Author Topic: Cooks Mfg.  (Read 1385 times)
Offline Josef
  • just horsin' around
Cooks Mfg.
« on: December 14, 2015, 07:41:53 PM »
Hi Guys,
just wanted to pass on an experience I recently had with Cooks dealing with a part on my nearly new cat claw sharpener. When changing a grinding wheel and profiling it I had the occasion to run the band advance gear motor without running the grinder motor. It was then that I noticed a pronounced grinding in the gear motor as it passed thru about 1/4 of it's rotation. Normally with the grinding motor running you can't hear the gear motor, so I had no idea how long it had been wearing like that. Shut it down and called Cooks, their number is right on the sharpener.
As with all sawmill manufacturers selling parts for their equipment I had to identify myself, they located me in their puter and we were good to go to order parts. Found out the gear motor is not repairable (no parts sold by Cooks) so the option was to order a whole new unit. After I heard the $300+ price I about had to sit down, so I took the next obvious path, is it covered under warranty. Answer, sure, for 12 months, lets see when you purchased yours, uh oh, that was 16 months ago. Dead end there.
Told the nice lady I'd have to do some more research and would call them back. That evening I decided to write a note to Cooks and sort of plead my case. I explained that though the machine was 16 months old, 4 months out of warranty I was a bit perplexed that a component as important and expensive as the gear motor had failed this soon, and that honestly I was a bit leery of purchasing an identical expensive replacement if it was of that questionable a quality. Could they assure me I wouldn't be in this same place 16 months from now.
Got back a nice note from Cooks, explaining that these gear motors have been in use for years, well into the thousands installed on Cooks sharpeners and a failure is quite rare. They went on to apologize for the equipment failure and said a replacement was on its way, that it would come with a return label so I could send back the defective part. No mention of the warranty period, no one pointing out that I was out of warranty by 4 months, just a very helpful staff standing behind their product and making me feel like a very important customer.
This entire process could have been handled in a way that "stuck to the letter of the law" and left me with a $300+ bill plus shipping and a bad taste in my mouth but Cooks, like the folks I have found here on the FF, are a class act and stood by their product and supported a customer when a part failed that should not have.
Kind of made my day,
Joe
In my house I'm the boss, I know this because my wife said so, I only hope she doesn't change her mind!
New to me Timber Harvester that I'm learning to operate, been building a home built mill for a while, should be ready to make sawdust with it someday if I ever quit "modifying" the design.
Offline Onthesauk
  • Still learning!
Re: Cooks Mfg.
« Reply #1 on: December 14, 2015, 07:49:00 PM »
That would make any ones day.  Good to hear!
John Deere 3038E
Sukuki LT-F500
Donít attribute irritating behavior to malevolence when mere stupidity will suffice as an explanation.
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
Re: Cooks Mfg.
« Reply #2 on: December 14, 2015, 08:02:47 PM »
That same thing happened with mine!  I think that mine is 5 months past warranty.  I meant to call them last week about it.  I wonder why it failed so suddenly?  It's a Dayton motor if I recall correctly.
Boy, back in my day..
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Cooks Mfg.
« Reply #3 on: December 14, 2015, 08:15:30 PM »
My guess.... Nothing made in usa anymore... We better get use to it...
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline reswire
Re: Cooks Mfg.
« Reply #4 on: December 14, 2015, 08:22:33 PM »
Sad, but true....
LT 40HDG 35, JD 5205, some Stihl saws, 15 goats, 10 chickens, 3 Chessies and a Weiner dog...
Offline pineywoods
Re: Cooks Mfg.
« Reply #5 on: December 14, 2015, 08:57:42 PM »
I'm not familiar with the cooks sharpener, does anybody know if that is the same gearmotor used on the woodmizer sharpeners ? If so, same motor on the mizer in/out arm and drag back. Usual mode of failure I have seen is a small roll pin that pins the final drive gear to the output shaft. Quick easy fix....
Online kelLOGg
Re: Cooks Mfg.
« Reply #6 on: December 14, 2015, 09:04:25 PM »
I've had their mill, sharpener and setter for 13 years and have had no failure issues. But lemons will occur from time to time; I'm not surprised they stand behind their products.
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Cooks Mfg.
« Reply #7 on: December 14, 2015, 09:05:55 PM »
Thanks Cook's.  smiley_clapping
Offline 4x4American
    • Website Link
Re: Cooks Mfg.
« Reply #8 on: December 14, 2015, 10:09:43 PM »
How do I fix it?
Offline losttheplot
Re: Cooks Mfg.
« Reply #9 on: December 14, 2015, 11:48:44 PM »
My gear motor was bad also.
