Author Topic: Winching Logs  (Read 3228 times)
Offline John Mc
Re: Winching Logs
« Reply #20 on: March 01, 2018, 02:14:08 PM »
Old VW beetle hoods used to be a popular skidding sled. I think there was an old pickup truck hood that was used as well, but I can't remember the model (it would likely be considered an antique now anyway).
If you are handy with metal fabrication (or know someone who is), the attached article includes a sidebar on making your own self-releasing snatch block. (I posted this here several years ago, with permission of the author.) I have not tried it, but was once in communication with someone who did and said it worked fairly well. The main article includes some basic winching tips.
Offline Pat Del Monte
Re: Winching Logs
« Reply #21 on: June 27, 2018, 03:57:16 PM »
How do you get the log out of one of those cones and get the choker off the log. I made one out of a 30 gallon heavyweight plastic barrel but it was so much work to try to unhook it I donít use it anymore
Offline Rhodemont
  • Logging and milling just a hobby
Re: Winching Logs
« Reply #22 on: June 28, 2018, 03:07:20 PM »
I made a a nose sled from a plastic drum and had the same problem.  So I cut a section out to allow acces to take the choker off and the first try the cone crumpled .  I found an old steel rock sled, cut the back lip off.  Worked pretty good banging through rocky areas but plowed soft/mud.  Still do not have this figured out.
Woodmizer LT35HD    JD4720 with Norse350 winch
Stihl 362, 039, and now an Echo CS-2511T
Offline mike_belben
  • Pulp Friction
Re: Winching Logs
« Reply #23 on: June 28, 2018, 04:45:51 PM »
If you need a skiddin cone your machine is too small, you aint getting the butts up high enough, or both.   An arch will outperform a cone.
Revelation 3:20
Offline John Mc
Re: Winching Logs
« Reply #24 on: June 29, 2018, 12:12:22 AM »
If you need a skiddin cone your machine is too small...
Possibly, but a skidding cone is a whole lot less expensive than a new, larger tractor.
Offline PA_Walnut
Re: Winching Logs
« Reply #25 on: June 29, 2018, 04:36:49 AM »
Great topic. I'm aiming to use my RTV for some winch/skidding action. Just got a 9000# winch for it and a snatch block.
I haven't seen anyone talk about a line dampner/blanket. An offload dude I know says to not even THINK about winching with a cable unless you have one...a snapped cable can take someone out.  :o
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Offline mike_belben
  • Pulp Friction
Re: Winching Logs
« Reply #26 on: June 29, 2018, 08:26:13 AM »
Youll notice just about everything with a forestry winch has a cable catcher screen.  Cut up a shopping cart and make you one.
Revelation 3:20
winching logs to my ATV log Arch
Started by oscar not the grouch on Forestry and Logging
Last post January 07, 2010, 08:49:11 AM
by Valley Mick
winching question
Started by Quebecnewf on Forestry and Logging
Last post March 21, 2009, 06:43:29 AM
by Ironwood
Winching question
Started by jph on Forestry and Logging
Last post February 18, 2007, 10:22:35 AM
by jokers
timber jack winching
Started by shawn55 on Forestry and Logging
Last post January 04, 2015, 08:38:44 PM
by shawn55
