Author Topic: 025 problem solved.... I think?  (Read 806 times)
Offline island boy
« on: November 02, 2011, 09:13:40 PM »
Took off the pull start cover to get to the module and removed two screws holding it down. Cleaned off some residue on the connections and then put it all back together. I figured I would at least get familiar with what the procedure was to replace the module. After getting it all back together the saw fired up as it always has and I waited for it to warm up figuring it would soon cut out. It kept running even after limbing and bucking a downed spruce tree.  Guess it's fixed, but not sure why... we'll wait and see.
Thanks for the help.
Hmm What to do ?? Problem Solved !!
Started by Meadows Miller on Sawmills and Milling
Last post July 06, 2010, 04:14:40 PM
by paul case
LT-40 feed problem(solved)
Started by woodmills1 on Sawmills and Milling
Last post August 26, 2003, 11:21:09 AM
by Fla._Deadheader
starting problem solved
Last post October 14, 2008, 07:42:38 AM
by bandmiller2
transmission problem solved!!!
Started by Carries-Mom on General Board
Last post February 13, 2008, 08:55:27 AM
by Carries-Mom
