Draw for handbuilt acoustic guitar get your name in
BRUTE FORCE Authorized Dealer
Council Tool
Author Topic: Log diameter for quarter sawing, species  (Read 1577 times)
Offline climber2
  • We are nothing compared to trees...
« on: February 11, 2018, 08:54:18 AM »
In having conversation with a carpenter regarding quatersawn lumber he mentioned that you can only do very large logs effectively. Also he said only oak is what people are milling this way...
There are many people on here with vast experience so I figured I would ask... I'm guessing this has been hashed a few times before in some manner but here goes.
What is the minimum diameter you will attempt quartersawing a log?
What species other than oak will you quartersaw and get unique character in the lumber?
Timber Harvester 36htd25, 06 Ram 2500 5.9, 95 Chev 3500hd, 445ct Bobcat w/ Wallenstein winch, Bandit 200+, Morbark M12r, Countless chainsaws...
Offline AdamT
Re: Log diameter for quarter sawing, species
« Reply #1 on: February 11, 2018, 09:29:20 AM »
The mill that I buy logs for only quarter saws white oak. 18Ē min, lengths from 8-12í. We really want them 20Ē and bigger though.
We have quarter sawn some red oak in the past. But itís been a while.
2017 Wood-Mizer LT40HDD35-RA
2011 Wood-Mizer LT40 HD
It's better to have it and not need it then it is to need it and not have it
Offline Southside logger
« Reply #2 on: February 11, 2018, 09:44:09 AM »
Sycamore is absolutely beautiful when quarter sawn.
Woodmizer LT35 sawmill, KD250 kiln, BMS 250 sharpener and setter
Offline scully
  • Orange Mills Matter
« Reply #3 on: February 11, 2018, 09:52:11 AM »
Oak ,cherry, sycamore are 3 types that yield nice figure when quarter sawn . I have done 16"dia but that is kind of small . 20" and bigger is always better .
I bleed orange  .
Offline firefighter ontheside
  • I like trees.
« Reply #4 on: February 11, 2018, 09:55:11 AM »
Personally I have only intentionally quartersawn sycamore and it is striking.  You can q saw maple and cherry and get good figure as well.  Itís worth mentioning that any wood when quartersawn is more stable and it can be done just for the stability of the lumber.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #5 on: February 11, 2018, 09:57:30 AM »
I agree with previous responses.    18" minimum,   there it to much waste on smaller diameter.   And, sycamore quarter sawn is fantastic.
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Offline Brad_S.
« Reply #6 on: February 11, 2018, 10:47:37 AM »
 Are usually donít do anything below 20 inches in diameter. While Maple and cherry do show some fleck, I think they are better plain sawn with the cathedrals centered. As mentioned, Sycamore is spectacular! I also like to quarter saw white pine if I am using it as beadboard wainscoting. I prefer to have the long vertical stripes in the boards.
Online Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #7 on: February 11, 2018, 11:17:31 AM »
Iíve qs Sitka spruce for a customer who is building a mast for a sail boat. Before I had a mill of my own, acquired some wrc that was qs into 1/4x1Ē strips for a strip built boats that I was building, but as mentioned above, both of these situations were for stability.
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #8 on: February 11, 2018, 12:12:40 PM »
I quarter sawed a 30" X 12' black oak a few years back with fantastic results.  This was before I learned about the RRQS method so I quartered the log and cut off the bottom, flipping the log between cuts. Got more riff sawn pieces this way.
1992 LT40HD
Offline DDW_OR
« Reply #9 on: February 11, 2018, 03:19:35 PM »
Reverse Roll Quarter Sawing
http://forestryforum.com/board/index.php/topic,93851.0.html
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline climber2
« Reply #10 on: February 11, 2018, 04:53:31 PM »
Pretty interesting. I don't know much on sycamore as we don't get any around here.
I've witnessed the flecks in Maple cuts before when the grain allows while milling sugar maple.
Has anyone had experience with Yellow Birch or hemlock? Those two have had me wondering for awhile...
Thanks for the replies!
