Author Topic: I need a Debarker,  (Read 1675 times)
Offline 123maxbars
    • www.outofthewoodsforestry.com
I need a Debarker,
« on: November 15, 2012, 10:43:26 PM »
After operating/owning my LT35 Hyd for the last year and a half I am happy to announce they now offer the debarker for my model. I hope to have it sometime this winter.  I saw mostly poplar/pine and a little cedar and walnut.  I get my logs from the local loggers who skid them out of the woods. Some are really clean but most have a decent amount of dirt/debris on them. I am hoping with the debarker I can get some decent blade life before sending them to resharp.  I average about 300bf before the blade gets pretty dull.  I would LOVE to get 450bf or more. And when I say I get 300 thats the best case senario.  I probably average 250bf.  I could probably push the blade longer but I hate wavey cuts. Anyways this post is for the people who had the LT35 before the debarker was released. Up until a few weeks ago it wasnt avaialbe for LT35 models that were built last year. I hope to get mine when they are doing thier service loop next year.
Sawyer/Woodworker/Timber Harvester
W/M LT35HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Offline Chuck White
  • Sawing Mobile since 2005
Re: I need a Debarker,
« Reply #1 on: November 16, 2012, 05:37:33 AM »
For what it's worth, I run an LT40HDG24 with a debarker and I average 600-800 bf before I need to change the blade!
Sometimes I even get a little more, depends on the logs!
~Chuck~
I LOVE MY SAWMILL
Offline Woodsrover
« Reply #2 on: November 16, 2012, 06:45:47 AM »
Are you washing the logs?  I pressure-wash all my dirty stuff and it helps a lot.
Offline 123maxbars
« Reply #3 on: November 16, 2012, 07:44:34 AM »
No on the pressure washing, My mill isnt anywhere close to a water source,
outofthewoods
Youtube page
Out of the
Offline Bibbyman
    • Warden Sawmill
« Reply #4 on: November 16, 2012, 08:28:59 AM »
We rented a power washer one time to use on some mud and creek gavel packed logs.  It got the mud off but left rocks and grit ground into the bark. Washing the logs was time consuming and a mess.  At least that was our experience.
Debarker may not get all the mud and rocks out of deep, soft bark.  You'll still want to clean the ends.  We try to clean up the exit side too.
Sawing since '94
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #5 on: November 16, 2012, 06:18:34 PM »
I need a debarker too.  Does anyone have any close-up pics of the new LT-35 debarker?  It looks simpler than the one on the Lt-40.
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline timberjackrob
« Reply #6 on: November 16, 2012, 08:17:28 PM »
i wonder if the lt35 debarker could be made to fit the lt28?arent they basically the same saw carriage?
208 timberjack woodmizer lt28 case 455 trackloader massey 4610 ford f250s ford f700
Offline submarinesailor
  • LT15 and a wife of 45 yrs
« Reply #7 on: November 16, 2012, 08:25:31 PM »
Hey Marty,
WIll the debarker mentioned above fit the LT35 we picked up around 5 months ago.
Bruce
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #8 on: November 16, 2012, 09:36:30 PM »
Hello Bruce,
Your LT35 revision A1.01.  At this time only revision A 2.00 and newer can be equipped with the Debarker. WM is working on making it available in the future.
The LT28 can not accept the Debarker you will need a heavier charging system to keep the battery charged. The LT 35 has an external alternator.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
« Reply #9 on: November 16, 2012, 09:38:36 PM »
Marty,
Thanks for the info.
Please let me know as soon as one is available for the 1.01.
Bruce
Offline MReinemann
    • Reinemann Mill Works
« Reply #10 on: November 16, 2012, 09:52:10 PM »
Debarker RPM?
Started by woodhick on Sawmills and Milling
Last post September 27, 2006, 02:53:44 PM
by sparks
Debarker
Started by WH_Conley on Sawmills and Milling
Last post April 09, 2018, 05:09:12 PM
by sparks
Log Debarker
Started by simplicityguy92 on Drying and Processing
Last post December 11, 2011, 12:58:58 AM
by simplicityguy92
debarker
Started by keith on General Board
Last post July 21, 2004, 09:16:15 PM
by keith
