Author Topic: Using my Log Rite again to get logs to the sawmill  (Read 742 times)
Offline 123maxbars
    • www.outofthewoodsforestry.com
« on: April 26, 2017, 09:51:07 PM »
I had a few Walnut and Cherry trees given to me recently. The only catch was the landowner did not want any heavy equipment/bobcat etc on his property.
Once again my Log Rite ATV arch performed like a champ and got the timber to my trailer for hauling. I made a video showing the process.  It might look like a lot of work but was worth the effort.
Sawyer/Woodworker/Timber Harvester
W/M LT40HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Offline Brad_bb
Re: Using my Log Rite again to get logs to the sawmill
« Reply #1 on: April 26, 2017, 10:03:13 PM »
What was that greasing thing you were doing on the chain??
Online WV Sawmiller
    • Green's Sawmill Services
« Reply #2 on: April 26, 2017, 10:40:47 PM »
123,
   Nice video. I suggest hooking the winch to a chain around the trailer bar instead of just to the bar. From what i saw I was worried the hook could slip. Also I try to seal the ends of my logs as soon as I buck them to length. Looks like there was a 6-7 week gap on your dates for this.
   I saw some of your logs were dragging. I sometimes do this with my ATV and log arch because I need to extra drag coming down steep slopes but sometimes I lift them on to a dolly if it will tear up the ground or too much drag on more level ground. My arch is shorter than yours so I likely need to use the rear axle/dolly more than you would Here are pictures of my set up.
Here is my arch and ATV and the rear dolly on the ground.
Once lifted with the arch I slide the dolly under the log and cinch it tight with a ratchet strap. lower the log then go pick up the other end for towing. In this picture the dolly is closer to the center than on longer logs
Then I tow it to the log pile, undo the winch cable on front, pull the arch forward out of the way, undo the ratchet strap and roll the log over with my Logrite which frees my dolly for the next use.
Offline 123maxbars
« Reply #3 on: May 01, 2017, 09:52:58 AM »
Its a small grease gun sold at lowes. Oregon makes them, same company that does the chainsaw chains/bars etc.  It works on a pump release and is made for bars with port holes at the end.  Since my Stihl bars don't have that I like to add some extra grease to the chain before use.  Not sure its necessary but doesn't hurt either.
outofthewoods
Youtube page
Out of the
Offline 123maxbars
« Reply #4 on: May 01, 2017, 09:54:11 AM »
123,
That is  a nice set up. I like that log arch you got.  I usually do seal the ends after cutting but I didn't bring my anchorseal that day and got a little behind.
Thanks for sharing pics of your operation with your arch!
outofthewoods
Youtube page
Out of the
Moving logs from log pile to sawmill
Started by Rod on Sawmills and Milling
Last post May 17, 2004, 10:44:55 AM
by Swede
homemade sawmill nearly done but cant get any logs in connecticut???
Started by markct on Sawmills and Milling
Last post July 23, 2008, 05:49:45 AM
by mike_van
Big Bar Chainsaw For Prepping Big Logs For Sawmill
Started by Tree Dan on Chainsaws
Last post January 04, 2017, 06:58:31 PM
by Gwhunter
Log Rite does it RIGHT AGAIN!
Started by Kirk_Allen on Forestry and Logging
Last post January 14, 2006, 02:55:07 PM
by Frank_Pender
