Author Topic: Does model MS261C have m-tronic?  (Read 3175 times)
Offline 4lane
« on: February 07, 2018, 10:55:10 AM »
I'm looking at a used MS261C. How can I tell if it has M-Tronic or not? I saw somewhere that the 'C' designation means it has m-tronic, but I've also seen where there was a 'C' model and a more expensive 'C-M' model. Can anyone help to clarify or let me know how I can physically tell if it has M-Tronic?
I see it does have a single position switch, instead of the normal two. Could this be the key to knowing it's an m-tronic? Thanks!
Offline khntr85
Re: Does model MS261C have m-tronic?
« Reply #1 on: February 07, 2018, 01:46:17 PM »
If it has carb adjustment screws, itís manual
If it has no carb adjustment screws itís m-tronic
Offline Ed
« Reply #2 on: February 07, 2018, 09:20:11 PM »
M-tronic.....
Ed
Offline ehp
  • logger/chainsaw hack
« Reply #3 on: February 07, 2018, 10:20:36 PM »
if top cover has holes in it so you can adjust the carb it should have a standard carb on it , no holes then it should be M tronic as long as its got the proper top cover on it
Offline upnut
  • Wood Tick
« Reply #4 on: February 08, 2018, 12:01:53 PM »
Simple, M-Tronic saws have a three position master control lever: Start, Run, and Stop. Non-M-tronic saws have the traditional Choke, Half-Choke, Run, and Stop. Stihl salesman pointed this out to me.  Scott B.
I did not fall, there was a GRAVITY SURGE!
Offline HolmenTree
« Reply #5 on: February 08, 2018, 05:40:18 PM »
I really like the 3 stage master control switch on my MS261CM.
No fiddling with that fast idle 4th step.
The Husqvarna 550XP with AutoTune has that 4th fast idle mode. A real annoyance after getting used to the 261CM.
Offline Grandpa
« Reply #6 on: February 08, 2018, 07:10:47 PM »
The M in the model # stands for m-tronic. As in 261 CM. A 261c should not be m-tronic.
Stihl's website explains it all.
Offline Ed
« Reply #7 on: February 08, 2018, 10:59:36 PM »
Ours is a 261C and is m-tronic......
Ed
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #8 on: February 08, 2018, 11:21:06 PM »
Thats how my ms 362c is labeled and its m-tronic.
Offline Grandpa
« Reply #9 on: February 09, 2018, 10:03:53 AM »
Now I'm confused. If you go to Stihl's  website and click on pro saws, the last sentence in the first paragraph explains what the letters in the model number mean. It says m means m-tronic.
I'm sure Ed and Joe know what they have, leaving me confused.
Can anyone explain this.
Perhaps Stihl changed their lettering system at some point. ???
« Reply #10 on: February 09, 2018, 11:43:15 AM »
On the side of the rewind housing it says 362c, on the powerhead plate/tag with the serial number it says 362 c-m. But when it was sitting on the shelf at the store the hand tag said it was just a 362 but it was miss labled and showed a cheaper price and a different size bar, so I ended up with $50 off the saw from a mistake.
Offline HolmenTree
« Reply #11 on: February 09, 2018, 11:46:28 AM »
I think the C on the saws rewind housing is just a shortened version for marketing and identification, plus save room.
Here's my MS261C with owner's manual that says MS 261 C-M.
Offline Grandpa
« Reply #12 on: February 09, 2018, 08:11:08 PM »
Thanks guys, I'm deconfused now.
What I get out of this is that the sticker on the starter doesn't mean much in regard to m-tronic.
Offline Enderslbz
  • saw lover
« Reply #13 on: February 11, 2018, 05:41:41 AM »
Yes, they are all labeled 261C on the recoil housing. Either pull the top cover and look for the wires or the lack of carb adjustment holes to indicate it is in all reality a C-M model. I have one and I'm pretty happy with it.
Stihl 056AV MagnumII
Stihl MS 361
Stihl 261 C-M
Stihl MS 290 Farm Boss
Stihl 031AV
Homelite XL2
Homelite Super 2
McCulloch PowerMac 6
ms261c vs ms261cm
Started by missedbass on Chainsaws
Last post March 03, 2018, 09:12:38 PM
by cb_cutter
Problems with a MS261C
Started by Mr_Meyrick on Chainsaws
Last post March 12, 2015, 04:37:50 PM
by Stihlnorm
Stihl MS261c or Husqvarna 555
Started by GriffLog on Chainsaws
Last post April 10, 2017, 03:56:27 AM
by NITRO313jh
MS261C - MS201TC or The MS 193T
Started by alabama on Chainsaws
Last post February 06, 2017, 03:38:26 PM
by Pembush
