.
The tie-beams sit on top of the sidewall top-plate like a regular English tie joint, but they used common rafters.  Each tie-beam has it's own set of rafters, but the rafters between the tie-beam spacing sit on "Stub-ties", which take up the distance or depth of the regular tie-beams and give each rafter a foot-pad to connect to and transfer the load to the top-plate.
I have only seen two frames that have this type of roof system, and I believe it may be Pomeranian-German style.
Has anyone seen other frames like this?
Thanks,
Rooster
Mike Rowe
                          Rooster
Offline giant splinter
  • Pacific Northwest
« Reply #4 on: November 11, 2012, 10:03:01 PM »
A very interesting design indeed and you did a great job with the sketchup, this design has almost a truss element to the roof support members and I like the way the rafters are connected over the tie beams at the top plate and the use of the "Stub-ties" and transverse rim-joist style beam to stabilize the roof loads. Very special and appears to be well engineered with many considerations given to use of space horizontally and vertically. Thanks for sharing this special barn frame and it looks even more interesting with your sketchup drawing as many of the details are visible to show us a clear view of how this structure was built. If only we had xray vision and could see into the joinery to observe the the details hidden from our view in this very strong design. I have never see any frame that used this method of connections it is unique and very sturdy.
Very interesting post thanks for sharing.
roll with it
Offline Brian_Weekley
  • I am Batman!
« Reply #5 on: November 30, 2012, 08:29:34 PM »
Rooster,
Do you know how those stub ties are attached to that inner beam?  Looks like they are notched to fit over the outer plate and I assume they would have horizontal mortise and tenon joints into the inner beam, but are they also pegged?  They could be pegged from the top of the beam, but I can't tell from the photos.
BW
e aho laula
Offline Rooster
  • Board Moderator
« Reply #6 on: December 01, 2012, 10:59:22 AM »
Rooster,
BW
BW,
To answer your questions...yes,yes,yes, and yes!   ;)
I'll be going down to finish the frame next month, and I will take lots of photos of the repairs, joints, and raising.
Thanks,
Rooster
Mike Rowe
                          Rooster
Offline Rooster
  • Board Moderator
« Reply #7 on: December 29, 2012, 10:14:28 PM »
Update:
I recently returned home from the site on which this barn was relocated to...(Fredericksburg, TX)
Here are some photos of the restored and re-raised frame.
Mike Rowe
                          Rooster
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #8 on: December 29, 2012, 11:39:23 PM »
It looked like a nice site.
Thanks for posting.
Jim Rogers
Offline Brad_bb
« Reply #9 on: December 30, 2012, 02:30:14 PM »
Are the girts face lapped(cut out on one side) to accept those long corner braces? How do you think they laid those out?  Before assembly or on the fly?
Good pics by the way.  Any more?  Was that how it was when you had to leave?
Offline Rooster
  • Board Moderator
« Reply #10 on: December 30, 2012, 02:38:42 PM »
Yes, the girts and wall diagonals are half-lapped. I believe that they were scribed during pre-assembly The diagonals have short tenons on the top and bottom that match mortises on the underside of the tie-beam and the top of the sill beam.
I couldn't stay for the rest of the rafters to be raised...so they will have to send me photos when they are done.
Thanks,
Rooster
Mike Rowe
                          Rooster
Offline clww
  • Oh yeah? Watch this!
« Reply #11 on: December 30, 2012, 05:44:44 PM »
I can't help but wonder how long it took to originally build that barn, "back in the old days"? That's some incredible workmanship, IMHO.
I really like that final photo at sunset.
Many Stihl Saws-16"-60"
18-Wheeler Driver for CFI
  • I am Batman!
« Reply #12 on: December 30, 2012, 11:32:07 PM »
Rooster,
Originally, I was going to propose a crazy, alternative theory for this design
They cut all the rafters based on the width of the barn:
However, they forgot that all the rafters dont sit on a tie beam!  Therefore, most of the rafters cut were too short and couldnt be used:
To remedy this mistake, they added the secondary beams and the stub-ties to give the rafters something to sit on and bring them to the correct height.
If the rafters had been spiked into the stub-ties, I would stand behind my theory.  However, your new photos clearly show mortises cut into the stub-ties to accept the rafters.  Therefore, I think the design was probably deliberate and I agree with your hypothesis (resistance to outward thrust).  Very interesting--thanks for sharing.
Brian   :P
e aho laula
Offline Slab Slicer
  • Hungry to learn
« Reply #13 on: December 31, 2012, 09:04:21 AM »
Considering the barns original location (WI), I believe the design was done to support HEAVY snow load on the roof. In a sigle top plate design, the load on the roof would transfer to the walls of the barn, and in turn bow the walls, and allow the roof to sag, and eventually collapse. The addition of the "inner beam" is similar to a floor truss laying on it's side. A single top plate would not hold near the load that this system would hold. JMHO
Amazing joinery by the way. Alot of craftmenship indeed. It's nice to see this barn being relocated, rather than disassebled, and sold in pieces.
