Council Tool
Author Topic: A day cutting wood  (Read 335786 times)
Offline Peter Drouin
    • A&P Saw mill LLC
A day cutting wood
« on: May 01, 2012, 08:49:55 AM »
Rain today so I thought you all would like to see this job. when I got to the job today I saw this :D :D :D A few logs all ln a row. so I set the mill up.
  The customer gave me the cut list and I started. the customer did a good job to line up the logs, but sometimes they get out of alignment . so I made a log mover for my self.
  It will work with any mill. just some 5" wheels and angle iron. the limbs are cut flush to the tree. I just roll the log up on it, I have 4"x4"x4' in front of it.
  just push the log sideways and your all lined up. will work with biger logs to.
  I use it all the time. it was hot to day so the umbrella came out today not to burn my but.
  and at the end of the day I blow off the mill. I have a aircompressor that I bring with me.
  I like to use a small tip, so I can get in all those small places. I like to blow out the filter too
  and then cover the mill and go home :D I made a small dent in the pile. ill go back wednesday
Offline Norm
Re: A day cutting wood
« Reply #1 on: May 01, 2012, 08:53:51 AM »
Now that's a big job! Cool idea on the log mover too!
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: May 01, 2012, 09:00:53 AM »
That is a nice whack of logs and a very good idea on the log mover/aligner.
What dimensions of lumber are you sawing?
Offline bandmiller2
« Reply #3 on: May 01, 2012, 09:24:59 AM »
Pete,good idea on that log evener,we just used the roller toe boards but only works if your on them. Frank C.
Offline ladylake
« Reply #4 on: May 01, 2012, 09:56:42 AM »
 A tapered slab in the middle of the logs lets you steer it easy as you roll it also, looks like a week or so of cutting  , might have to move the mill closer to pile after a coulple of days.  Steve
Timberking B20 12000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Dino setter Volvo MCT125c skid loader
Offline dblair
« Reply #5 on: May 01, 2012, 10:28:05 AM »
I like that log aligner . Nice whack of logs also.
old Appomattox Iron Works circle mill.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #6 on: May 01, 2012, 10:39:14 AM »
I like for the log pile to be at least 10' from the sawmill so I can adjust them with a 4"X4" as Steve suggested above.
I do have roller toe boards, but whatever method that you use, it is far easier to always have the log adjusted before it is loaded onto the sawmill.
Most times for minor adjustments on 8' logs, I roll it back onto the loader pulling the long end first and then back onto the sawmill pushing the long end first.
Offline thecfarm
« Reply #7 on: May 01, 2012, 10:53:12 AM »
A good idea. What kind of wood? Rain here today too.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #8 on: May 01, 2012, 11:03:18 AM »
Great Whack O Logs Peter!
I like the idea of the "log shifter", must save a lot of hastle.
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener, 4-foot Logrite cant hook.
Basic mechanical skills are all that's required to maintain the Wood-Mizer.
Offline markd
« Reply #9 on: May 01, 2012, 11:40:02 AM »
Peter, looks like you have a good system workin for you there, good job! Markd
markd
    • A&P Saw mill LLC
« Reply #10 on: May 01, 2012, 12:17:57 PM »
All the wood is w pine and hemlock. the cut list is for a 24x50 barn. the customer had me cut some dry wood for the sticking. my wood, he did not want to use green wood. and yes ill have to move the mill in. I do use a tapered slab to steer the logs. but the log shifter has been a good thing to get them lined up a big help to me. the next job is just as big and the phone is ringing off the hook with lumber orders.  :D :D
Offline Al_Smith
« Reply #11 on: May 01, 2012, 12:43:44 PM »
Clever idea .Egads you'll have a pile of saw dust before that job is done no doubt .
Offline cutterboy
  • Sometimes trees fall where they want to.
« Reply #12 on: May 01, 2012, 09:50:35 PM »
What a beautiful sight! All those logs lined up nice and pretty. Looks like you'll be busy for awhile. I love your log shifter.....very clever. Hey, and thanks for all the pictures.
Offline barbender
« Reply #13 on: May 01, 2012, 10:09:33 PM »
I just finished my first portable job, and I was running into the misalignment issue. I like Peter's solution, I was thinking a small arch would be slick too.
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #14 on: May 01, 2012, 10:16:12 PM »
It does not get a lot better than that.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #15 on: May 02, 2012, 07:51:58 AM »
I agree WDH, that is a dream job for sure.   8)
    • A&P Saw mill LLC
« Reply #16 on: May 02, 2012, 09:03:38 PM »
well I got at the job today and all the sawdust was gone and all the slabs . so I got out the atf and painted all the parts on the mill that move. :D
  fuel up sharp blade and here I go :D well the log shifter is not perfict the hook on the mill will get it sometimes
   on the cut list are some beams. the WM will cut nice and square but I check, I have a small square that I keep by my feet on the chair.
  but sometimes I over clamp. so I will shave the cant so its square
  I keep a pv on each side ov the log pile I think you can see them in the pic
  when im cutting I have to look out for the outside wheel the sawdust will get in there and stop it from turning :o
  .all and all to day went well. maybe after thursday ill have to move in. 2 days and I think im half way maybe :D :D :D
   :D
Offline WDH
  • Forester
« Reply #17 on: May 02, 2012, 10:28:53 PM »
That pile looks like it keeps getting bigger.  Maybe the wood nymphs are secretly adding to it at night after you leave.  You may never get finished  :D.  It could be the Hotel California of logs  ;).
Offline JohnM
  • Sometimes its best to punt and play field position
« Reply #18 on: May 03, 2012, 10:27:53 AM »
well I gut at the job today and all the sawdust was gone and all the slabs too.
The nymphs take the slabs and dust, glue up 'logs' and put them on the end of the pile. ;D :D
JM
Lucas 830 w/ slabber; Kubota L3710; Wallenstein logging winch; Split-fire splitter; Stihl 036; Jonsered 2150
Offline WDH
  • Forester
« Reply #19 on: May 03, 2012, 09:17:41 PM »
Nymphs are like that  :D.
Cutting Wood
Started by luvmexfood on General Board
Last post January 03, 2018, 10:49:47 PM
by luvmexfood
My Day Cutting Wood
Started by lxskllr on General Board
Last post November 10, 2018, 05:10:32 AM
by timberlinetree
Cutting wet wood
Started by outdoortype on Chainsaws
Last post April 26, 2005, 05:46:41 AM
by rebocardo
Cutting for a portion of the wood
Started by KjBarnwood on Sawmills and Milling
Last post April 27, 2008, 08:49:22 PM
by Warren
