Author Topic: John Deere 2010 Tractor  (Read 4086 times)
Online Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« on: February 08, 2018, 08:01:23 PM »
I understand and agree to the terms of selling items on the FF :)
  I don't know the year because the serial # plate is gone.  It was long gone when we got it in 2004 or 05. It's an early one because it has a cartridge oil filter.  Later models have a spin on.  I was always going to check the engine serial # for the year but never did.  The hours are original at 3013.  The tach and hour meter do work.  Gas gauge works sometimes.  Bad ground?  Lights don't work but are all there.  I think the switch is bad.  Hydraulics and three point work good as does the power steering.  Shifting linkage has the typical wear of this vintage.  It'll pop out of a couple gears if you don't get it just right.  Needs bushings or something in the linkage.  Not a transmission issue.  Park works.  Rollamatic front end with new tires with one new rim and one used one.  Old tires and rims were 14" and no longer available.  It's got 15s now.  Back tires are matched and I'm quite sure are original but are in pretty good shape.  No rust through on the fenders.  Straight sheet metal.  Petronix electronic ignition.  Valve job wouldn't hurt it any.  It needs its carb cleaned now I'm sure.  I'll get it out, make sure it's running good get more pictures once the weather moderates a bit.  Twelve for a high today.
Online Corley5
    • Whittaker Farms
Re: John Deere 2010
« Reply #1 on: February 09, 2018, 08:05:10 AM »
  It's not listed anywhere else and won't be until I get it out and have it running.  I haven't set a price yet either.  Make an offer if you're serious.
  The battery's up on it but I'm not going to try to start it until it's warmer.  Tractor is original.  It's never been repainted.  No top link.
Offline David-L
  • present and accounted for.
Re: John Deere 2010 Tractor
« Reply #2 on: March 01, 2018, 07:41:09 AM »
Nice Deere. I have had a 720, 2155,2355,2950. How much if you get it running. Need a dedicated wood splitter tractor. Light small scale haying also, sickle bar NH451.
Online Corley5
    • Whittaker Farms
« Reply #3 on: March 01, 2018, 09:23:26 AM »
Like this?  Great match for a 2010 :)  I'm thinking around the $3,000.00 mark.  I haven't had time to get it out.  Maybe next week :-\
Offline David-L
« Reply #4 on: March 04, 2018, 04:05:23 PM »
Would do the trick. Is that like 35 40 hp. Let me know, might pursue.
Offline starmac
« Reply #5 on: March 04, 2018, 06:18:54 PM »
The way I figure it, the prices 8 and 9N fords bring that would be a steal, quite a bit more tractor as far as I am concerned. I do prefer the wide frontends though.
Online Corley5
    • Whittaker Farms
« Reply #6 on: March 04, 2018, 07:48:46 PM »
45 horses 8)
Online Corley5
    • Whittaker Farms
« Reply #7 on: March 04, 2018, 07:58:35 PM »
  I used it to run a New Holland BR 730 round baler and a New Holland 488 conditioner.  It is a nice tractor :) :)  Just doesn't fit my operation anymore.
  Back tires have never had fluid in them 8) 8)
Offline chet
« Reply #8 on: March 05, 2018, 04:59:47 PM »
I would have snatched it up a few years ago when I needed a doner engine for my 2010 Dozer. Worked out ok, as I was able to find it's larger rare HA165G sister engine.  8)
I am a true TREE HUGGER, if I didnt I would fall out!  chet the arborist
Online Corley5
    • Whittaker Farms
« Reply #9 on: May 18, 2018, 01:19:34 PM »
I put a new set of spark plugs in it and she runs good.  I've got it listed for $4,000.00 on Craigslist and Yesterday's Tractors.
r>
Online Corley5
    • Whittaker Farms
« Reply #10 on: May 19, 2018, 03:18:24 PM »
Just because I've got it listed elsewhere for 4 thousand doesn't mean I won't take less.  I mentioned the $3,000.00 neighborhood earlier.  I'd like a bit more than that ;) ;D  Make an offer see where it goes.  It's a nice tractor.  I hope somebody buys it before I get some crazy idea and decide to keep it.
Online Corley5
    • Whittaker Farms
« Reply #11 on: May 29, 2018, 12:18:43 PM »
It's gone.  CL buyer from Mesick hauled it away this morning.
John Deere 2010 Crawler
Started by g_man on Forestry and Logging
Last post October 09, 2011, 01:18:38 PM
by timbuck2
John Deere 2010 ROPS
Started by Crusarius on General Board
Last post May 01, 2017, 08:59:24 AM
by maple flats
1962 John Deere 2010 Backhoe
Started by in10sity on General Board
Last post April 24, 2013, 08:39:25 PM
by Peter Drouin
4 x 4 John Deere Tractor bearings.
Started by Bogue Chitto on Forestry and Logging
Last post April 10, 2012, 03:37:37 PM
by Bogue Chitto
