Author Topic: Minor Problem with 2005 LT15  (Read 2350 times)
Offline firefighter ontheside
  • I like trees.
Re: Minor Problem with 2005 LT15
« Reply #20 on: February 15, 2018, 12:55:12 PM »
Thanks Sparks!
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Offline Brad_bb
« Reply #21 on: February 20, 2019, 09:37:31 AM »
Felt in various thickness is sold by Grainger and McMaster Carr.  There is some on ebay, but it's not as organized to find the thickness and strips or sheets you're looking for.
Offline Woodpecker52
« Reply #22 on: February 20, 2019, 06:42:08 PM »
I put 2 beads of ATF down the felt length and blow it off at the end of the day.  I also added brushes to the ends to move more sawdust from the rails.  One thing I also added which has really worked and I no longer have to scrape my belts anymore is simple brushes that just lightly touch the free ends of the belts.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
« Reply #23 on: February 20, 2019, 06:53:52 PM »
Other wheel belt brush
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #24 on: February 20, 2019, 06:58:34 PM »
WP52,
   I like that idea about the brush cleaning the belts. I may have to see about adding something like that. Its so common sense it makes you wonder why it isn't just a normal part of the mill.
« Reply #25 on: February 20, 2019, 10:31:37 PM »
I have them on my Grizzly bandsaw in my shop.  I got so tired of stopping after each log to clean the belts especially after using water lube, it was part of the routine, since I put them on the mill  I have not had to clean the belts once!! even when cutting pine.  The thing is the brush is just a shoe brush and the bristles are very soft, I think that it does not deform the belts ability to flex like it should at the free end of rotation but  just enough lite contact to keep the dust from being compacted on the next rotation, one of the best things I did so far.
Offline Escavader
  • Sawmill/Planermill operator since1984
« Reply #26 on: February 21, 2019, 06:52:49 PM »
Felts absolutely sucked on mp100.shavings on track a night mare.added an exhaust 60 percent better.strapped a board to deflect it another 30 percent better .still getting it on further track.ive making a hookup for a low volumn air line to blow off as i go.
  Havent had issues with lt 15 yet
Alan Bickford
Hammond lumber company/Yates American A20 planer with dbl profilers Newman feed table multiple saw trimmer destacker automatic stacking machine Baker resaw MS log corner machine  4 large capacity Nyles dehumidification kilns JCB 8000 lb forklifts woodmizer lt 15 and mp100 and blower
Offline booman
« Reply #27 on: February 21, 2019, 07:44:18 PM »
Woodpecker, what is the blue gear and chain shown in your pictures?   Is that an LT15?
Offline booman
« Reply #28 on: February 21, 2019, 07:57:43 PM »
What I have used for my LT15 is a strip cut from an old heat shield and sound deadener mat I had and spray some Permatex headliner and carpet adhesive on both areas and then stick them together.  Never had one come loose.  Of course you need to put some atf on it.
« Reply #29 on: February 21, 2019, 08:30:45 PM »
I added a chain drive system to the lT15 and since it is stationary went with a gear motor and ac 1hp motor.  So I had problems with thermal switches with starting and reversing the ac motor ( the duty cycles not made for this they like continuous operation)  So It dawned on me I only need to catch a ride on the chain anyway and  since it is faster to pull back head, hence the blue sprocket which I simply drop into the chain channel and catch a ride on the chain, when I am through with the cut I pull up the sprocket and pull the head back then start the cut by hand then drop the spocket.  I have cut switches at ends of mill and on the head.  The chain I can leave running in one direction  all the time, no start, stop reverse and the problems blown fuses etc. just simple on off.  It is simple, is as easy as changing gears on a bike, If the log cut is to hard and starts to bog engine, I just disengage and finish by hand, and adjust speed elsewhere ( I can adjust pulleys or change speed by controller)  If I just want to cut by hand I can just raise sprocket, the chain runs in a square channel that fit perfect under the head beam and lock pins. You can see the system on my gallery page and past posts.
Offline Brad_bb
« Reply #30 on: February 21, 2019, 08:37:53 PM »
Escavater, how about some pics of what you are talking about.  I have an MP100 also.  Been using it since 2014.  I have a blower sucking chips and spitting them in a giant box in the next room (which is the dusty half of the pole barn).  Interested in what you mean my exhaust and how you use a board?
« Reply #31 on: February 21, 2019, 08:43:17 PM »
Last picture then I will shut up!
Online beav
  • got any logs?
« Reply #32 on: February 21, 2019, 09:30:38 PM »
Woodpecker:
Early woodmizers had a sprocket at each end like you have untill they got sued when someone's fingers didn't quite make it around the sprocket. Some sprocket covers might be a good idea?
« Reply #33 on: February 22, 2019, 10:41:21 AM »
I added sheet metal shields at each end and the middle sprockets have a shield also.  They would certainly take a finger smooth off!  The gear motor itself was used to lift heavy warehouse doors, there is no stopping it except by killing power hence kill switch at each end and on rig head by handle I have a Dayton long handle switch.  I never send the head down by itself but walk and monitor cut with hand on handle.
  • I like trees.
« Reply #34 on: February 22, 2019, 12:25:16 PM »
Did you ever see a topic and open it because it might interest you only to find out it was a topic you started last year.  Well, that just happened to me.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Offline Brad_bb
« Reply #35 on: February 22, 2019, 04:22:55 PM »
My fault.  I need some felt for a project and I remembered in one post someone said something about using felt from a tractor supply or farm and fleet and was searching for what it was from.  Couldn't find the exact post I was looking for when I came across this one talking about using felt to repair the rail wipers on the mill.  Then I found a better source via Grainger and McMaster Carr so I added that info to the post for anyone that is looking for felt in the future.  But then some other made some new content and posts....  That's happened to me too, but sometimes it's a post I never saw, or forgot the good info in there, so it was worth the re-read.  ;D
« Reply #36 on: February 22, 2019, 05:11:59 PM »
wonder if magicmans  has the same thought with What you sawin!
Minor CBN Grinder Problem (I think)
Started by Bandmill Bandit on General Woodworking
Last post February 12, 2012, 05:26:05 PM
by Clam77
TIMBERJACK 560D help (minor problem)
Started by CCC4 on Forestry and Logging
Last post December 29, 2012, 06:33:26 PM
by CCC4
Minor to major Forest Health problem
Started by chain on Ask The Forester
Last post February 05, 2010, 09:20:42 PM
by chain
Short logs on a 2005 LT15
Started by firefighter ontheside on Sawmills and Milling
Last post August 21, 2018, 09:21:34 AM
by bwstout
