Author Topic: Low compression husqy 346xp.  (Read 3749 times)
Offline steele109
Re: Low compression husqy 346xp.
« Reply #40 on: April 13, 2018, 11:00:57 PM »
Parts tree doesn't show a plastic washer on any models 1999-01. Except that funky trio brake model.
Offline Dantheforester
« Reply #41 on: April 14, 2018, 10:19:59 AM »
Did you replace the tore cyl gasket or patch that area with sealant?  And does this saw have the metal intake clamp?
I did replace the gasket. It does indeed have that clamp (little devil).
I'll be taking off that "vinyl spacer". I reckon that it may have been a strand of bailing string that wrapped around the shaft and fused with the heat to create a pretty convincing washer.
Thanks again.
346XP NE compression
Started by XP_Slinger on Chainsaws
Last post December 27, 2015, 06:55:32 AM
by XP_Slinger
Husqvarna 346XP compression release?
Started by jjmk98k on Chainsaws
Last post March 19, 2008, 11:41:00 PM
by letsgetitracing
I want a Husqy. 372 vs 575
Started by David B on Wanted
Last post November 19, 2005, 12:58:55 PM
by sawguy21
question
Husqy 55 won't run
Started by jteneyck on Chainsaws
Last post September 02, 2009, 09:48:26 PM
by jteneyck
