Author Topic: trailer decking  (Read 1993 times)
Offline trapper
trailer decking
« on: April 22, 2016, 10:45:38 PM »
My mechanic needs decking for his equipment trailer.  No oak available but have white ash.  Other than rotting sooner any other problems?  3X12 for the sides and thinner in the middle.
stihl ms241cm ms261cm  echo 310 400 suzuki  log arch made by stepson several Logrite tools woodmizer LT30
Offline ladylake
Re: trailer decking
« Reply #1 on: April 23, 2016, 05:33:40 AM »
 White ash will last almost as long as white oak so long as it's not wet all the time such as a post. I would use it anytime for decking.  Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
Re: trailer decking
« Reply #2 on: April 23, 2016, 07:43:27 AM »
Better to use the Ash before the bugs get it,
suggest he spray the sawn planks with used oil
before he mounts it,  should help the wet condition
Dan
Offline Skip
  • Saw hard or stay home.
Re: trailer decking
« Reply #3 on: April 23, 2016, 10:44:25 AM »
Red elm if you can get it, wont split easily cause of grain . doesn't rot fast #1 choice around here on pipeline trailers. growsers from the iron doesn't tear it up as fast as straight grain wood.
Offline sealark37
Re: trailer decking
« Reply #4 on: April 23, 2016, 04:51:56 PM »
Ash will work fine.  I would make the thickness uniform across the trailer.  Some oil treatment will extend the life of the deck.   Regards, Clark
Offline doug olsen
  • old enuff to know better
Re: trailer decking
« Reply #5 on: April 23, 2016, 08:53:31 PM »
Well, it appears that you or your friend have a choice of woods to use.
If I may suggest, what we do over here, in addition to the basic decking material, is use a softwood as sacrificial on top of the deck, where the tracks and grouser ride ( two stips,each two ft. wide). It is easier to replace these when damaged and holds the equipment better when chained down...IMHO
LT 15/portable trlr., 580 Case hoe/thumb, JD 570 Skidsteer (bkn.) 500 Rubicon quad
Offline dcress
Re: trailer decking
« Reply #6 on: April 21, 2019, 01:54:02 AM »
Just started milling new float deck boards yesterday. Birch 2-1/2" to 2-1/4" x 7-1/2" to 9-1/2". New float has oak decking. Never seen anyone use birch but from experience it should do well.
Offline Chuck White
  • Sawing Mobile since 2005
Re: trailer decking
« Reply #7 on: April 21, 2019, 09:49:51 AM »
I have sawn Beech, R/Oak, Hickory, W/Ash & Elm 2x8-10 for a couple of my customers!
Seemed to work out well for them!
I do believe that they sprayed it down with some kind of preservative or oil!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline doc henderson
Re: trailer decking
« Reply #8 on: April 21, 2019, 10:43:40 AM »
We have tons of huge cottonwood.  not rot resistant, but intertwined grain holds it together and it crushes instead of splitting.  Did some full on 2 x 8 x 18feet for a trailer to haul bulldozer about 4 years ago.  sprayed a little tung oil on it to repel water, holding up well and good use for a wood that many do not find useful for many things.  the trailer had rows on each side for the tracks, trailer was about 30 feet long.
timberking B 2000, 277c track loader, PJ 32 foot gooseneck, 1976 F700 state dump truck, JD 850 tractor.
Offline SFires
Re: trailer decking
« Reply #9 on: April 23, 2019, 03:43:45 PM »
Any wood that is stringy when trying to split (I.E. elm,hickory) makes great flooring .
A man can always use more tools, more space,more wood, and a whole lot more time.
Offline mbolt512
  • Just enough knowledge to be dangerous.
Re: trailer decking
« Reply #10 on: April 24, 2019, 07:40:46 AM »
This may be a dumb question, but would SweetGum work as trailer decking? It grows like a weed here.
Make do, do without or find a better way.
Offline WV Sawmiller
    • Green's Sawmill Services
Re: trailer decking
« Reply #11 on: April 24, 2019, 04:15:58 PM »
   Boy its stringy enough! But I don't know if your could ever get it to stay flat. I don't remember it being very weather resistant either. let us know what your find.
Trailer Decking
Started by 4x4American on General Woodworking
Last post January 26, 2015, 08:14:58 AM
by scsmith42
Trailer decking
Started by dail_h on Sawmills and Milling
Last post May 13, 2005, 06:41:10 AM
by woodmills1
My first trailer decking
Started by hackberry jake on Sawmills and Milling
Last post April 26, 2012, 03:43:30 PM
by Al_Smith
Trailer Decking
Started by 4x4American on Sawmills and Milling
Last post June 13, 2016, 11:38:37 PM
by barbender