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #11 on: February 11, 2018, 06:50:09 PM »
In over nearly 35 years of cabinet-making, furniture building/restoration and home remodeling, I've seen several different species that were quarter sawn.  Oak, southern yellow pine, cypress, Douglas fir, cherry and walnut all come to mind.  Quite a bit was quarter sawn for dimensional stability as much as for the figure in the wood.  The increase in value is greater with certain species than others, oak being one.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher
Offline longtime lurker
« Reply #12 on: February 12, 2018, 06:44:40 AM »
Depends on species and application. I'll "quarter saw" for flooring material in some hardwoods down to a 12" top... at that size a through and through pattern will give a pretty high yield of 4 x 1 at rift to quarter. With collapse prone eucalypts backsawn material tends to suffer pretty badly so its the best way to go.Besides what else can you cut from logs that small... you gets to either quarter cut them or backsaw them but its just a matter of whether you want your boards to cup or spring. And they'll cut a nice enough little board if you do it right... slab and a board off the top, slab and a board off the bottom, split the pith *gasp*, and just slice them off in inch thick pieces and nail them into the edgerman looking like bananas... result is good stable straight boards that'll fetch a market premium from horrible little logs.
(Thats me in saws em and leaves em mode... probably why it dont happen often... my perfectionist tendencies mean i got to carry to much jumk with me to do things right. Eucalyptus grandis - Rose Gum - usually sold in the states as "Rose/Red Grandis"... things i can do with 12" logs that no-one else is silly enough to touch :D)
Cabinet species same - I can get enough premium for some of them as quarter sawn 4's to make it more attractive then backsawing the little bits of snot.
Mostly though the good things start to happen around the 22" mark, in terms of pattern flexibility to give a yield of predominantly quarter cut boards and hold some width on them. Aint no money in fancy looking 3" wide boards regardless of what you cut them from.
Offline climber2
« Reply #13 on: February 12, 2018, 11:02:28 AM »
Thanks for the pics and insight. QS is pretty much new to me as I try to turn trees I remove into something usable.
Anymore thoughts will be appreciated, as always.
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #14 on: February 12, 2018, 10:35:09 PM »
I typically won't QS something unless it's decent sized, such as these.
HobbyHardwoodAlabama.com
Offline climber2
« Reply #15 on: February 12, 2018, 11:07:14 PM »
Them are some fatties yellowhammer!
What species are they?
  • I like trees.
« Reply #16 on: February 13, 2018, 08:22:59 AM »
Looks like sycamore.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
« Reply #17 on: February 13, 2018, 09:59:53 AM »
The ones on the trailer are Sycamore, the log my dog Chip is standing on is a 5'4" diameter, 1,450 bdft red oak.
Offline climber2
« Reply #18 on: February 13, 2018, 10:09:30 AM »
That would explain my inability to recognize it, sycamore does not exist here. Maybe you would see it in the southern half of the state but still rate.
Offline D6c
« Reply #19 on: February 13, 2018, 11:08:01 AM »
I quarter sawed a cottonwood a while back.  Not for cosmetic reasons but for stability.  I used it for decking on the pallet racking in my barn.  Qtr. sawed lumber doesn't cup like flat sawed can.  Made some nice straight grain boards.
Offline buzywoodliff
  • It could ALWAYS be worse
« Reply #20 on: February 13, 2018, 12:54:46 PM »
Glad to see all the comments about stability.... i'm no expert, but I thought that was the main purpose, with sweet grain pattern being a bonus.
Offline Ianab
« Reply #21 on: February 13, 2018, 01:34:06 PM »
Like LL says, there are some species that will really misbehave badly if you flat saw them, but can make useable (although narrow) quartersawn boards. As well as the eucalyptus species he mentioned I've found Sheoak (Australian pine) works a LOT better q-sawn, even with logs under 18". With a swing blade mill it's no more work to cut a 1x6 or a 6x1
sawing 3to 4in diameter cedar
Started by fivedogs on Sawmills and Milling
Last post April 12, 2013, 11:12:33 PM
by fivedogs
Quarter sawing!
Started by PM on Sawmills and Milling
Last post December 27, 2007, 10:51:45 PM
by Dan_Shade
QUARTER SAWING
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post May 07, 2012, 06:11:30 PM
by Ga Mtn Man
Quarter sawing
Started by peterduncan on Sawmills and Milling
Last post June 29, 2008, 10:11:23 AM
by MemphisLogger
