Author Topic: Problems with m Fabtek 4 Roller  (Read 1299 times)
Offline HansenM84
« on: August 11, 2014, 09:00:50 AM »
I'm hoping someone has some insight for me.  I have a Timbco 415C with a Fabtek 4 Roller head.  I changed the wire harness from the boom to the head, and all the head functions worked except the wheels won't spin to feed the log through.  They spin backward but only forward for short spurts or not at all.  The return homes sensor for the saw bar is lighting up when it returns home.  A fella at Fabco told me to pull out the #2 & #4 relay and switch them.  I did that and it started working again.....and then yesterday it stopped working again.  I've replaced the relays now, with no effect, and am at a loss now.  Any advice???
Offline Gary_C
  • Sunrise on the Prairie
Re: Problems with m Fabtek 4 Roller
« Reply #1 on: August 11, 2014, 09:52:20 AM »
Do you have some wires crossed in the new wire harness?
I don't know that particular machine, but I know with other Valmet machines those connection blocks can have some loose screws. Recheck all your connections and make sure they are in the right place and tight.
Offline HansenM84
« Reply #2 on: August 11, 2014, 01:41:49 PM »
Yup, checked all the connections a couple of times.
Offline dcress
« Reply #3 on: April 13, 2019, 10:30:23 PM »
Joystick buttons and wiring.
Offline wannaergo
  • Work while I'm young, sleep when I'm dead!
« Reply #4 on: April 14, 2019, 07:16:21 AM »
That sounds exactly like what our 4 roller would do when the saw home sensor crapped the bed.  If it's not that, then I'd start looking for broken wires
2016 Ponsse ergo 8w
2014 Cat 564
Husky 385
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #5 on: April 17, 2019, 12:27:49 AM »
I'd start with the saw home sensor.  Then look into joystick buttons.
Offline dcress
« Reply #6 on: April 21, 2019, 01:12:53 AM »
Joystick button switches is the easiest and cheapest thing to cross off the list. For what its worth might as well change them all if it is the problem.
Fabtek 4-roller
Started by deastman on Forestry and Logging
Last post November 24, 2013, 06:52:42 PM
by Duhnis
Fabtek 4 roller
Started by logloper on Forestry and Logging
Last post August 16, 2015, 01:13:22 PM
by logloper
Fabtek 4-Roller
Last post June 06, 2015, 06:00:13 PM
by deastman
Fabtek 4-Roller
Last post December 27, 2016, 09:01:13 PM
by wannaergo