Another comment, How old is this barn? Again, considering it's original location, and the loads it must have experienced in it's lifetime, there is no indication in your first pic of any roof sag, or outward bow in the walls. I think the design proved itself.
2016 LT35HDG25, Kubota BX1500 w/FEL and custom skidding rig, Stihl MS362-25", Stihl MS250-20", Stihl MS192-18", Stihl MS180c-18". 2011 Toyota Tacoma, Ringo 12' trailer w/ folding rear gate, Iron & Oak 22 ton splitter.
Chuck
Offline drobertson
« Reply #14 on: December 31, 2012, 09:16:06 AM »
rooster thanks for all the pics, this timber frame construction has really grabbed my attention, and not knowing anything at all, what slabslicer suggested on the side load makes sense to me, not only snow loads but maybe wind loads as well,  thanks to all who build these structures and share your techqniques,  david :new_year:
Offline Migal
  • I'm new! But Old as Dirt!
« Reply #15 on: December 31, 2012, 11:25:06 PM »
 :) Mighty fine work in the first paragraph that part of wouldn't work Hmm I grew up on a farm in PA where the barn was built over 200 yr's prior to my birth and it sure looked alot like that one cept the painting was just dry boards no rot though we always wished Mail Pouch would paint it but it wasn't by the freeways that they charge toll's on now day's Hmm Dang glad to see such fine craftsmanship then and now  :snowball:  :new_year:
Stihl learning and picked up my Log Master LM2 Cat 34hp 02 21 12! 230MF+ the toys that go with it! MS361 MS271 Stihl PB500 Echo 48" Logrite 16ft Bass Tracker Pro' Abua Garcia 5600 bait caster, Wood working equipment' Lake Lot never enough time! oh don't forget the fridge with ale! Loving Wife Rebeca
Offline Rooster
  • Board Moderator
« Reply #16 on: January 01, 2013, 02:50:09 PM »
Yes, it's all hewn.  Some of them are so smooth and straight, that from 20ft away, they look sawn and planed.   I am of the opinion that true hewing is done to produce this smooth finish as apposed to roughing out a beam or cant.  Check out how smooth Mike B. gets his hewn surface.
Or Nebruks:
Mike Rowe
                          Rooster
Offline D L Bahler
  • Hopp Schwyz!
    • Traditional Swiss Carpentry
« Reply #17 on: January 01, 2013, 06:58:06 PM »
I'll add here what I said over at the TFG forums, plus a little more info relevant to this thread.
Seeing the deconstruction and reconstruction of this barn, the frame assembly, joint layout, joint designs etc. have very clear connections to timber framing of the western Swiss Plateau. Many of the features of this barn strike me as very familiar and identical to what I see on the large farm buildings in the Canton of Bern. These would include the long slanted braces, the short tenons, the dovetail lap joints, and even the mysterious stub tie assembly. I have seen this exact assembly in use in Canton Bern.
I think there are a number of reasons why this is done.
First, all rafters are identical, that is you don't have shorter rafters where the full ties are. This makes a difference in keeping the roof straight over time.
Also, this assembly stiffens the walls and keeps them nice and straight.
Third, in the huge Bernese farmhouses, there are many many tie beams spaced like the stub ties (close) supporting a very large upper room where hay and machinery are stored. On buildings lacking this huge upper space (due to a design for a different use) the assembly of the many ties is kept by using the stub tie system. This allows for a certain degree of stiffness while still allowing for a relatively open loft space.
I would hypothesize that this barn was built by a Swiss immigrant with training in the old country, applying his knowledge to the farming realities of the United States.
Offline D L Bahler
  • Hopp Schwyz!
« Reply #18 on: January 01, 2013, 10:41:56 PM »
I looked through some of my pictures, here's one barn that shows some of the features although it is a little different, and is in the mountains, not on the plateau.
Offline D L Bahler
  • Hopp Schwyz!
« Reply #19 on: January 01, 2013, 10:51:46 PM »
And here are a few more, from the Emmental
moved
MOVED: * VERY LARGE BARN FULL OF UNIQUE HARDWOOD LUMBER *
Started by Jeff on For Sale
Last post January 17, 2013, 01:13:32 PM
by Jeff
Unique Multiple King-Post bent in barn frame.
Started by Rooster on Timber Framing/Log construction
Last post January 22, 2013, 02:07:04 PM
by Rooster
Red Barn, White Barn, Brown Barn, Blue?
Started by kwendt on General Board
Last post March 29, 2015, 03:50:59 PM
by Don_Papenburg
Timber-frame barn photo library and plight of the Mid-Western barn...of sorts.
Started by Rooster on The Wisconsin Barn Preservation Program
Last post November 14, 2009, 08:19:08 PM
by Rooster
