Council Tool
Author Topic: Steel wheels vs belted wheels for winter sawing  (Read 2382 times)
Offline climber2
  • We are nothing compared to trees...
« on: February 12, 2018, 11:07:27 AM »
As I continue researching mills for an upgrade thighs keep crossing my mind. This topic is one for sure to consider as I do most of my sawing in the winter months. This may seem strange but it's when I have the time to do it.
If you have some insight, please share it. Maybe there is no difference...
Timber Harvester 36htd25, 06 Ram 2500 5.9, 95 Chev 3500hd, 445ct Bobcat w/ Wallenstein winch, Bandit 200+, Morbark M12r, Countless chainsaws...
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Steel wheels vs belted wheels for winter sawing
« Reply #1 on: February 12, 2018, 11:30:03 AM »
I have had zero problems sawing with belted bandwheels other than one instance of clumps of larch pitch under ther belt.
Wood-Mizer LT40HDD51-WR Wireless, Kubota L48, Honda Rincon 650, TJ208 G-S, and a 60"Logrite!
Offline Doug Wis
« Reply #2 on: February 12, 2018, 12:43:38 PM »
   I do the bulk of my sawing in the winter and have had both. 1st mill was a Kennerbilt  with steel wheels and then upgraded to a TK 1600 with tight belted wheel. After tiring of the hassel of changing the tight belts, I switched to using the loose belts[B57 vs B56}. I don't saw a whole lot and am a long way from a pro at it, but I haven't noticed any difference between the 3 types of wheels. Actually never even thought of it till I read your post.
A man who says he can do everything at 65 that he did at 25 sure wasn't doing much at 25.
Offline moodnacreek
  • Sawin by the notches
« Reply #3 on: February 12, 2018, 12:44:25 PM »
Log sawing is not supposed to be done in spring or summer. You will always get better lumber sawn in the winter.
Offline Larry
« Reply #4 on: February 12, 2018, 03:35:03 PM »
No difference that I can tell.  Belts can get destroyed on the first log or last for 300 hours.  Steel runs for a few thousand hours before needing attention.
Offline JB Griffin
« Reply #5 on: February 12, 2018, 08:50:43 PM »
Steel at work, belted at home. Much much much perfer the steel.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
    • My homepage
« Reply #6 on: February 12, 2018, 08:54:53 PM »
What do you see as the advantage to the steel wheels? I've only run the 40 series WM.
Offline JB Griffin
« Reply #7 on: February 12, 2018, 09:07:12 PM »
Everything, their actually balanced and turned true with very little run out, no belt for junk to get under or replace, the crown lasts for 600mbf+, impossible with a belted wheel period. Not to say that belted wheels won't work, they obviously do, just not as well.
Offline kelLOGg
  • More is better but enough is best
« Reply #8 on: February 13, 2018, 12:52:42 PM »
You're right about the trueness of steel wheels. I had mine recrowned a few years ago and measured the runout when I installed them. less than 0.001 inches.
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline SineWave
« Reply #9 on: February 13, 2018, 05:04:50 PM »
Holy cow, a quarter of the thickness of a human hair...that's TRUE!
Offline Alyeska Pete
  • Location: In the Catskill Mountains, west of Kingston, NY
« Reply #10 on: February 16, 2018, 04:57:05 PM »
Steel wheels also have the advantage of being able to run diesel instead of water and antifreeze.  And a lot less of it.
    • My homepage
« Reply #11 on: February 16, 2018, 05:03:44 PM »
You can run diesel on rubber belts. That's all I ran on the '94 LT40. Never had a problem with the belts, or with pitch. I hardly run any lube on my Super. A little soapy water fyi clean now and then.
Online gmmills
« Reply #12 on: February 18, 2018, 10:33:19 AM »
   I have used both belted wheels and steel wheels on the same mill in the past.  Over all, properly machined, crowned, steel wheels are far superior to loose or tight fitting belted wheels. I can honestly say that I will never go back to a belted wheel.   No belts to be damaged buy broken blades. I am sure you all will agree, it is extremely frustrating to have installed new wheel belts and have a blade prematurely break cutting the new belts contact surface.  Steel wheels will also increase overall blade life up to double that of belted wheels. If you can afford to upgrade to steel wheels, by all means do not hesitate to do so.
Custom sawing full-time since 2000.
WM LT70D62 Remote with Accuset
Sawing since 1995
Offline Larry
« Reply #13 on: February 18, 2018, 11:21:36 AM »
When I had a mill with steel wheels, my bands usually died from sharpening.  With my belted wheels, bands die from breaking.  I'm not sure if my results can be contributed to the wheels or something else.
It would be interesting to hear from others that have ran both style of wheels.
Offline JB Griffin
« Reply #14 on: February 18, 2018, 11:58:08 AM »
Blades at work last longer than they do on my wm, but thats not a fair comparison.  19" belted vs 36" steel :D
Offline climber2
« Reply #15 on: February 18, 2018, 02:07:45 PM »
[quote
[/quote]
I agree.  Maybe a manufacturer could add to the conversation as well. There has to be reasons why some use what they do, 💰 aside
Offline slider
  • sawyer,trucker,tree service
« Reply #16 on: February 18, 2018, 05:20:25 PM »
I think your question has already been answered . The high production sawyers lean towards steel wheels.
al glenn
Online 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #17 on: February 20, 2018, 08:27:33 PM »
My Baker resaw has steel wheels and my lt70 has belts.  The belts beat up the blade and the blade doesnt turn as nice.  The blade on the resaw runs nice and flat and when the blades break they donít ruin the new belts I just put on.  Iíll be putting steel wheels on the 70 at some point
Boy, back in my day..
Offline highleadtimber16
  • Learning Everyday
« Reply #18 on: February 20, 2018, 08:52:42 PM »
I've personally found my best sawing is in the spring/early summer. I do not like frozen logs. Especially frozen fir.
2011 Wood-Mizer LT 40 hyd w/ 12' Extension, Patrick Model A Loader, 75 Hitachi, Stihl 461, 2X066, & ms 192
Cutting Old Growth Cedar from Queen Charlotte Islands.
Offline starmac
« Reply #19 on: February 21, 2018, 12:57:57 AM »
Interesting, do they even make steel wheels for a woodmizer?
Online 4x4American
    • Website Link
« Reply #20 on: February 21, 2018, 06:17:16 AM »
Yea cooks sells em, but theres other ppl doing it also
    • My homepage
« Reply #21 on: February 21, 2018, 08:34:23 AM »
Does the WM4000 run belts? You'll have one of those by fall. :D
Started by Doug Wis on Sawmills and Milling
Last post December 07, 2012, 09:29:22 PM
by Doug Wis
question
Belted vs. all-metal band wheels
Started by Ga Mtn Man on Sawmills and Milling
Last post February 08, 2012, 10:15:48 PM
by Handy Andy
Steel/ Cast bent spoke wheels, and some gears
Started by Ironwood on Wanted
Last post May 06, 2009, 09:01:57 PM
by Ironwood
V-Belt Band wheels vs Cast and Trued w/ Crown Band Wheels
Started by Fly Fisher on Sawmills and Milling
Last post July 16, 2010, 09:32:47 PM
by redbeard
