Author Topic: Nyle l3  (Read 585 times)
Offline Ricker
Nyle l3
« on: March 02, 2018, 05:34:59 PM »
All I know about kilns is what have read on the forum.  And most of it probably not absorbed.  But a guy I know cleaned out his fathers laws cellar and garages and came across an l33.  It's got to be 30 years old, was in a insulated box trailer when in use 20 years ago, been in dry storage since.  He wants to sell it to me, of course he said will give me a good deal but has no idea what he wants for it.   It seems like good shape for the age, no other fans or equipment just the kiln and control box.  Is something this old worth messing with or if I can get it for a 100 -200 bucks grab it and hope for the best.  Any thoughts appreciated.
Offline GeneWengert-WoodDoc
Re: Nyle l3
« Reply #1 on: March 03, 2018, 12:13:24 AM »
The NYLE L33 compressor is of low value, as the seals are dried or worn.  Plus, today we use a different refrigerant gas but there are substitutes that will work.  You may need a new circulating fan motor ($350).  It is likely too expensive to get into working order.  Maybe you can get a deal where you will pay $500 minus the cost of getting it in working order.  Incidentally, compare it to the L50 made today...it is actually a little bit better.  A new equal unit will run around $3500.  You may have controls with a % run timer...not too good today.
Offline K-Guy
    • http://www.nyle.com/
Re: Nyle l3
« Reply #2 on: March 05, 2018, 12:00:58 PM »
Hey Gene
The L50 has been out of production for about 8-10 years, the new unit is the L53.
Nyle Kiln Sales & Service
If you don't read the newspaper, you're uninformed. If you read the newspaper, you're mis-informed. Mark Twain
Nyle L50 vs Nyle L200
Started by nanook on Drying and Processing
Last post October 21, 2007, 08:55:24 PM
by David Freed
Nyle l50
Started by woodhick on Drying and Processing
Last post November 28, 2005, 11:30:15 AM
by woodhick
nyle l53
Started by Joey Grimes on Drying and Processing
Last post March 13, 2016, 08:11:44 AM
by WDH
Nyle L 53
Started by Downhill Cutter on Drying and Processing
Last post May 19, 2019, 02:44:28 PM
by Downhill Cutter
