Author Topic: Fuel mix preferences  (Read 3784 times)
Offline Al_Smith
Re: Fuel mix preferences
« Reply #20 on: February 03, 2018, 10:09:05 PM »
Some might say it leans the mix .However it's the ratio of fuel,meaning the fuel mix to air .Using that reasoning it would make sense to use straight gasoline and we all should know that won't work .--just saying---
Offline barbender
« Reply #21 on: February 03, 2018, 11:53:11 PM »
I've seen that reasoning before, Al, and it makes me think of all the saws I've seen that were lean seized from running a heavier oil ratio (zero)🙄🙄🙄😁
Offline Al_Smith
« Reply #22 on: February 04, 2018, 05:51:32 AM »
I seldom buy anything new but a few years ago I bit the bullet and bought a brand spanking new Stihl weed wacker .It came with a pack of Stihl ultra with the purchase with a recommended ratio of 50 to 1 which extended the warranty .So I ran it with the oil--at 32 to 1 ratio .Funny at that ratio the brand new Stihl plus 40 year old McCullochs  ran equally as well using that stuff at that ratio .They didn't smoke like they were burning soft coal either .--I luv the oil wars  8)
Online HolmenTree
« Reply #23 on: February 04, 2018, 09:54:08 AM »
Actually on the back of the Stihl Ultra bottle they recommend 32:1. 40:1  50:1
Offline Southside
« Reply #24 on: February 04, 2018, 09:32:42 PM »
I run my 372's at 32:1  - always have, always will.  For the past 5 years or better I have been using the gallon size 2 cycle marine injection oil that Wally World carries, it's blue and it's cheap, mix that with regular gas from the pump, E10 at most.  The way I see it if that stuff was good enough for my 671 cc Rotax powered muscle sled then it sure is good enough for a 72cc saw, and I have never damaged one doing it this way.
Offline Al_Smith
« Reply #25 on: February 08, 2018, 07:54:07 PM »
 :D They just carry on like a chainsaw is a vintage Roll-Royce or something .Run aviation gas,high octane rocket fuel ,oil at 100 to 1 ratios and so much stuff you could over load this server .Of course as is my nature my job is to heckle which I'm very good at .Truth be known I could care less what anybody does with their saws . 8)
Offline martyinmi
« Reply #26 on: February 08, 2018, 09:38:35 PM »
All octane does is prevent the spontaneous ignition of the fuel-air mixture as it is compressed.
Spontaneous ignition...or auto ignition?  ;D
No God, No Peace
Know God, Know Peace!
Offline John Mc
« Reply #27 on: February 08, 2018, 09:56:13 PM »
Took those words from a page explaining about Octane. They went further to explain that it would ignite from the compression alone, rather than needing a spark. (Now that you mention it, igniting from compression is not really "spontaneous")
Offline JohnW
« Reply #28 on: February 08, 2018, 10:35:09 PM »
John Mc, ignition from compression is still spontaneous combustion, according to the usual meaning of spontaneous combustion.  It's combustion, not according to the plan, or maybe combustion on its own timing, not by the spark plug.
Offline John Mc
« Reply #29 on: February 09, 2018, 08:17:59 AM »
I'm aware that the term is normally used that way. My comment was more an observation that it is an odd use of the word. It is not really "spontaneous" by the common (non-automotive/gas engine) use of the word. You compressed the mixture, it caused the mix to heat up and ignite. Nothing really "spontaneous" about that, even though it is not the intended method of ignition.
Online HolmenTree
« Reply #30 on: February 09, 2018, 09:05:03 AM »
My experiences in timbersports I've had "run away " saws.
Once had a Stihl 090 that I modified with high compression running a race fuel mixture.
After the last cut when I tried to shut it off it just kept going WOT. Pulled the spark plug boot off the plug it still kept screaming.
Ended up holding the throttle wide open until it cooled down enough to stop.
Red hot piece of carbon or something kept it going
Offline sablatnic
« Reply #31 on: February 09, 2018, 09:38:01 AM »
Same happened to me with a heavily modified Partner.
It just idled along with ignition turned off,  while I had time to unscrew the top cover and pull the wire off the plug. Kept idling without the wire for several minutes, till it had cooled off.
At the time we guessed that the spark plug or a piece of carbon kept warm enough to keep it running.
Offline Al_Smith
« Reply #32 on: February 09, 2018, 04:14:40 PM »
Oh goody Marty showed up . 8)
Offline Al_Smith
« Reply #33 on: February 09, 2018, 04:27:07 PM »
It wasn't a chainsaw but I once owned a 1973 Olds Toronado that would diesel enough you could drive it a city block before it would stop .455 cubic inch monster that loved gasoline .It was supposed to have a solenoid on the carb throttle plate to shut it completely off to prevent that .Evidently it didn't work so well .Got real stinky dieseling on gasoline,phew .
Now that engine was in the days of"low lead" not no lead .So perhaps the formulation of that stuff wasn't so good .It ran pretty good on Sunoco 260 though .
Offline thedoublejranch
  • 40+ acre timber farm
    • The Double J Ranch and Timber Farm
« Reply #34 on: February 09, 2018, 06:12:01 PM »
I just run what the manufacturer of the engine recommends. Works for me but I've only been using a chainsaw for the last 42 years so maybe I'm being foolish.
42 years ago, be hard pressed to find gas with alcohol in it, now its almost a normal thing. You have to actively search for alcohol free fuel now and the sources are very limited. That fuel creates havoc if you have saws that set with no use for a few months or more. If your saws run all year long, its a non issue as you stated.
To find alcohol free pump gas, try http://pure-gas.org
The Double J Ranch & Timber Farm.
Member "NWOA" National Woodland Owners Association"
Offline Enderslbz
  • saw lover
« Reply #35 on: February 11, 2018, 06:23:15 AM »
I've heared of scented fuel additives for the RC cars that run on the nitro methane stuff, never for a chainsaw though  ???
 Never tried an octane booster in the 2 strokes. I may try it in one of my older saws and see what it does.
OMG I love that smell, why would you ever want to cover it up  ???
Stihl 056AV MagnumII
Stihl MS 361
Stihl 261 C-M
Stihl MS 290 Farm Boss
Stihl 031AV
Homelite XL2
Homelite Super 2
McCulloch PowerMac 6
Offline JohnW
« Reply #36 on: February 11, 2018, 02:42:52 PM »
I have a couple octane questions, if I can borrow the post for a minute.  I suppose if the octane is too low, and you have run on when you turn your saw off, then the saw is probably also firing too early before top dead center, also, resulting in power loss.  Is that right?  I've been using 100LL in my saws (310, 372, and 395) but as people have pointed out, low lead aint no lead.  I should probably switch.  The 92 octane 50:1 premix stuff looks good.  On switching, I probably need to get my saws retuned, right?
Mallet Preferences
Started by rbowie on Timber Framing/Log construction
Last post November 29, 2012, 09:39:48 PM
by Aikenback
regional saw and bar size preferences
Started by Native Cutter on Chainsaws
Last post September 01, 2015, 01:54:43 PM
by Real1shepherd
engine oil preferences, mainly diesel, but any input?
Started by drobertson on Sawmills and Milling
Last post July 03, 2014, 11:14:12 PM
by LorenB
moved
MOVED: Rentech opens synthetic fuel plant in Colorado Jet & Diesel fuel
Started by Tom on General Board
Last post August 07, 2008, 11:11:44 AM
by Tom
