Author Topic: nother tractor question  (Read 2376 times)
Offline LeeB
« on: April 30, 2011, 12:53:25 AM »
I have a Ford 851 that has a hung up clutch. Ran fine a couple of weeks back when the neighbor kid used to bush hog the pasture. Never had any trouble with the clutch before. I thought it might need adjustment but that didn't help. Any way to get at the clutch without splitting the tractor?
Offline sandhills
Re: nother tractor question
« Reply #1 on: April 30, 2011, 01:19:30 AM »
I'm not very familiar with Fords, but every clutch I've ever worked on required splitting.  By "hung up" do you mean the clutch won't release?  Had an IH that did that and it was due to the pilot bearing going out and pieces of it getting caught in the clutch, I would think there should be a plate under the bell housing you can remove and look up into the clutch, can't always see the problem though  :-\.
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #2 on: April 30, 2011, 05:23:50 AM »
I have a Ford 2600 that I thought was going to have to be broke down to fix, but a young fella out of Vo ag class ...took it down a blacktop road and broke it loose some how...I dont rember what he did , but do know he said it had to be on a road that would not let the wheels spin on  (loose gravel or dirt)....If you don't get an answer I'll call a buddy of mine that was with him and see if he rembers exactly what he did to it..This was probably 25 years ago and I just don't rember ....Tim
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline LeeB
« Reply #3 on: April 30, 2011, 08:16:19 AM »
Yes, the clutch won't release.
 I can well understand why you can't remeber after  25 years Tim. I can't remember what I had for lunch yesterday.
Offline WH_Conley
  • I need to tide my profile!
    • Stone Hill Hardwoods
« Reply #4 on: April 30, 2011, 08:52:52 AM »
Get it in a higher gear, rev the engine, shove in the clutch and stomp the brake. I have a Ford 7000 that does that every once in awhile.
Bill
Offline Raider Bill
  • Who will pull the wagon when everyone rides?
« Reply #5 on: April 30, 2011, 09:31:37 AM »
Put it up against a big tree and let er run. I did that once it worked but was a long time sitting so I suspected rust was the issue.
The First 60 years of childhood is always the hardest.
« Reply #6 on: April 30, 2011, 10:16:15 AM »
Thats what I wanted to say he done to mine...and as Raider Bill said it had been setting for a while ....we had trailered it to a shop and I was expeciting to get nailed for a pretty good bill....but there was a young guy that had just got out of vo ag that knew the trick...I would make sure both brakes were locked when I tried it....it is dangerous...Tim
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7 on: April 30, 2011, 12:31:57 PM »
That may not have contributed to the problem, but I hate the thought of loaning equipment out.
It's not something simple like a limb or something hung up in the linkage?  Nah, simple stuff happens to other people.   :-\
Offline red oaks lumber
« Reply #8 on: April 30, 2011, 04:22:32 PM »
LeeB, yesterday for lunch you had grits ;D
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #9 on: April 30, 2011, 04:42:55 PM »
No one eats grits for lunch.  Only breakfast and supper.  Yeah !!!
Offline Larry
« Reply #10 on: April 30, 2011, 05:49:01 PM »
All good suggestions.  I've also broke them loose just by blocking the clutch pedal in and leaving it for a few days.  I had a Ford 4000 that if it sat for over a month the clutch would freeze every time.
Offline Autocar
« Reply #11 on: April 30, 2011, 07:17:24 PM »
Sounds like your clutch disk has rusted to the fly wheel. Put it in gear and hold the cluch pedal down while you do this when she gets pulling hard she will spin free. Just be sure you have the cluch pedal ingaged.
Bill
Offline Brad_bb
« Reply #12 on: April 30, 2011, 11:50:46 PM »
Rusted together in such a short period?  Hmmm.  Yes you'd have to split the tractor.  I do believe a replacement clutch is available.  I also recommend the tractor forums at ytmag.com  It's where I've gone when I needed discussion on my '55 960 that I fully restored.
Offline WH_Conley
« Reply #13 on: May 01, 2011, 12:17:27 AM »
Nope. Don't need to split it. A little shock will break it loose. If it sat for years probably wouldn't come loose. I believe those are semi metallic clutches, the metal is what sticks. It doesn't take a lot to break them loose. I just use my big tractor for the heavy work. It is not uncommon to have to break it loose 2 to3 times a year.
Bill
Offline Taylortractornut
« Reply #14 on: May 01, 2011, 12:21:48 AM »
Two things can come to mind  1 a warped or disentigrating clutch disk.     I have a warped one  in my old 3550 TLB some times it wont release after alolt of pushing and loading.   I wonder if the  kid road or slipped the clutch any.     The second is  theres condensation inside the  bellhousing and  its letting the the clutch rust to  flywheel and not letting it release.   You can clutch it and    ride the brakes and  run it up the  road in road gear.   I used to run an  older D8  with an air operated  clutch.   It was a later model clearing tractor.     When the  clutch froze usually after a rain     I would start it in gear with a push and  hold the clutch lever and   rake a while till it let go.       I have talcum powdered them to help dry it up.     On smalled dozers   the steering clutches will do the same and are a  pita to break loose.
My overload permit starts after sunset
Offline davey duck
  • 607-731-7062
« Reply #15 on: May 01, 2011, 03:38:10 PM »
those ford tractors have a pto that engages when the clutch is released if they were bush hogging they might have got it in a bind and slipped the clutch an welded it together.or the throw out bearing is burned out.
David G.Fleming
Offline ARKANSAWYER
  • Poor white Southern trash
« Reply #16 on: May 01, 2011, 10:32:59 PM »
With all the rain we have had I would just try to get it to slip.  One way is to put the tractor in gear and pull it with a truck.  Being on a good hard road helps.  The clutch needs to be held in while this is happening.  If the pilot bearing is froze it is hard to get the tractor apart.  It is to wet right now any way so you do not need a tractor.  You need a boat.
ARKANSAWYER
Another 'nother Laptop Question??
Started by Magicman on Technical Support Topics
Last post April 06, 2015, 09:34:53 AM
by Magicman
Nother Question for electronics-mechanics
Started by Fla._Deadheader on General Board
Last post February 24, 2003, 04:51:45 AM
by OneWithWood
Tractor question
Started by Mongo on Forestry and Logging
Last post September 20, 2004, 08:47:49 PM
by J_T
Tractor question
Started by Bruno of NH on General Board
Last post February 21, 2017, 04:33:14 PM
by Ed_K
