Author Topic: gearmatic 8a  (Read 1377 times)
Offline Gary Davis
gearmatic 8a
« on: March 05, 2018, 11:11:18 PM »
I have a gearmatic 8a I am trying to bring back to life it has some missing and broken parts
Item # 59 part # c703a Brake band broken  (my guess #79 was cut and 71 and 79 are missing)
        # 79            a779ax spring saddle  looks like it was cut
        #71              a846a  spacer tube missing
         #78              a845a  spacer tube missing
        # 76              b726a clutch leaver arm
        #57               c718a clutch band secondary needs relined
        #58               b703a clutch band primary     needs relined
as you can see there is plenty of rust ,the clutch lever arm I think I will be able to get welded (looks
like it has ben broke and welded before)
I would like to find a used brake band I think it has to be cheaper to realign the to buy new I have a
post in the wanted items
also what do i need to drive the brake pin out and does it only move in one direction
in the wanted items
It sorta worked before but couldn't free spool and the brake wouldn't hold with a heavy load ( I was
trying pull about 1200 ft  36 ft log 28in dia)
Offline Satamax
Re: gearmatic 8a
« Reply #1 on: March 10, 2018, 12:55:15 PM »
Gary, 312-16 or 312-17 sticks, rockwool
And dot welding.
French CD4 sawmill. Latil TL 73. Self moving hydraulic crane. Iveco daily 4x4 lwb.
Offline Gary Davis
Re: gearmatic 8a
« Reply #2 on: March 10, 2018, 04:34:35 PM »
I got the clutch lever arm welded and the clutches are in the shop being relined
Offline Satamax
Re: gearmatic 8a
« Reply #3 on: March 10, 2018, 09:48:44 PM »
Sorry i was too late!  That's usually me!  ;D
Offline Gary Davis
Re: gearmatic 8a
« Reply #4 on: March 17, 2018, 06:26:09 PM »
I got my clutches relined cost about 150.00
I got them installed this first pick shows the ridged line that was in it and the slave cylender was reversed
the next pic is with the flex line
next step is to replace the outer bearing then I should be able pull loads up after I get the brake out I might be able to repair the brake in the band right now it because of broken and missing parts it wont hold very good and wont free spool so it about 1000.for a brake band and another 300 for the spring saddle and spacers
Offline teakwood
  • Switzerland
Re: gearmatic 8a
« Reply #5 on: March 18, 2018, 08:46:27 AM »
1000 for a brake band???
Offline bushmechanic
  • Someone else has it worse than you.
Re: gearmatic 8a
« Reply #6 on: March 18, 2018, 12:37:49 PM »
I was going to say why didn't you repair those band adjusters while you had it apart? I don't think those welded washers are part of the original mix! If it was me I would have looked for a number 9 Gearmatic to rebuild as those 8's weren't much of it. If you were close to me I have a #9 on the back of a S7 Hough that I am scrapping ;)
Offline Gary Davis
Re: gearmatic 8a
« Reply #7 on: March 18, 2018, 10:13:32 PM »
 its about 1000 for a new brake that's the price from huff equipment and also champion when i get the brake out I am going to see if that brake in the metal can be repaired in the pic its on the lower right corner near the spring ( the broken piece is about 1\8 by 3\8 )
Offline Gary Davis
Re: gearmatic 8a
« Reply #8 on: March 24, 2018, 08:22:31 PM »
the clutch pulls really good now next step is to get the washer tabs to keep the clutch in place repaired
and pull the brake off to see if it can be repaired  ( drill and tap )
Offline mad murdock
Re: gearmatic 8a
« Reply #9 on: March 28, 2018, 03:38:48 AM »
It is great to see the skidder getting the repairs needed. I am so glad you are with that machine. Don Garrett told me the history on that machine when new, it was sold to a Portland Road Co. I got it from a guy in Vernonia, who inherited it from an old gent who had passed away who supposedly was the second owner. He had it for years, I gathered. It sure looks good seeing it getting fixed up.  Will be great to see it pulling wood again! 8)
JD AMT 626, Turbosawmill M6 Warrior Ultra liteweight, Granberg Alaskan III, lots of saws-gas powered and human powered :D
Offline Gary Davis
Re: gearmatic 8a
« Reply #10 on: June 22, 2018, 11:21:41 PM »
to all concerned I found a gearmatic 8a that was taken off a Garrett 15 some time in the early 80s and stored inside also got some pins and the control handle, when I get done I will have some extra parts
Gearmatic 19
Started by mechanics wife on Forestry and Logging
Last post September 30, 2010, 05:46:46 PM
by Autocar
gearmatic 19 again!
Started by treefarmer87 on Forestry and Logging
Last post August 18, 2010, 07:53:06 PM
by treefarmer87
Gearmatic 19
Started by Caseybow123 on Forestry and Logging
Last post June 23, 2017, 10:22:27 PM
by Spartan
gearmatic 19
Started by treefarmer rick on Forestry and Logging
Last post January 14, 2013, 05:11:10 AM
by HiTech
