Tally-I/O
Author Topic: Sthil MS 180 saw hard starting  (Read 395 times)
Offline Ivan49
« on: February 12, 2018, 07:16:04 PM »
 I have a Sthil Ms 180 saw and it is hard to start. I took it in and they cleaned the carb and it still was hard to start but did start. I used it yesterday and shut it off now it won't start. Runs good when it runs. Any ideas
Offline dougand3
Re: Sthil MS 180 saw hard starting
« Reply #1 on: February 12, 2018, 08:55:27 PM »
After you try 5-10 pulls and it doesn't start...pull the spark plug and examine. Wet or Dry? Then reattach plug, ground on cylinder and pull rope. Good spark?
Pull muffler and look at piston. Scoring?
Try a new carb. They are $8 online. Cheap diagnostic test.
I'd be concerned that I took the saw to a shop and it was roughly the same when I got it back.
Offline Ivan49
« Reply #2 on: February 12, 2018, 09:08:00 PM »
The saw would have went back if I had tried it right away but it was weeks after I got it back so that is my fault. I will never take anything there again. This saw does not have many hours on it as I used it as a trim saw on my sawmill. I put a new plug in but maybe it had gas in cyl which I did not think about Thanks I will give it a try
Sthil Parts are hard to get
Started by JSNH on Chainsaws
Last post September 08, 2014, 07:14:49 AM
by JohnG28
sthil 034 hard to pull the cord
Started by chevytoo on Chainsaws
Last post January 07, 2019, 07:56:37 AM
by Al_Smith
hard starting
Started by rockwall on Forestry and Logging
Last post November 17, 2013, 03:43:35 PM
by ga jones
hard starting 660
Started by tlbrooks on Chainsaws
Last post October 13, 2015, 11:45:19 PM
by WV Mountaineer
