Author Topic: Dose anyone still use these  (Read 1574 times)
Offline Alligator
  • Born behind the slab pile, have turpentine blood
    • Alligator Casey
« on: July 07, 2014, 10:17:17 PM »
I must have filled a thousand of these. Some of them behind the mill when it was freezing.
Can anyone tell how much we sawed today?
Esterer Sash Gang is a  Money Machine
Offline drobertson
Re: Dose anyone still use these
« Reply #1 on: July 07, 2014, 11:08:20 PM »
Yep, that's the way it's done, high production of course, but have done it a few times here.  Bout the best you can get in my view.
Offline Alligator
    • Alligator Casey
Blanks Anyone
« Reply #2 on: July 07, 2014, 11:25:07 PM »
Dimension Tally sheet and Excel Spread Sheet Calculator
also 2 Examples
Offline ozarkgem
  • age 65 yrs old
« Reply #3 on: July 08, 2014, 07:57:06 PM »
Looks like a hole in one and 6 under par. I have no idea what it is. Pre electronic tally sheet I would guess. OK How many board feet
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #4 on: July 08, 2014, 08:50:51 PM »
I get 26028 bf. Warn't no portable sawmill. :o :o :o
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker),  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #5 on: July 08, 2014, 08:57:53 PM »
I will agree! i started to add it, then TT replied. It saved me doing it, but was thinking there should be a formula to go with the tally sheet.
Offline Alligator
    • Alligator Casey
« Reply #6 on: July 08, 2014, 09:09:57 PM »
I've been away from the lumber business 20 years. Oddly enough I'm an IT project manager, but I don't do sawmills. I've never seen an electronic tally. That is why I ask. I thought there had to be a better way than sitting in that metal folding chair with a clipboard in 25 degree weather, with a 20 mph north wind.
As far as the footage goes, I guess I got carried away with the dots. I started running it up 3 times and every time the phone rang with a hour support call, lost my place, I finally gave up. I remember it's a lots more serious when you are counting your own money.
Hope someone can use the tally sheets. I did them on MS Visio, a Microsoft CAD/Drawing program. It's pretty simple to use.
Offline Alligator
    • Alligator Casey
Formula?
« Reply #7 on: July 08, 2014, 09:55:25 PM »
Board Ft. Head Calc
1x4 = 1/3 x L
1x6 = 1/2 x L
1X8 = 2/3 X L
1X10 = 1/6 L - L
1X12 = L
2X4 = 2/3 X L
2X6 = L
2X8 = L X 1-1/3
2X10 = L X 1 -2/3
2X12 = 2 X L
Offline Delawhere Jack
  • I ought to know better.....
« Reply #8 on: July 08, 2014, 10:07:38 PM »
Oddly enough I'm an IT project manager, ....
Having worked in the IT field for 13 years in everything from desktop support to data center design, all I can say is.....
I offer my most sincere condolences.  :)
(Running a sawmill is far more rewarding).  :)
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
Re: Formula?
« Reply #9 on: July 08, 2014, 10:11:01 PM »
Board Ft. Head Calc
1x4 = 1/3 x L
1x6 = 1/2 x L
1X8 = 2/3 X L
1X10 = 1/6 L - L
1X12 = L
2X4 = 2/3 X L
2X6 = L
2X8 = L X 1-1/3
2X10 = L X 1 -2/3
1X12 = 2 X L
Might want to recheck that list. ;)  Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline Alligator
    • Alligator Casey
Re: Formula?
« Reply #10 on: July 08, 2014, 10:14:30 PM »
Board Ft. Head Calc
1x4 = 1/3 x L
1x6 = 1/2 x L
1X8 = 2/3 X L
1X10 = 1/6 L - L
1X12 = L
2X4 = 2/3 X L
2X6 = L
2X8 = L X 1-1/3
2X10 = L X 1 -2/3
2X12 = 2 X L
Sorry
Offline Alligator
    • Alligator Casey
« Reply #11 on: July 08, 2014, 10:35:45 PM »
That's one reason I am enjoying the company here. Not the people you meet in the IT field. I grew up in the sawmill and all my friends lived on farms and in the country. I'm sort of a odd duck in IT meetings, but they all are kind of afraid of me because I out think them in most situations. Part of that is the sawmill background. You have to look a all the angles when  you're dealing with sawmills, labor, machinery, and the public. Most IT people don't do well in at least 2 of those, pick 2.
Offline Alligator
    • Alligator Casey
Sorry IT took so long
« Reply #12 on: July 10, 2014, 04:58:00 PM »
Here is the answer. terrifictimbersllc nailed it. Of course he knew. I attached an excel Spread Sheet. You can zero the Pcs columns and use it if you like. A supplement to the toolbox.
Offline Alligator
    • Alligator Casey
A Blank with makeup
« Reply #13 on: July 10, 2014, 05:43:55 PM »
Here's a blank all dressed up
Offline Alligator
    • Alligator Casey
I'll get the right one there one day
« Reply #14 on: July 10, 2014, 08:59:43 PM »
Some how I uploaded the wrong one. Just a suggestion, save it as a job name before you edit it. You have to enable editing when you download it.
Dose Your Wife Work With You ?
Started by Autocar on Forestry and Logging
Last post July 28, 2010, 08:51:49 AM
by terrifictimbersllc
CDL How dose it all work overthere
Started by Meadows Miller on General Board
Last post February 01, 2011, 06:32:03 AM
by Kansas
Dos por Ocho por Dose Metros
Started by Fla._Deadheader on Sawmills and Milling
Last post July 09, 2006, 09:50:26 AM
by asy
Dose size matter?
Started by JRHD on Drying and Processing
Last post January 22, 2019, 04:58:24 PM
by JRHD
