Author Topic: Sawed up some nice poplar today (video)  (Read 1733 times)
Offline 123maxbars
    • www.outofthewoodsforestry.com
« on: September 23, 2016, 07:32:37 PM »
Sawed up a good size poplar today for beams/post of a drying shed I am building.
Made a short video with a friend of mine supplying the tunes. Thought you guys would enjoy
Sawyer/Woodworker/Timber Harvester
W/M LT40HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Online WV Sawmiller
    • Green's Sawmill Services
Re: Sawed up some nice poplar today (video)
« Reply #1 on: September 23, 2016, 09:42:08 PM »
    Nice video. I love cutting poplar - probably most common wood I cut although salvaging dead and dying ash now. A couple of observations:
1. Your LT35 starter switch is in a different place than mine (Who cares right as long as it works).
2. I noted you swing the moveable bed into place before loading the log. Advice I received was to load the log, lift it with the rollers then swing the moveable rail into place, lower the rollers and start sawing. I was told dropping the log directly on to the moveable rails can damage them, apparently more so than the permanent rails.
3. I see you are much more diligent about sweeping the sawdust off the board/cant. Good on you. If you have not tried using a 12" wide dry wall scraper (I think I picked this up from the Magic Man) I suggest you try it. You can scrape the dust off as you walk beside the mill while cutting the next board. I tend to just try to blow the sawdust out of the stacked and stickered boards with a good leaf blower but you are probably removing more sawdust.
    Keep up the good work and keep those videos coming. (Maybe Dire Straits "Money for Nothing" should be our theme song :D).
Offline plowboyswr
« Reply #2 on: September 23, 2016, 10:15:03 PM »
 popcorn_smiley smiley_thumbsup keep smiley_paparazzi
Just an ole farm boy takin one day at a time.
Steve
Offline pineywoods
« Reply #3 on: September 23, 2016, 10:30:15 PM »
on item 2, they WILL break if sufficiently abused. Here's proof. Owner (not me ) elected to keep sawing without the swingout, now complains the bottom board is always thick on one end.
Offline larrydown60
« Reply #4 on: September 23, 2016, 11:33:35 PM »
Thanks for sharing another good video
Offline Czech_Made
« Reply #5 on: September 24, 2016, 08:56:26 AM »
Nice video.
Offline samandothers
« Reply #6 on: September 25, 2016, 07:51:08 PM »
Poplar I cut seems to move more than yours did.  Could be some of my logs were smaller and came off side of hill.  The stress caused stress!  :D
Offline 123maxbars
« Reply #7 on: September 25, 2016, 09:39:02 PM »
Great advice on the bed rail. I didn't know that. I appreciate the feedback on here as always!
outofthewoods
Youtube page
Out of the
Offline 123maxbars
« Reply #8 on: September 25, 2016, 09:39:56 PM »
I have noticed that the smaller juvenile poplar trees are full of stress and the larger ones (over 20in DBH) seem to behave better on the mill.
outofthewoods
Youtube page
Out of the
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #9 on: September 26, 2016, 07:49:26 AM »
Same here.  Much more growth stress in the small trees.  Small poplar can be one of the worst.
Offline drobertson
« Reply #10 on: September 26, 2016, 09:02:17 AM »
Thanks for sharing, the only poplar I've seen sawn was during the shoot out, and it seems just as explained here, some move a lot, while other logs behave. happy
Offline roghair
« Reply #11 on: September 26, 2016, 03:04:11 PM »
NIce video!
I was wondering; is this a typical feed speed or is it lower while the log is bigger?
On my home made manual mill I go much faster through the log (listened to Peter Drouin :) )
built a sawmill
Sawed some nice oak today
Started by cutterboy on Sawmills and Milling
Last post June 03, 2011, 08:08:53 AM
by Magicman
sawed 1000 bf of poplar today
Started by SCSawyer on Sawmills and Milling
Last post January 03, 2009, 06:02:27 PM
by SCSawyer
Sawed some nice white oak today.
Started by warren46 on Sawmills and Milling
Last post February 18, 2015, 08:30:33 PM
by Magicman
Got a nice free walnut tree today, harvested on video.
Started by 123maxbars on Sawmills and Milling
Last post February 22, 2017, 07:59:03 AM
by scully
