Author Topic: Woodmizer ?  (Read 1536 times)
Offline raycon
Woodmizer ?
« on: December 17, 2004, 08:54:36 AM »
Whats a lot of hours when looking at used mills? (if the machine was poorly maintained low hours means nothing but...figured I'd ask)
Locally I've seen the hours range from 100 on a 2000 super to 6000 hours on a 97.
Was there any issues with the Lombardini diesel engine?
I've sort of spun out of control while looking into increasing HP and now I'm looking at used LT40HD super  equiped with the 40hp lombardini diesel.
Anyone remember a thread in which the year vs upgrades were listed for the woodmizer hydraulic mills? Like what year the hydraulic blade tensioner was added.
Thanks for any info
Lot of stuff..
Offline Percy
  • Resident trouble maker
Re: Woodmizer ?
« Reply #1 on: December 17, 2004, 09:17:03 AM »
A fella here in Terrace(Bruce Andrews) bought a 96 LT40 with the Lombardini. It had 1800 hours on it when he bought it. He has had to replace the head already as it was eating antifreeze. They(Woodmizer) seemed to have some problems with the Lombardini but I know of several that have well over 5000 hours on them with no problems......I was told by one owner that proper warmups and not shutting it down unless it was like lunchtime or quitting time, made all the difference along with proper maintenance. If it looked like the pevious owner wasnt up on his maintenace, Id offer less..... ;D
Re: Woodmizer ?
« Reply #2 on: December 17, 2004, 09:41:37 AM »
Those old woodmizer just keep on peddling. Yep, there was a concern with the Lombardini.
I started with a 24 horse Onan (Gasoline) and put over a million board feet on it.  It's hard to wear out the basic  mill.  The engine, as well as all the parts can be replaced
My mill stayed out in the weather 24/7 and that was its worse enemy.  Rust depleted some of the metal in the moveable parts of the dogs etc. the beam, rails, tower, bed and the rest of the frame has remained in good condition.   You will replace bearings, cam followers, belts, sheaves, switches and the like as maintenance anyway.  Even if the milll was poorly maintained, it will return to good condition just by your maintaining it.  You don't have to worry about "fixing" it too much.
There are things to check,   the swivel point of the engine where you tighten the belts to act as a clutch.  It is a shaft underneath the engine and opposite the tower that rides on bushings that wear.  Cam followers are the bearings that the tower and head ride upon and are in contact with the round rail.  they are above and below the beam.  Sheaves wear and cause even new belts to fit too deep in the groove to get a good purchase.  There are switchs, springs, solonoids and the like in the hydrauulic box that either work or don't.  The brass "buttons" that ride on the brass rail and transfer electricity to the hydraulics and ground against the bottom rail will wear and need replacement. Drum switches wear out.
Hydraulic band tensioning was pre-1990.
The hydraulics really came into being functionally about 1990.  The toe boards got rollers about 94 and other niceties added along and along.  The frame eventually was beefed up about 06 and The Super soon followed.  I don't have exact dates but that should give you a window.
Offline D._Frederick
Re: Woodmizer ?
« Reply #3 on: December 17, 2004, 10:01:46 AM »
Ray,
I had asked one of the WM people at a logging show why they had shifted away from using the Lombardini diesel engine, and was told that they were having a lot of bottom end failures. The Lombardini has a aluminum block which may not be rigid enough to with stand the stress of going from an idle to maximum rpm for each board cut.( Just my thoughts)  The engines now being used have cast iron blocks.
Offline raycon
Re: Woodmizer ?
« Reply #4 on: December 17, 2004, 11:08:21 AM »
Great info. Appreciate it.
Happy Holidays
Ray
Lot of stuff..
Woodmizer hydraulic mill and Woodmizer Edger
Started by Keith Edge on For Sale
Last post December 22, 2008, 08:11:51 AM
by Keith Edge
woodmizer
Started by Adesi P. willombe on Wanted
Last post December 07, 2011, 12:48:40 PM
by zopi
Woodmizer in Fl.
Started by 54Dutchman on Sawmills and Milling
Last post January 20, 2016, 05:18:46 PM
by Dave Shepard
woodmizer PA
Started by Tom L on Sawmills and Milling
Last post August 05, 2011, 09:50:04 AM
by Tom L