It would not only grind the gears but the head would shudder as it was dropping down the face of the tooth.
There was nothing visually wrong inside the gear motor.
I was lucky and noticed before the year was up.
DON'T BELIEVE EVERYTHING YOU THINK !
Offline Kbeitz
    • My Hobbies
Offline 4x4American
    • Website Link
Re: Cooks Mfg.
« Reply #11 on: December 15, 2015, 07:07:08 AM »
That is exactly what mine is doing.  I found that by turning the speed up to 4 I didn't notice the shudder as much.
Offline Ox
  • Trying to learn/remember something new every day.
Re: Cooks Mfg.
« Reply #12 on: December 15, 2015, 10:51:49 AM »
After dealing with Cooks for a sharpener, single tooth setter and blades I really like the company.  They have the good old fashioned feel to their company and it's refreshing.  I'd love to try one of their mills.  Judging from the sharpener it would be super over built and rugged.
Offline pineywoods
Re: Cooks Mfg.
« Reply #13 on: December 15, 2015, 11:05:46 AM »
The label tells it all. It's a 90 volt dc motor, woodmizer uses a 12 volt.
Offline Chuck White
  • Sawing Mobile since 2005
Re: Cooks Mfg.
« Reply #14 on: December 15, 2015, 04:40:44 PM »
Looks like not only "shuddering", but there seems to be quite a wobble in it also, when the grinder is coming down.
Looks like there is something loose, like the allen head bolt or the large bolt that secures the grinder in place, other than that, the hinge pin or bearings might be worn out.
I've had mine since June of '09 and "knock-on-wood" I haven't had any problems with it!
Hope you get it figured out!
~Chuck~
Offline East ky logging
Re: Cooks Mfg.
« Reply #15 on: December 15, 2015, 08:45:12 PM »
I'm with ox on this. I got the sharpener and setter and they called a month later seeing if everything was going alright. I've never had a company care if it worked or not as long as the  check cleared. Best down home people I've ever dealt with.
Offline Furu
Re: Cooks Mfg.
« Reply #16 on: December 15, 2015, 08:49:41 PM »
Fantastic company and very knowledgeable brothers.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Cooks Mfg.
« Reply #17 on: December 15, 2015, 11:17:18 PM »
I replaced mine also, when still quite new and under warranty.  Been fine since.
HobbyHardwoodAlabama.com
Offline losttheplot
Re: Cooks Mfg.
« Reply #18 on: December 15, 2015, 11:17:37 PM »
I  think it is the slack in the gear motor, when the grind motor goes from being lifted to dropping it looks like it takes up the slack in the cogs. Perhaps there is more slack in some motors than others?
there is a set crew and lock nut on the outside of the gear motor you can try adjusting the slack.
Be careful.
if you put some constant load on the cam the shuddering and grinding go away,
Just to be clear
I have no problem with the service I have received from cooks
The videos are of the old motor. I used them to show cooks what was happening. I'm in Canada.
I sent them the old motor and they sent me a new one, I had to pay shipping both ways
The sharpener still seemed to work OK.
I noticed the problem after sharpening around 50 bands, I did not find anything loose, the camera can be deceiving.
The replacement motor did not make the grinding noise but the head still shudders on the drop. Its expensive to ship the motor back and forth so I live with it. seems to work OK.
Offline Ox
Re: Cooks Mfg.
« Reply #19 on: December 16, 2015, 07:52:12 AM »
I read you loud and clear.  In fact, if you said you got shoddy service from Cooks I'd be wondering to myself, "Just what did this guy do?!??   :D
East ky logging - I'd forgotten, but your post reminded me.  They called me too, asking if the sharpener and setter were performing up to expectations and to see if there was anything I needed.  Hardly ever happens today.  Real nice folks.  I hear great things about Woodmizer as well.  In fact, I'd bet a dollar that every sponsor on this forum is this way.  I can't see Jeff allowing a "lesser" company around here, judging from his character from just reading what he's written and never meeting him.  This place is one of my every day stops along with the news and email.
Cooks AC-36
Started by colby 92 on Sawmills and Milling
Last post June 11, 2018, 08:42:08 AM
by Alyeska Pete
cooks
Started by JB Griffin on Sawmills and Milling
Last post January 04, 2014, 10:45:21 PM
by 5quarter
Cooks Sawmill?
Started by Keithdgray on Sawmills and Milling
Last post January 05, 2013, 11:28:25 AM
by backwoods sawyer
Cooks guides
Started by onorato on Sawmills and Milling
Last post April 07, 2016, 10:15:08 PM
by onorato
