Author Topic: Cottonwood girdling  (Read 1610 times)
Offline IL80
Cottonwood girdling
« on: January 17, 2015, 12:13:28 PM »
I have about 10 acres of lowland that is quite populated with cottonwoods. These trees are averaging 15-20" dbh and are shading out some areas of oak timber and also the lowland that I want to grow up into cover for wildlife. My question is, will the "double girdle" method of ringing these trees actually kill them? These are growing fast and I don't want them to get huge. I did pick up some tordon but hate dealing with that stuff. Any advice would be great... Thanks!
Offline mesquite buckeye
  • Trees are good- even ones with stickers
Re: Cottonwood girdling
« Reply #1 on: January 17, 2015, 12:59:43 PM »
Tordon works, but try to spill as little as possible as it is soil active...
Offline IL80
« Reply #2 on: January 17, 2015, 03:11:05 PM »
Okay, thanks! I'm hoping that by girdling the tree twice, I won't need to apply any chemicals. I've read that this works, any thoughts? Hopefully this applies to large cottonwoods too!
« Reply #3 on: January 17, 2015, 05:01:05 PM »
They will die. :o :snowball:
Offline ChrisIsThis
« Reply #4 on: January 17, 2015, 05:29:37 PM »
Double girdling will kill cottonwood. It might not be 100% effective and it might take your trees 2-3 years to die completely. Girdling without herbicide is most effective in the growing season. Cottonwood might re-sprout from the stumps too, but since this is crop tree release and you have a number of years before harvesting don't worry about sprouting. The shade from the other trees should shade out the sprouts. If you're going to be doing this in the winter then you might want to use some herbicide. Tordon is very effective, but with some potential for off target damage or mortality. Glyphosate (active ingredient in Roundup) is also effective without potential off target effect.
The larger the island of knowledge; the longer the coast of mystery.
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #5 on: January 17, 2015, 08:56:20 PM »
I would use the tordon.
Girdling?
Started by Onthesauk on Ask The Forester
Last post June 30, 2011, 07:12:20 AM
by SwampDonkey
girdling a walnut?
Started by Brad_S. on Ask The Forester
Last post January 29, 2006, 08:13:31 PM
by Ironwood
Girdling oaks
Started by outofmire on General Board
Last post August 07, 2011, 12:43:11 AM
by CX3
Proper Girdling
Started by Karl_N. on Ask The Forester
Last post February 02, 2009, 10:54:59 AM
by chainspinrunner
