Author Topic: Moving scrap wood.  (Read 1764 times)
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Moving scrap wood.
« on: December 12, 2015, 12:33:00 PM »
I sell all my scrap wood for fire wood. Everything goes. Bark and all.
This way I don't have to full with it. When the box is full I move it up along the road
and sell it for $30.00 a box. It does not last long and it's gone.
I ran into a bit of a problem picking the box up with my forks on the tractor.
The back wheels just did not want to stay on the ground.
So I had to come up with a safer way of moving the boxes around.
This is what I came up with. I back into the box with the 3 point down.
Then I hook up the winch hook and lift the back of the box.
The 3 point then lifts everything up and away I go. Works great.
Total cost $27.00 in parts. I used all junkyard scrap metal and hubs.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Bruno of NH
Re: Moving scrap wood.
« Reply #1 on: December 12, 2015, 01:28:45 PM »
Looks good .
Great way to move the wood .
Jim/Bruno
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,Mahindra 3540 cab tractor loader F350 4x4 dump and lot of contracting tools
Offline ljohnsaw
« Reply #2 on: December 12, 2015, 01:32:26 PM »
Nice, I like the way you make all the scrap match up and balance aesthetically!
John Sawicky
Offline Tree Dan
  • I may be In Canada but my heart Is also In the U.S
« Reply #3 on: December 12, 2015, 06:41:19 PM »
Why would you not run the cable and your blocks to lift the front instead of the back? :P
Wood Mizer LT40HD, Kubota KX71, New Holland LS150, Case TR270
6400 John Deere/with loader,General 20" planer, Stihl 880, Stihl 361, Dolmar 460, Husqvarna 50  and a few shovels,
60" and 30" Log Rite cant hooks, 2 home built Tree Spades, Homemade log splitter
Offline Kbeitz
    • My Hobbies
« Reply #4 on: December 12, 2015, 07:00:23 PM »
Then what would lift the back ?
The 3 point lifts the front with the small forklift like blades.
This way both ends gets lifted off the ground.
Offline tnsnakebite
« Reply #5 on: December 12, 2015, 08:50:59 PM »
Great job.
I always look forward to your next project post.
Questions. I would like to try some welding. Its been years and never was good at it. Can I  get good welds with a setup running on 110 ? Limitations?  Advise on buying one?  Thanks.
2006 TimberKing 1220 20 H.P. Kohler. Trailer kit and 2 extensions. Purchase date 10-2015. Price-$3,300
J.D. 1070 w/loader
Offline sandsawmill14
  • love my job (most days)
« Reply #6 on: December 12, 2015, 09:22:25 PM »
 smiley_thumbsup
Offline Kbeitz
    • My Hobbies
« Reply #7 on: December 12, 2015, 09:39:46 PM »
Great job.
110 volt welders to me are not worth the time of day unless you buy one that cost around $1200.00
Even then the 110 volt one can pull 40 amps for the good ones. I would say don't waste your money.
If you don't want to waste your time to learn welding then go with a mig welder.
It's like using a glue gun. But the metal got to be real clean. If your using rusty junkyard metals then
I would say find your self a cheap 220 volt arc welder like the Lincoln tombstone welders.
And then make sure you get some really good rods. Cheap rods or welder will turn you off from trying
to learn to weld. If you have good rods and a good welder it's not hard to weld. Bad rod is a real nightmare
to try to use.
Offline tnsnakebite
« Reply #8 on: December 12, 2015, 10:46:51 PM »
Makes a whole lot of sense what you just said.
Thanks for the details.
J.D. 1070 w/loader
Offline kensfarm
  • Think!
« Reply #9 on: December 13, 2015, 12:56:13 AM »
I like that the box.. is also the for sale sign.
Offline Kbeitz
    • My Hobbies
« Reply #10 on: December 13, 2015, 01:05:34 AM »
I will be making more boxes.
Offline fishfighter
« Reply #11 on: December 13, 2015, 06:58:05 AM »
If I didn't live off the main road, I would have to set up something like that. It's a shame I burn most of my cutoffs.
Offline Arkyrick
  • Doing it since 2008
« Reply #12 on: December 13, 2015, 09:10:29 AM »
Great Idea what is the size of that box? and I notice you cut them into about 16" pieces?
LT 35 hydraulic portable "73"Ford 335 tractor - lots of chains
Offline Kbeitz
    • My Hobbies
« Reply #13 on: December 13, 2015, 01:03:32 PM »
4' x 4' x 4' cubed;
Offline ljohnsaw
« Reply #14 on: December 13, 2015, 01:45:20 PM »
4' x 4' x 4' cubed;
So you actually made the boxes from scratch (scrap).  I thought they looked a little bigger than pallets (48x42 here).  Yes, a half-cord of firewood for $30, a bargain ANYWHERE!  Even for pine, that would $75-100 out here.
John Sawicky
Offline Brad_bb
« Reply #15 on: December 13, 2015, 04:02:30 PM »
You are not letting them take the pallet assembly are you?  It takes some time to make those.
Offline beenthere
« Reply #16 on: December 13, 2015, 05:07:47 PM »
Brad
How would they take it?
Offline Kbeitz
    • My Hobbies
« Reply #17 on: December 13, 2015, 05:16:38 PM »
Nope they don't get the box and they need to load it from the box to there truck all by them selfs.
$30.00 does not seem like much but it keep my area clean and i get rid of all the junky wood.
I'm happy. $30.00 buys some blades.
Offline 21incher
« Reply #18 on: December 13, 2015, 06:35:58 PM »
Nice job, and you picked a good color paint. Have you made a machine to cut the slabs to lenght yet?  :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline Kbeitz
    • My Hobbies
« Reply #19 on: December 13, 2015, 10:30:59 PM »
Thats on my list.
For now I have a 12" chop saw at the end of 12 foot long rollers.
I'm looking for a dsah pot to use for my swing blade I want to build.
Anyone know what I could use for one. I think it would make useing a swing
blade so much safer.
Scrap Wood
Started by woodshax on Sawmills and Milling
Last post February 26, 2017, 03:02:48 PM
by Kbeitz
Scrap wood build
Started by tmarch on Sawmills and Milling
Last post September 01, 2015, 05:49:05 AM
by thecfarm
Doggy Condo out of Scrap Wood
Started by Busy Beaver Lumber on General Woodworking
Last post December 23, 2015, 01:40:26 AM
by Dave H.
Moving Wood'Lumber
Started by Stephen1 on General Board
Last post October 27, 2010, 06:06:41 AM
by fishpharmer
