Author Topic: Parbuckle Trailer - Hinge Design Question  (Read 3106 times)
Offline OffGrid973
  • Off Grid
Re: Parbuckle Trailer - Hinge Design Question
« Reply #20 on: November 29, 2018, 03:50:33 PM »
Had one come over the side dead lift and the larger walnut had to roll up the back after taking off 250lbs of forking so it could roll.  This was first big test for the crane and it worked like a charm.  Those cedar were left over and deck is 13 for idea of size.
Thanks again for all the advice folks, crane = happy back
Your Fellow Woodworker,
- Off Grid
Offline Downstream
« Reply #21 on: November 29, 2018, 08:09:36 PM »
Very nice set-up.  How much is that crane rated for?  It looks pretty heavy duty.  Does it have a stabilizer leg or do you support that corner of the trailer when lifting?
EZ Boardwalk Jr,  Granberg Alaskan Chainsaw Mill, Stihl 660 and 211, Logrite 60" cant hook, Dixie 32 Tongs
Offline OffGrid973
  • Off Grid
« Reply #22 on: December 04, 2018, 07:22:22 PM »
Rated for 2,800lbs and when the boom is up the winch can really pull an amazing amount...there is a drop trailer leveler on the other side to try and position support on both sides of the crane when I drop the normal trailer foot.  Gives it 5 points of contact including the pintle hook.
If you can find a crane for $500 like I did I believe its a great deal.
- Off Grid
Online Sixacresand
  • John and Nancy
« Reply #23 on: December 04, 2018, 09:21:54 PM »
Side Parbuckling logs with a winch onto raised beams on blocks on the trailer floor.  My ramps are 6 inch steel pipe hook over the the trailer rails.  Unloading is quick and easy.  Just roll them off.  Just need to have a detachable fender for loading and unloading.
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #24 on: December 08, 2018, 01:09:07 PM »
I installed a hydraulic winch on the front end of my trailer and connected into the trailer hydraulic powerpack.   When I use it I have a couple big oak beams that I use for ramps.  The winch cable runs out to the back center of the trailer through a snatch block, back to a second snatch block on the side opposite of where I set the ramps.   This keeps the cable from bunching up on the winch.    I've easily loaded logs up to 10k - 12K lbs this way.
Sometime in the next week or two I am going to pick up a couple of 16' 42" diameter Red Oaks using this setup.   I'll try and get a few pictures of it in use.
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #25 on: December 08, 2018, 02:24:17 PM »
This is my way of loading.
Another.
Online mike_belben
  • Pulp Friction
« Reply #26 on: December 08, 2018, 02:50:30 PM »
Before my gooseneck tore up i made this pulley rig out of some scrap and a wheelbarrow rim i stepped on out in the woods.  The winch is on my bobcat grapple and id only use it for the logs it couldnt forkload.  The ramps are notched to hook onto the rub rail.
Revelation 3:20
Offline goose63
« Reply #27 on: December 08, 2018, 05:18:41 PM »
This my set up with75 feet of cable on the winch for extra reach
goose
thank you to all the vets
Design me a trailer!
Started by Night Raider on Sawmills and Milling
Last post January 12, 2009, 08:32:11 PM
by Meadows Miller
Need ATV Trailer Design Ideas
Started by jander3 on General Board
Last post March 28, 2009, 08:19:12 AM
by frndly neighborhd loger
LT15 Custom Trailer Design - Feedback Needed
Started by kng on Sawmills and Milling
Last post September 06, 2016, 03:04:33 PM
by kng
recycled
Foundation design question
Started by scgargoyle on Timber Framing/Log construction
Last post December 20, 2007, 05:33:33 AM
by scgargoyle
