Author Topic: Building a shed around a woodmizer  (Read 1923 times)
Offline 123maxbars
    • www.outofthewoodsforestry.com
« on: May 01, 2013, 11:30:37 PM »
I am moving in a few weeks to our new home. Unlike the place we live now I am going to have a smaller work area for the LT35. I am going to have to utilize every square foot for logs/tractor etc. I do not do portable work. My sawmill hasn't moved since I brought it home. This is a move (that should be our last) that has been in the works for the past two years. Anyways I am laying out the ground work for the new shed to cover the mizer. Due to the place it will go and limited space I am going to have to build the shed around the mill.  Since its such a tight fit between three solid rock walls that are 15plus feet high the only way I can get the sawmill in the location I need it is plant it there and build the shed around it. After the shed is complete if I ever wanted to move the mill out (trade in/ or upgrade maybe) it could be done but would be pain in the a$$.  Just wondering if anyone on here has ever built a shed/building around their mill.
Sawyer/Woodworker/Timber Harvester
W/M LT40HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Offline thecfarm
Re: Building a shed around a woodmizer
« Reply #1 on: May 02, 2013, 06:44:52 AM »
15 foot high rock walls???  ::)  I thought I had some walls,you got me beat. Good luck with your shed.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: May 02, 2013, 07:18:18 AM »
No, but I hope that you detail and share your ideas and build with us.   ;D
Offline flyboy16101
« Reply #3 on: May 02, 2013, 08:39:47 AM »
From the sounds of things you might be able to set some trusses on the existing rock walls. I was going to build around the mill for mine but with my luck I have I would drop something on it so I've decided to move the mill out of harms way before I start. Good luck with the project look forward to seeing pictures.
Wood-mizer Lt35, International 504 w/ loader, Hough HA Payloader, Stihl Ms290, Ms660, Logrite Cant Hook
Offline dboyt
  • Log On!
« Reply #4 on: May 02, 2013, 12:11:43 PM »
This brings up a question... how do you plan for ventilation of exhaust fumes?
Offline 123maxbars
« Reply #5 on: May 02, 2013, 10:29:37 PM »
Good question and thanks for the insight. Something I need to think about,
outofthewoods
Youtube page
Out of the
Offline Alyeska Pete
  • Location: In the Catskill Mountains, west of Kingston, NY
« Reply #6 on: May 03, 2013, 07:53:31 AM »
"Since its such a tight fit between three solid rock walls that are 15plus feet high the only way I can get the sawmill in the location I need it is plant it there and build the shed around it."
Just curious as to how you are going to get logs in and slabs and lumber out if there is only room for the mill?  Some pictures of site would probably help allot.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #7 on: May 03, 2013, 09:09:30 AM »
Pete; I was down your way, back in 1994!
I was a shuttlebus driver for "WoodStock '94".
All I can say is it was interesting, only got lost twice.
Once I ended up in a cow pasture (almost), the other time in ended up in Kingston!
~Chuck~
Offline 5quarter
« Reply #8 on: May 03, 2013, 10:10:51 AM »
Chuck...We did a 2 week fishing trip along the Lake/river between Potsdam and Norwood When I was a kid. is that the black river up there?  I love that part of the state!
Offline mesquite buckeye
  • Trees are good- even ones with stickers
« Reply #9 on: May 03, 2013, 12:03:15 PM »
Also, where does the sawdust go and how do you get it out?
You could always build a gantry crane with a couple of hoists, set on a couple scrap rails. Then you could roll it in and out easily to move it or to clean, work etc.
Offline drobertson
« Reply #10 on: May 03, 2013, 07:07:09 PM »
Max, I did the oppisite, but just a pic for any ideas you might have,
I realize you have an existing building, my point was only that with the portable option, this should always be kept in the back of your mind, portable is a option that will come up at some point, and just for conversation a very enjoyable adventure, this shed was built in 07' and has the drive through option, which is handy for many things, cleaning the shed, mill and of course going portable when necessary,  david
Building a sawmill shed
Started by levans on Sawmills and Milling
Last post June 17, 2012, 01:15:46 PM
by levans
building a shed for my sawmill
Started by ToddC on Sawmills and Milling
Last post December 26, 2006, 10:13:56 PM
by Don P
question
Building a Sawmill Shed
Started by FeltzE on Sawmills and Milling
Last post June 24, 2003, 07:28:13 PM
by C_Miller
Building a cantilevered saw shed
Started by Qweaver on Sawmills and Milling
Last post July 08, 2010, 08:40:48 PM
by Magicman
