KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Porch ceiling decking  (Read 531 times)
Offline samandothers
« on: February 07, 2018, 06:21:28 PM »
Need some input.
We are planing a timberframe home with white pine interior frame and either white pine or southern yellow pine ceiling tongue and groove.  We are planning on a white oak exterior frame for its resistance to natures wear.  We are still trying to determine what to use for the exterior 2x ceiling decking.  At this time we plan to use Heritage finish.
We have been all over the board with this.  We thought southern yellow pine on the exterior too as it looks nice and is harder than some other woods.  We wondered if cypress would be better in the exterior but this should not get wet nor see direct sun.  The look of Douglas fir is attractive.  Cost wise the southern yellow pine is the most economical.  The cypress is more pricey, over 2x the cost per board foot which is a definite consideration.  Hopefully with the tung and linseed oil finish the carpenter bees will not be as attracted and find easier/softer munchies elsewhere.
Thoughts?
Offline Don P
    • Calculator Index
Re: Porch ceiling decking
« Reply #1 on: February 07, 2018, 07:22:05 PM »
From my experience they only munch on the edge of the overhang not on the ceiling itself. I've put up lots of EWP porch ceiling as well. Neither tung nor linseed oil is tough enough to stop their jaws. Heavy paint, maybe, maybe Sikkens would if you can tolerate the application fumes. The fascia, projecting beams, 1st purlin, protected but that outer edge is where they want to nest though.
Offline firefighter ontheside
  • I like trees.
« Reply #2 on: February 07, 2018, 08:28:34 PM »
My log home is stained with Sikkens Cetol 1 and 2/3 plus.  It does seem to deter the carpenter bees.  My soffits are SPF and the bees get into that pretty bad, but its not stained.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
« Reply #3 on: February 08, 2018, 09:11:51 AM »
Seems there is no magic bullet for the bees.  Though I was trying to find a wood or finish that may help.  I have had some pretty good luck with hanging some bee traps on the corners of the barn.  Maybe I just pretty some up with fancier plastic bottles!   ;D
Thanks for the feed back.  Maybe we just experiment with some color tints and ultimately choose a finish and wood we like versus trying to find a wood that deters the little critters.
Offline Don P
    • Calculator Index
« Reply #4 on: February 08, 2018, 06:57:00 PM »
I've come to appreciate cement fascia  :)
« Reply #5 on: February 08, 2018, 10:29:30 PM »
Harder it is I recon adds to discourage bees are any others chewing vermin!  I need to supply easy pickings soft wood homes so the little buggers dont have to gnaw on the harder stuff.
cedar porch ceiling......seal?
Started by dablack on General Woodworking
Last post April 07, 2013, 10:34:56 PM
by PC-Urban-Sawyer
Next exterior ceiling ideas for a porch
Started by 412jason on Timber Framing/Log construction
Last post January 06, 2015, 12:38:43 AM
by beenthere
Decking and Ceiling Recomendations?
Started by jander3 on Timber Framing/Log construction
Last post May 18, 2010, 01:42:26 PM
by Raphael
wpc / plastic composite decking vs real hardwood/ wood decking
Started by harrymontana on Forestry and Logging
Last post January 19, 2013, 10:54:54 AM
by Dom
