Author Topic: air drying post oak/white oak  (Read 2056 times)
Offline paul case
  • Original wearer of the PCM.
Re: air drying post oak/white oak
« Reply #20 on: May 24, 2018, 05:03:55 PM »
So it has been 7 weeks and we started edging yesterday on our stick stacked flitches. I did make our stacks 12 rows high and 42'' wide and stacked them real close to the wall and 2 bundles high and 3 stacks deep. I believe when we started we had 40 stacks of flitches 12 high and 42'' wide. Some of the boards on top and bottom of the stacks had checks, but the insides looked good. I think it would be hard for the buyer not to be happy with my lumber as it is going to grade much better than 3a.
The red oak we stacked this way seems to have no checking.
 So it works for us.
PC
pc
Offline nativewolf
« Reply #21 on: May 24, 2018, 07:18:19 PM »
It helps to have 24k sq ft of barn you lucky son of a gun  8).
Liking Walnut
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #22 on: May 24, 2018, 08:07:57 PM »
That's great news.  White oak is a challenge.
HobbyHardwoodAlabama.com
Offline paul case
« Reply #23 on: May 24, 2018, 09:31:00 PM »
They are 16 k each and there are 4 of them. I paid for every sq inch too.
I dont want to mislead anyone. The purpose for sticking the stack was to keep the lumber in good shape until I had enough to ship. Not to dry the lumber. Only to keep it from molding in the humid and sometimes dry spring/summer/fall.
PC
pc
Offline GeneWengert-WoodDoc
« Reply #24 on: May 24, 2018, 11:15:05 PM »
In response to the question:  So, in a general sense, would you say that when the RH is under 40? 50? it's a good time to shade and block?
The answer depends on species, thickness and MC.  For green 4/4 oak, 50% is the minimum RH.  For pine, maybe 10% RH.  The air temperature is also a factor...protect lumber more when it is hotter, but even cold (below freezing), dry-humidity days can create damage in green oak.
Fan drying white oak
Started by Southside logger on Drying and Processing
Last post April 11, 2018, 05:44:56 PM
by GeneWengert-WoodDoc
Air drying White oak
Started by jack on Drying and Processing
Last post June 04, 2006, 01:10:12 PM
by Flurida_BlackCreek
Drying white Oak
Started by John Mc on Drying and Processing
Last post January 23, 2009, 07:13:42 PM
by ED B
Drying Quartersawn White Oak
Started by Jim Spencer on Drying and Processing
Last post August 03, 2010, 09:42:04 AM
by brdmkr
