Author Topic: LT40 Engine Pivot SQUEAK!  (Read 786 times)
Offline Ga Mtn Man
  • Y'all can call me GMM
« on: October 10, 2017, 09:41:03 AM »
I'm getting a loud squeak/groan from the engine pivot joint on my LT40.  I've sprayed everywhere I can find to spray with white lithium grease and it's still squeaking.  Need advice on where/how and what to lube with.
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline Percy
  • Resident trouble maker
Re: LT40 Engine Pivot SQUEAK!
« Reply #1 on: October 10, 2017, 10:36:49 AM »
Way back when I had an Lt40, my bushings squawked when they needed needed replacing. Mine were a clamped rubber affair with bronze bushings in them.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: October 10, 2017, 11:28:05 AM »
Be sure that it is the bushing and not any of the linkage that lifts the engine.  You will probably have to unload the bushing by using a jack/lift to take all of the engine weight off.
Offline Ga Mtn Man
« Reply #3 on: October 10, 2017, 03:29:44 PM »
Definitely coming from the pivot.  Take the weight off to do...?
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #4 on: October 10, 2017, 03:36:22 PM »
I replaced mine with the "all-metal" ones like BibbyMan did several years ago!
Not much of a job, but had to cut 1/4" off of the length of each of the bushings, did that with a hacksaw in the shop vice!
Look at "Useful Sawmill Mods" for BibbyMan's post.
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline drobertson
« Reply #5 on: October 10, 2017, 04:28:51 PM »
yep, they squeak, not sure to this day why a grease fitting was not put in play, it don't make much sense from a mechanical design stand point.  I used PB blaster, it helped,
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #6 on: October 10, 2017, 05:47:39 PM »
Can you drive wooden wedges under the engine to take the weight off the bushing to change it?
Mine never has started squeaking .......yet.
Offline Ga Mtn Man
« Reply #7 on: October 10, 2017, 06:31:10 PM »
My mill does get rained on occasionally...wonder if that makes a difference.  I'm going to give the PB Blaster a try first.  If that doesn't fix it then it'll have to wait a while.  Too busy to be taking the mill apart right now.  Besides, I can't hear it squeak when the engines running anyway.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #8 on: October 10, 2017, 09:11:32 PM »
Taking the weight off relieves the pressure points and will allow the lube to get where it needs to go.  I would use the white lithium grease.  Yours should have the aluminum blocks and not need any attention but obviously it does.
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #9 on: October 10, 2017, 09:34:51 PM »
Myn squeaked awhile ago too..I think I sprayed it with fluid film and it went away but it was so long ago I can't remember
Boy, back in my day..
LT40 voltage drop engine bog alternator belt squeak
Started by jovol on Sawmills and Milling
Last post January 13, 2019, 07:09:00 PM
by POSTON WIDEHEAD
Stihl 090 has squeak in engine.
Started by acco1840 on Chainsaws
Last post August 02, 2011, 07:07:00 PM
by sharkey
LT40 Carriage Feed Squeak
Started by Ga Mtn Man on Sawmills and Milling
Last post September 28, 2016, 12:45:34 PM
by derhntr
Replacing engine On LT40
Started by donnieb5213 on Sawmills and Milling
Last post November 02, 2018, 10:28:08 AM
by pineywoods
