Author Topic: Computer setworks for LumberPro HD36  (Read 397 times)
Offline Mike@Norwood
  • Board Moderator
    • www.norwoodsawmills.com
« on: February 23, 2018, 08:42:11 AM »
Computer setworks are available to upgrade your HD36.
Check them out here: https://www.youtube.com/watch?v=t94CJZnI0P4&t=3s
Here’s how they work- “Mark” your first cut to give the computer its original point of reference.
After each cut, the computer will then automatically raise the sawhead to the correct height to safely return to the starting point.
Press “Set” and the sawhead automatically descends ready for the next cut to your programmed board thickness.
Versatile and Easy-to-Use: Quickly change board thickness from one cut to the next – The computer comes pre-programmed with 10 different depth-of-cut settings.
Or easily reprogram any of your ten pre-sets to cut your own specialty dimensions.
You can also change the program to saw in inches or millimeters in increments of 0.001” or 0.1mm.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Computer setworks for LumberPro HD36
« Reply #1 on: February 23, 2018, 09:21:02 AM »
Norwood is a very progressive company and I am sure that this new Computer Setworks will be a welcomed option.
Thank You Mike for the update.
Norwood Setworks for HD36
Started by Ga Mtn Man on Sawmills and Milling
Last post February 17, 2018, 09:33:34 AM
by Ga Mtn Man
Which Computer Setworks to Buy?
Started by Lumber Grader on Sawmills and Milling
Last post November 27, 2017, 09:17:41 AM
by Magicman
What are some of the better computer setworks terminals one could get?
Started by 2StateTrigger on Sawmills and Milling
Last post December 03, 2015, 02:20:54 PM
by Ga Mtn Man
Timberking computer setworks
Started by rconkie on Sawmills and Milling
Last post September 23, 2015, 10:44:52 AM
by rconkie
